Old Jan 29, 2012, 10:22 PM
TexasC is offline
Find More Posts by TexasC
United States, TX, Houston
Joined Dec 2011
Originally Posted by FuntanaS View Post
Where are you planning on buying it? Ampdraw.com has the best price.
For spare parts I would say; blades, flybar, feathering shaft, tail boom, main gear, and main shaft.
I would suggest the Gens Ace 2200mah 25C battery from Hobbypartz.com It is on sale right now and is highly rated over on helifreak.com
http://www.hobbypartz.com/98p-25c-2200-3s1p.html
Also instead of spending $14 on the stock wood blades I would recommend going with the fiber glass blades also from hobbypartz. They are only $3 and they shatter when you crash instead of transferring the energy to the head.
http://www.hobbypartz.com/60p-pro-3252.html
Is the price really better? How much is shipping. Horizon Hobby has free shipping on everything over $100.
TexasC is offline Find More Posts by TexasC
Old Jan 29, 2012, 11:01 PM
Didgeridood is offline
Find More Posts by Didgeridood
Didgeridood's Avatar
United States, AK, Cordova
Joined Oct 2011
So after another crash with my 450 I am in need of some help. I was thinking about converting it to FBL with a tarot head or align head. Which would be a fun project but now I am just irritated with myself because I cant figure this out. I have watched how to's and watched the blade videos many times. I have +12 pitch and -5 pitch O_O I cant seem to get it right... I would really like if someone could help me out in getting my heli back to normal. Perhaps over skype or something
Steve
Didgeridood is offline Find More Posts by Didgeridood
Old Jan 30, 2012, 11:33 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Originally Posted by TexasC View Post
I can definitely vouch for that statement. I stuggled to get good solder connections when I had a cheapo 15 watt soldering iron. I couldn't understand why the covering on my wires would melt but the solder wouldn't. Turns out I was having to hold the iron on the wire/connector too long to heat it and heat was transferred throughout the wire melting the sheathing.
As soon as I got a Weller 40 watt soldering station, it only takes a second or two to tin my wires and solder my connectors. What a difference a good soldering iron makes.
You also have to watch the battery leads, the Turnigy brand have a coating on the higher C rated batteries (sorry I can't remember the name of the coating...zinc maybe?) which makes it difficult for the solder to take no matter how much flux I used. In the end I was advised to gently file (I actually used a Dremel bit) to lightly scuff the wires up before I tried again, which solved the problem.
feefo is offline Find More Posts by feefo
Old Jan 30, 2012, 12:31 PM
Manzooka is offline
Find More Posts by Manzooka
Newb
Manzooka's Avatar
United States, VA, Richmond
Joined Dec 2011
Just had my first set of real outdoor flights on my 450 with the exception of a hover experiment several days ago. I burned through six batteries and had a blast! I took some videos so I'll post those a little later when I get them uploaded.
One big question though... and keep in mind that I'm very much a heli newb . Every time I begin a new flight my rudder seems really out of trim and it takes some effort to get it readjusted. It was always a little different too, never the same adjustment needed and even direction of adjustment could be different between flights. Am I missing something simple here? I'm using a JR X9503 btw.
I'm also still getting a little tail wag and trying to figure that one out.
Manzooka is offline Find More Posts by Manzooka
Old Jan 30, 2012, 05:24 PM
Manzooka is offline
Newb
Manzooka's Avatar
Joined Dec 2011
Just went out for a second round of flights and it was pretty much the same experience... a minute to or two to get the rudder trim adjusted and then relatively smooth flight with a little tail wag. But on my final flight the tail of my 450 was severely jerking left and right to the point that I almost crashed.
Old Jan 30, 2012, 06:10 PM
Joined Oct 2011
I had to play with my gyro gain a tad to get the wag to stop.
Old Jan 30, 2012, 10:53 PM
SgtManny is offline
Find More Posts by SgtManny
Joined Dec 2011
@Manzooka Is there a big temperature difference from when you take your heli out of the house and the area you fly at? My Blade SR flew great the other morning as I set it outside on the porch to let it acclimate and the tail held; but later in the day if I went straight to the park, the tail would just slightly drift. It was about 40 degrees outside, so a difference of 30 degrees may have been pretty significant.
