Made a video to show the difference
United States
Joined Feb 2001
Exactly what is the problem?
I have been using CC ESC’s for many years with a couple of eMultiGov governors. They have all worked perfectly and have very tight headspeed control. What about the new Futaba CGY750 with governor? I have one on the way and was planning on using it with my ICE 100. ? |
To clarify the issue:
So it's not that it won't work. It's just that it doesn't work nearly as well as other ESC's that have a nearly instant throttle response. So as it stands now, if you want to use the vbar gov, a Castle ESC is not the best choice. It's clearly to Castle's advantage making their ESC's the premier performer with the vbar governor. It becomes much harder to justify the super high end ESC's as the performance has been touted as better then anything else currently on the market. http://www.mikado-heli.com.hk/e-vend...t=36&c=36&p=36 Here's the marketing: Quote:
Ontario, Canada
Joined Sep 2009
Kontronik ESCs seem to have issues with the vBar gov as well:
http://rc.runryder.com/helicopter/t630322p1/ Can someone remind me why we need flybarless?
Another interesting tidbit.
If you're in fixed endpoint mode and set the head speed change rate to max (20) there is a 2 second delay on throttle changes! So the average guy using v curves gets really bad performance. This has me wondering. Does the Castle gov get sent through the same throttle filter as airplane mode? This would really hinder performance. |
United States
Joined Feb 2001
| Thread Tools | |
| Discussion Ardrone SDK 1.5 Patch for last revision of firmware | redfox74 | Multirotor Talk | 0 | Dec 25, 2010 09:50 AM |
| Discussion 1.2ghz patch vs 900mhz patch | JohnyGab | Video Piloting (FPV/RPV) | 6 | Dec 22, 2010 06:48 AM |
| Question Phoenix Firmware v3.1 - Gov Mode - the most accurate | gww528 | Castle Creations | 4 | Jul 07, 2008 08:35 AM |
| Discussion Words, phrases and Lies. Trickery used by Gov. to Bolster Support for wars. | BACKEMFNRG | Life, The Universe, and Politics | 32 | Jul 03, 2007 06:34 PM |
| Phx25 Gov Mode Firmware | tadawson | Castle Creations | 4 | Jun 22, 2005 06:29 PM |
