Old Dec 04, 2012, 11:00 PM
Znybar is offline
Find More Posts by Znybar
Joined Sep 2012
I honestly don't recommend the MCPX, coaxials react completely differently to FP or CP helis (you need to keep down elevator to keep them moving, for example) that lead to bad habits. It'd either use the money to jump to a MSRX (FP heli) or buy a good sim.
Also, a good pair of training gear and you can start straight with the 450. It's what I did and now I'm comfortably flying inverted. The 450 is going to be much more stable than the smaller models, and as long as you don't push yourself too fast you'll have much more fun than an MCPX.
Znybar is offline Find More Posts by Znybar
Old Dec 04, 2012, 11:46 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
MCPX is a full CP heli. You must be thinking of the MCX or MCX2, Blade's micro coax heli.
stuball56 is offline Find More Posts by stuball56
Old Dec 04, 2012, 11:47 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
I think you're thinking of the MCX, MCX2 rather than the MCPX. The MCPX is a CP heli and is a lot of fun, IMO. If you can react fast enough to an MCPX, the 450 will seem like a piece of cake.
Jboy90277 is offline Find More Posts by Jboy90277
Old Dec 05, 2012, 12:00 AM
Znybar is offline
Joined Sep 2012
Whoops, my bad.
Agreed, if you can fly the Mcpx or nano, the 450 will seem easy by comparison. I practiced inverted on my nano, and when I finally psyched myself up to do it on the 450 it was scarily easy.
Old Dec 05, 2012, 12:05 AM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
I went from the CX2 to a MSR without any problem. The Scout is just my fun "torment the cat" toy". Looking to step up to a Blade 450 3D at some point. I don't want to do 3D, don't much care for 3D flying in general, I'm more of scale guy. I'm thinking a CP w/ FB is the next best step. Going straight to CP FBL would get expensive!
Moonbeam is offline Find More Posts by Moonbeam
Old Dec 05, 2012, 12:08 AM
Znybar is offline
Joined Sep 2012
You'd be surprised regarding 3D. I went into helis with teh same mentality, but once you get to the level that you've mastered basic flight you want to challenge yourself and do new things.
Old Dec 05, 2012, 03:25 AM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
In the beginning, 90% of us say this. No 3D for me! I still say it. But I can see that as my skills progress I want to try new things. Right now, "new" to me is flying in a simple circle. I have not mastered that, far from it. So yes, 3D seems like nothing I want anything to do with at this time. Once flying in a circle becomes routine and "boring" well then..............
Old Dec 05, 2012, 03:30 AM
Znybar is offline
Joined Sep 2012
You'll be flying inverted before you can say 'no 3d'
Old Dec 05, 2012, 06:37 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
I don't have a FB yet but they have way fewer parts to break! Might be cheaper in the long run.
jrjr is offline Find More Posts by jrjr
Old Dec 05, 2012, 12:45 PM
Wookster is offline
Find More Posts by Wookster
Augernaut
Wookster's Avatar
United States, KS, Overland Park
Joined Jan 2010
Originally Posted by Znybar View Post
Whoops, my bad.
See I'm just the opposite. I have a much harder time with the 450 than the Nano Or MCPX. I think its a bit of intimidation from the energy in the rotor and the idea that if I goof this up she isn't going to just bounce off the tree. Flight is easier, I do fast forward flight with loops and rolls. Not much inverted yet, its always been windy and I cant get the 450 to hold. its the anxiety that seems to interfere. I can't just bang a 450 around and know its all going to be ok if i make a mistake. So I find the small helis much more enjoyable.
Wookster is offline Find More Posts by Wookster
Old Dec 05, 2012, 04:53 PM
Znybar is offline
Joined Sep 2012
I'd suggest doing some more flying with the 450, even if its not inverted. I learnt the hard way that being nervous only makes your flying terrible. I'd say just fly random patterns at your own pace with teh 450 so that anxiety isn't an issue. I ended up being so comfortable I had the reflex of inverting (from the sim and the nano) and it was done before I'd realized my 'error'
Old Dec 05, 2012, 09:06 PM
Joined Dec 2011
While the 450 will likely break something if you do make a mistake, it's not as bad as you would think if you're fast with the throttle hold. The stock parts are relatively cheap and it isn't too difficult to fix. Hobbypartz also has low cost blades that have helped keep the repair costs down (work pretty well, too). I've crashed enough times to know - this video being just the latest instance out of about 5 crashes now.
All I can say about this particular crash is the combination of Corona 939mg digitals and the Align 3GX FBL controller cannot handle that particular maneuver - it's gone into uncontrolled, tumbling flight each time I've tried it. Crash #4 happened with the same maneuver. I don't think it's the thumbs - can do this pretty easily with my 130X.
I'm upgrading to an AR7200BX and Savox digital servos (combo pack for 450s) next. I'm testing out setups with the 450 before going to the bigger TREX 500 and TREX 600 that are waiting to be built up.
Blade 450 3D Crash Again (3 min 1 sec)
Old Dec 06, 2012, 09:42 AM
deonjams is offline
Find More Posts by deonjams
Philippines, NCR, QC
Joined Dec 2011
Same here
deonjams is offline Find More Posts by deonjams
Old Dec 09, 2012, 08:37 AM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
that happened to me....but in sims.....hopefully I can do it wt my B450...
CPMBOY is offline Find More Posts by CPMBOY
Old Dec 19, 2012, 10:15 AM
H2Ohaze is offline
Find More Posts by H2Ohaze
United States, CO, Loveland
Joined Apr 2009
Question on Futaba 9C transmitter vs the Dx6i:
I just ordered a 450 3D, but I have a Phoenix sim and some other RC stuff (boats, etc). I recently installed a Specktrum DM8 2.4 ghz module into the Futaba to allow it to control all the specktrum receivers I have.
Basically question is: The Futaba requires me to reverse at least throttle(3), pitch(6), and possibly other channels like elevator(2). Will this be bad mojo, do I have to do extra special stuff to make it perform the same as the Dx6i would?
On the Sim, strangely, I have to reverse channels 2, 3, and 6 (elevator, throttle, and pitch). I'm not sure what to do with channel 5 on this...on the Dx6i this can be set normal/stunt? The Futaba gives you three "idle ups" meant for more aggressive flying in addition to a "default" normal...all controlled by other switches independent of channel.
H2Ohaze is offline Find More Posts by H2Ohaze
New Product Blade 450 3D RTF/BNF! DFflyer Mini Helis 63 Apr 08, 2013 06:26 PM
New Product New Blade 450 3D choppersrule Electric Heli Talk 0 Feb 03, 2011 10:08 PM
Wanted WTT Blade MSR BNF plus cash for a 450, 250, or Blade 400 RX ready jedi391 Aircraft - Electric - Helis (FS/W) 1 Jan 08, 2011 12:13 PM
Discussion Blade 400 3D and E-Revo, or T-Rex 450 SE V2... heliaddict22 Off-road Cars 2 Oct 22, 2008 10:51 PM
Discussion TREX 450 or EFlite Blade 400 3D or Belt CP carbon? emiliomuno Mini Helis 7 Oct 02, 2008 07:22 PM
