This thread is privately moderated by boredom.is.me, who may elect to delete unwanted replies.
Old Feb 05, 2011, 01:00 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
bimRc Micro EDF Information
This will be the new guide to my various ducted fan products.
Price List
Unit Specifications
Bench Test Figures
Under Development
"What does NDF/MDF stand for?"
NDF - Nano Ducted Fan
MDF - Micro or Mini Ducted Fan
"What do all the numbers mean?"
The "numbers" are easy to read once you understand what they represent.
NDF22L/10 G2
- This is the general size indicator.
- This indicates the inner diameter of the housing.
- This tells whether there is an intake lip or not.
- This either indicates the max motor diameter or the motor diameter the housing was designed for.
- This indicates what version the specific model is.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Feb 05, 2011, 01:01 PM
Joined Nov 2007
Price List
Housings:
NDF22 G2 - $2
NDF22 Super - TBD
MDF25 3-stat - $2.5
MDF25 5-stat - $2.75
MDF25 Outrunner - $3
MDF30 - $6.5
MDF30L - $7.25
MDF40/20 - $12
MDF40/KMS - $12.25
Intake Lips:
NDF22 G2 - $0.75
Motor Combos:
NDF22 with Turnigy 1015 - $25
Mounting Screws (pair):
10mm Motor - $1
12mm Motor - TBD
Thrust Stands:
NDF22 - $6
MDF25 - TBD
MDF30 - TBD
MDF40 - TBD
Rotor Trimmers:
RT22/12x10 - $3.5
What's what?
- Motor Combos include the housing, rotor, motor, pre-soldered connectors, and mounting screws.
- Mounting screws are the screws necessary for mounting a given motor into a fan housing.
- Thrust Stands will be capable of holding the edf unit even if it has an intake lip attached.
- Rotor Trimmers are little devices used to easily trim a rotor to the proper size. They are made for brushed motors so they are cheap to build and operate.
Shipping:
U.S. (Domestic) - $6.5
International - $12
Shapeways Startup Fee - $1.5 (all orders)
Old Feb 05, 2011, 01:02 PM
Joined Nov 2007
Unit Specs
NDF22 G2 Series Specifications:
Inner Dia. - 22mm
Outer Dia. - 23.4mm
Outer Dia. with Lip -
Height - 15.5mm
Height with Lip - 20mm
Motor Option(s) - 7mm, 8mm, 8.4mm, 10mm, 2 gram
Intended Rotor(s) - GWS EDF30
Stator Count - 3
Housing Weight -
Extras - Thrust Stand
MDF25 Specifications:
Inner Dia. - 25mm
Outer Dia. - 26.4mm
Height - 16mm
Height with Lip -
Motor Option(s) - 10mm, 12mm
Intended Rotor(s) - GWS EDF30, GWS EDF40, AeoRc 27mm 8-blade, AeoRc 30mm 8-blade
Stator Count - 3
Housing Weight - TBD
MDF25 Outrunner Edition Specifications:
Inner Dia. - 25mm
Outer Dia. - 26.4mm
Height -
Height with Lip -
Max Outrunner Diameter - 14mm Outrunner
Intended Rotor(s) -
Stator Count - 5
MDF30/12 Specifications:
Inner Dia. - 30mm
Outer Dia. - 31.6mm
Outer Dia. with Lip - 39.4mm
Height - 27.5mm
Height with Lip - 31.5mm
Motor Option(s) - 12mm
Intended Rotor(s) - GWS EDF40, AeoRc 30mm 8 blade
Stator Count - 5
MDF40/20 Specifications:
Inner Diameter - 40mm
Outer Diameter - 42mm
Max Motor Diameter - 20.8mm
Outer Motor Hub Diameter - 22.8mm
Height - 35mm
Added Height of motor cone - 50mm
Added Height of Lip - TBD
Outer Diameter of Intake Lip - TBD
Stator Count - 5
MDF40/KMS Specifications:
Max Motor Diameter - 21.4mm
Outer Motor Hub Diameter - 23.4mm
Height - 35mm
Stator Count - 5
Joined Nov 2007
Bench Test Figures
NDF22 G2
Motor - Turnigy 1015 11500kv
ESC requirement: 4 amp
Battery: 2-3 cell capable of 2.5-* amp discharge
Thrust: 30-* grams
Watts: 15.54-*W
Weight: 6.5 grams
Old Feb 05, 2011, 01:03 PM
Joined Nov 2007
Under Development
NDF22 Super Series Specifications:
Inner Dia. - 22mm
Outer Dia. - 23.4mm
Height - 20mm
Height with Lip -
Intended Rotor(s) -
Stator Count - 5
MDF30/10Specifications:
Inner Dia. - 30mm
Outer Dia. - 31.6mm
Height -
Height with Lip -
Max Motor Diameter - 10mm Outrunner
Intended Rotor(s) -
Stator Count - 5
Intake Lip
Motor Cone
Intake Lip
Motor Cone
Thrust Stands for all sizes
Discussion 3000 Watt 70mm EDF video with motor information gundamnitpete Electric Ducted Fan Jet Talk 19 Jan 07, 2010 12:57 AM
This is not Micro Helis and other Newbie information. Fred Bronk Electric Heli Talk 0 Dec 30, 2004 11:43 PM
Rave Micro Electric Information requested MicroWannaBe Beginner Training Area (Aircraft-Electric) 4 Nov 03, 2004 09:09 PM
Micro Electric Information Requested MicroWannaBe Scratchbuilt Indoor and Micro Models 1 Oct 31, 2004 10:34 PM
Question Micro plans / Setups / Information ????? MicroRotors Scratchbuilt Indoor and Micro Models 1 Dec 31, 2001 02:34 AM
