Old Feb 04, 2011, 01:48 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
RC Vector Kites proposal
This is a request for Jim Graham to reconsider the comment he made in the Site Complaints area: http://www.rcgroups.com/forums/showt...php?t=1382991: “I'm wondering if a kite forum has a place on an RC forum.” I cannot respond in the Site Complaints forum, so am doing it here.
That post was in connection with the proposed creation of a new forum for “RC Kites”: http://www.rcgroups.com/forums/showthread.php?t=1381366.
Jim, at first sight and taken in isolation, your comment may appear to be valid (it does surprise me to see a moderator make such a comment in connection with a legitimate new forum proposal procedure, but we’ll let that pass).
I wonder whether you have ever had the time to look at what is involved here, and see the types of models and equipment that are being used and developed. These are not simple kites on strings, in the generally-understood sense of the word “kite”. They should, perhaps, be called something like “flexible-wing RC aircraft”. The most commonly used term is “vector kites” and a search on RCG and/or Google will give you some indication of what is being done in this new and very exciting field.
Here, for example, are just a few links:
http://www.rcgroups.com/forums/showthread.php?t=1354564
http://www.rcgroups.com/forums/showthread.php?t=1333679
www.crazyplanes.de/specials.htm
And some videos:
www.crazyplanes.de/deltaxxxl7.wmv
www.crazyplanes.de/bebopextreme.wmv
www.crazyplanes.de/deltaxxxl6.wmv
Clearly, these models are very much RC related. In fact, most of them require a great deal more skill, inventiveness, ingenuity, and effort than many more conventional types of RC models.
Even if that were not the case, I am having some difficulty understanding your comment in view of some of the other forums that exist on RCG and which you would have to agree are hardly RC related. Just a few examples: Free Flight. Control Line. Full-scale Automobiles. Frisbees (!). Boomerangs (!). And we won’t even mention Chit Chat or LTUP.
So, Jim, I would respectfully request that you take a few minutes to look into what is being discussed and proposed here, and ask you to consider rescinding your implication that these models have no place on RCG. Perhaps we might even get your support for the creation of the proposed new forum, so that these models would have a proper home on RCG and not have to be scattered all over the board as they are at present (in diverse forums such as "aerial photography", "night flying", "builder's workshop", “flying wings”, and others).
Thanks for reading this and (hopefully) giving the matter some thought and consideration.
Harry D is offline Find More Posts by Harry D
Old Feb 04, 2011, 02:44 PM
jbourke is offline
Find More Posts by jbourke
Administrator
jbourke's Avatar
United States, OR, Corvallis
Joined Nov 1998
Harry,
I agree with you. The "Related Hobbies" section is the proper place for a kite forum. I enjoy stunt kites and I'm sure a lot of other r/c-ers do as well.
I think Jim's point was probably that it wouldn't be accepted by the users. I don't necessarily share that view. In any case, rest assured that if the forum is proposed and accepted via the proper process, the admins won't stand in the way.
Jim
jbourke is offline Find More Posts by jbourke
Administrator
Old Feb 04, 2011, 04:58 PM
Jim T. Graham is offline
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
Harry D - you are absolutely correct, that is an RC related kite! Thanks for the great links. I have seen these fly at an outdoor and indoor show. I guess when you said a kite forum I had the image of the kites we had as kids. These are very cool. I'm excited about the prospect of a forum related to these RC kites.
Jim T. Graham is offline Find More Posts by Jim T. Graham
Administrator
Old Feb 04, 2011, 05:10 PM
Harry D is offline
TLAR Aviation
Harry D's Avatar
Thank you
Thanks, Jim and Jim. I hope the new forum "gets off the ground".
Old Feb 04, 2011, 05:57 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
"RC" can also stand for Remote-Controlled which a vectored kite certainly is. For me, if the wind is up I go slope soaring but I usually have a two-string delta not far away for when the wind isn't vectoring properly.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Feb 04, 2011, 10:08 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
mw
Mark, I think like Jim you're misunderstanding the term "vector kite". Our vector kites don't have strings.
slebetman is offline Find More Posts by slebetman
Old Feb 04, 2011, 11:54 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
If they are R/C I would hope not. It would be somewhat redundant, no?
Please enlighten me on the term.
mw
Old Feb 05, 2011, 09:30 AM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
Hi Mark, enlightening always helps
I converted a big number of different kites to RC (and built some by my own) within the last 4 Years, for which I developped and used interchangeable 2D or 3D or 4D Vector-Units.