SgtManny is offline Find More Posts by SgtManny
Old Jan 31, 2012, 05:37 AM
Manzooka is offline
Newb
Manzooka's Avatar
Joined Dec 2011
Thanks for the suggestion Manny, but I don't think that's the problem. I keep my heli's in my garage and it stays pretty close to outdoor temps this time of year. Besides, we're not talking about a "little" drift. Whenever I first get my heli in the air on a new battery it will make a complete rotation on its own within 2-3 secs without input.
I've just read a little something about gyros not liking rudder trim and about how I'll be better off trying to adjust for this behavior mechanically. I suppose I'll work on that this evening unless anyone else has a recommendation.
Old Jan 31, 2012, 09:00 PM
Manzooka is offline
Newb
Manzooka's Avatar
Joined Dec 2011
I spent the afternoon fooling around with the gyro, tail servo, and tail assembly and regardless what I did I still got pretty much the same results... constant (and usually rapid) tail drift. I saw someone mention that vibration could be causing the problem so I starting pursuing that possibility.
I tried taking off the blades (but left the flybar and paddles on) and spooled the heli up safely in my hands and there is vibration a plenty! I also noticed that the head assembly looked a wee bit wobbly. Could this be the result of the blades being off or I have a I narrowed down the likely cause of my problem to an issue with the head assembly?
I haven't crashed and nothing *looks* bent, not that that means anything .
Old Feb 01, 2012, 04:02 PM
Manzooka is offline
Newb
Manzooka's Avatar
Joined Dec 2011
Here's a vid showing off the issue. It's in three short sections. First is just spool up behavior, second shows the tail drift issue during hover, third shows relatively smooth forward flight after adjusting with rudder trim.
Stock Blade 450 3d ... tail drift? (1 min 34 sec)
Old Feb 01, 2012, 06:56 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
ok my dad cant fly his b 450 3d to much for him so now he should get the blade 300?
skarface is offline Find More Posts by skarface
Old Feb 01, 2012, 07:31 PM
FuntanaS is offline
Find More Posts by FuntanaS
Registered Flyer
White Bear Lake, MN
Joined Jun 2006
Shipping was $7.99 and the Blade 450 BNF was $247.99 so it came out to be $256. Almost $50 cheaper.
FuntanaS is offline Find More Posts by FuntanaS
Old Feb 02, 2012, 12:44 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
I can't see it being any easier, it's just smaller, which can mean it's actually harder. Sim practise did it for me, I don't really like using the sim but I wouldn't have learnt to hover otherwise.
Old Feb 02, 2012, 01:50 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
ok thanks i tried getting him on the sim at the hobby store and he just looked at it as a game and said no lets go. i will have to tell him about your post because he would get 1 foot above the ground be drifting everywhere then one of the training gear would get caught and he would flip.
Old Feb 02, 2012, 02:07 PM
rpstar is online now
Find More Posts by rpstar
rpstar's Avatar
Dacula, GA
Joined Feb 2008
Get a Blade 120SR or something similar. You could get the mcpx but it's going to be even harder than the 450 but it does take abuse. I have both the mcpx and the 120sr and the 120SR is a good entry point if you ask me. I've bounced mine of tables, lamps, chairs, stair railings, and it keeps coming back for more. Of course I've had to replace blades and such but they are cheap.
rpstar is online now Find More Posts by rpstar
New Product Blade 450 3D RTF/BNF! DFflyer Mini Helis 63 Apr 08, 2013 05:26 PM
New Product New Blade 450 3D choppersrule Electric Heli Talk 0 Feb 03, 2011 09:08 PM
Wanted WTT Blade MSR BNF plus cash for a 450, 250, or Blade 400 RX ready jedi391 Aircraft - Electric - Helis (FS/W) 1 Jan 08, 2011 11:13 AM
Discussion Blade 400 3D and E-Revo, or T-Rex 450 SE V2... heliaddict22 Off-road Cars 2 Oct 22, 2008 09:51 PM
Discussion TREX 450 or EFlite Blade 400 3D or Belt CP carbon? emiliomuno Mini Helis 7 Oct 02, 2008 06:22 PM