I think, the following might help to clear the subject, 'What Vector Kites are' :
I define a Vector Kite as an untethered flying RC-Object, using
- a flexible wing of all kind of usual kite constructions without control surfaces
- using kite technology (fabric, film, glasfibre and/or cf rods)
- using modern RC-technology and (brushless) electric motor(s) within a so called 'Vector Unit'
- a Vector Unit construction, based on a gimbel, or universal joint, or swashplate, or flextube, or 2 connected servos, that enables the pilot to control the propeller's flow direction in all directions (right, left, up, down, every degree between, as well as forward and backward .)
I call those RC-Kites as 'Vector Kites' since 2006.
Before I started in 2006, different Kite-To-RC-conversions existed - motorized or non-motorized - as kites of different shapes, using wing-warping or control-surfaces for steering.
As You can see: There exist 2 kind of 'Kite-to-RC-conversions', those, which are 'Vector Kites' as RC-Kites, and those, who use surfaces or wing-warping for steering.
@ Jim: I'm also excited about the prospect of a forum related to RC-Kite Conversions, as Vector-Kites, or non-Vector Kites.
But I also know about the problems, many traditional orientated Model-RC Aircrafter have with those strange looking, but RC-piloted flying objects:
No surfaces, no fuselages, no cabin, no pilot-puppet, not the real thing ...
For me, Vector Kites are a new kind of RC-Aircraft, opening a very different a n d interesting kind of piloting.
On the other side - and that might be the most interesting aspect - the use of the technique of an interchangeable Vector Unit allows to create completly different new flying objects -without control-surfaces - like no other.
In so far, Mark: Welcome to the world of Vector Kites!
flattermann
flattermann is offline Find More Posts by flattermann
Last edited by flattermann; Feb 05, 2011 at 10:15 AM. Reason: ... forgot one aspect
Old Feb 05, 2011, 10:52 AM
Treetop is offline
Find More Posts by Treetop
sensitive artsy type
Treetop's Avatar
Tucker, Georgia, United States
Joined Feb 2004
mw
Them's control line kites.
Treetop is offline Find More Posts by Treetop
Old Feb 05, 2011, 12:26 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
19 foot vector kite, flying indoors...
19 feet RC-Vectorkite Indoor (3 min 40 sec)
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Feb 05, 2011, 12:38 PM
Treetop is offline
Treetop's Avatar
Joined Feb 2004
Someone needs to build one that looks like a Manta Ray, it moves so much like one.
Old Feb 05, 2011, 01:06 PM
Germany
Joined Dec 2006
Hi treetop,
Hope, You will like this Vector Kite, which is one of my favourites:
www.crazyplanes.de/manta300wind.wmv
flattermann
Old Feb 05, 2011, 01:27 PM
Treetop is offline
Treetop's Avatar
Joined Feb 2004
I like! I was curious as to how they behaved outdoors. Seems to handle quite a bit of wind, which surprised me. The windmills in the background added a great deal to the video as proof of how well the wind was blowing. Also the kites early on did as well.
I always meant to get one of those I.F.O. kite-like planes, and I saved a thread where a guy built a large one. I will see if I can find it, it is several years old, but was something I was also interested in. Of course the IFO models have more plane like control surfaces.
Thanks for that flatterman!
Old Feb 07, 2011, 01:08 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Glad we got it all sorted out! Having fun is teh main thing, so thats all that really matters.
Was the original complaint from someone who thought we were proposing simple line kites? Or ... ? The post I was given a penalty point for was on the "Hawkeye" thread (an RC kite used for aerial photography). After that post, several of the Hawkeye owners joined our proposal for an RC Kite section, including the owner of the company and starter of the thread in question. So I'm still wondering what happened there. It was a bit upsetting to get penalized for trying to do something nice. I'd like to think it was just the result of busy mods on a large site not having all the background information. As a side, it may help to have some leniency on the idea of "cross-posting" when dealing with proposals of this kind (such as where there is no main heading for a section proposal to be subbed under).
In any case, happy flying!
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Feb 15, 2011, 12:25 PM
Expat
Japan
Joined Apr 2010
Jim, or whoever was responsible for leaning the penalties against my account for this, I'd like a response please.
Discussion Vector Kites - wow! Slider2732 Scratchbuilt Indoor and Micro Models 113 Feb 21, 2011 11:57 PM
New Product R/C Vector kites by Premier Designs STRINGFLY Parkflyers 16 Feb 01, 2011 07:47 AM
Off Site Vector Kites tbroeski Aircraft - General - Miscellaneous (FS/W) 3 Jan 16, 2011 06:03 PM
Cool Vector Kites tbroeski Electric Sailplanes 0 Jan 06, 2011 11:04 AM
