Old Aug 09, 2011, 07:58 PM
nick_onelove is offline
Find More Posts by nick_onelove
Build, Fly, Crash. Repeat.
nick_onelove's Avatar
Joined May 2011
I'm using the 4200Kv upgrade motor with the 11T pinion, and Align carbons. I will be getting the aluminum blade grips (and most of the other aluminum upgrades for that matter) as soon as they are available.
nick_onelove is offline Find More Posts by nick_onelove
Old Aug 26, 2011, 09:45 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Just got my RTF delivered. Anyone have any tips for this bird? I'm hoping to use my valuehobby 2200 30c batteries. What kind of flight times are you all getting with the stock battery? Thanks for any input
wavekatcher is offline Find More Posts by wavekatcher
Old Aug 26, 2011, 09:52 PM
jenn123 is offline
Find More Posts by jenn123
United States, NV, Las Vegas
Joined Apr 2011
Every now and then I check in on this thread. Was thinking about buying one..All in all are you guys happy with this heli ?? Is it e-flites best yet ?
jenn123 is offline Find More Posts by jenn123
Reply With Quote  (Disabled)
Old Aug 26, 2011, 10:14 PM
Joined May 2011
I get about 5 minutes of 3D with the stock battery and the upgrade motor. So probably like 6 or maybe even 7 minutes of hovering with the stock motor.
I would say it is one of E-Flite's best. Very stable with dual-rates yet also extremely 3D capable, especially with the flybar weights removed and the upgrade motor installed. And the price! It just doesn't get any better for such a low price, especially if you already have a Spektrum transmitter.
Old Aug 26, 2011, 11:50 PM
Joined Mar 2011
Thanks Nick,
I saw one fly and had to have one. I have a 2 year old son, so no time for building a Trex any time soon.
The price was good. I needed another tx so I went with the RTF version. $396 delivered to my front door. (in one piece I might add) I love Wholesale Trains.com I might as well have my paycheck direct deposited to them.....
Old Aug 26, 2011, 11:59 PM
Joined May 2011
Wow, if you're talking US dollars you got a hell of a deal! Congrats, I think you'll enjoy it.
Old Aug 27, 2011, 09:55 PM
JIMBAKER is offline
Find More Posts by JIMBAKER
called into work, I'm AIRSICK!
JIMBAKER's Avatar
Oregon
Joined Jan 2009
Where would one find smaller pinions for the Turnigy 2836 motor? The shaft size is 3.18mm, I need a 10 T but not any bigger than a 13 T would help. Thanks
Blade 450 With Turnigy 2836-3200kv motor.wmv (3 min 43 sec)
JIMBAKER is offline Find More Posts by JIMBAKER
Old Aug 27, 2011, 10:09 PM
Joined May 2011
I'm not sure, awesome aerial footage though!!!
If you can't get it figured out, keep in mind Eflite also has an upgrade motor available, for only $2 more than a new stock motor. It made a pretty significant difference in mine.
Old Aug 27, 2011, 11:02 PM
Joined Mar 2011
Nice video Jimbaker!
Old Aug 30, 2011, 11:02 AM
JIMBAKER is offline
JIMBAKER's Avatar
Oregon
Joined Jan 2009
Thanks Guys,
I measured the shaft again on my Turnigy motor to make sure of what I needed and using a drill index I found that I had a drill bit that was ever so close to the right size, #30. I tried to locate a 3.18mm drill bit local, found a local source for metric bits but the closest they had was 3.3mm. Next stop was the LHS to make sure they stocked the pinion gear so in case I ruined mine I would be able to replace it. When I returned home I drilled the pinion out with my # 30 drill bit on the drill press without damaging it and installed it, re-programmed my throttle and pitch curves back to stock and has seen the temps on the motor drop about 20 degrees after an 8 minute flight, I am happier with that.
While I was at the LHS, I asked if they would be interested in trading me the new stock 420 motor that HH is kindly replacing under warranty for the slightly more powerful 440 4400Kv motor, we made a deal, so I will swap it out when I receive the new one form HH and the LHS gets the 440 instock. In the mean time I will get a few more flights in with the Turnigy 2836 motor.
Nick, when you replaced your motor with the 440 did you make any other changes?
jb
FYI: I was inspecting and lubing the tail assemble last night and caught a pin moving out on one of the slider arms, just a heads up, guys and gals.
Old Aug 30, 2011, 12:24 PM
Joined May 2011
I didn't change a thing, installation couldn't have been simpler; not even any need to re-program the ESC. I do use carbon fiber main and tail blades and I removed the flybar weights, but I had already done all that before I got the motor.
The 440 gives the heli a significant extra bit of pop, yet doesn't decrease flight time much at all.
Old Aug 30, 2011, 04:47 PM
JIMBAKER is offline
JIMBAKER's Avatar
Oregon
Joined Jan 2009
Nick,
I am fairly new to Helis, just started in May this year, what effect does removing the fly-bar weights have?
jb
Old Aug 30, 2011, 07:42 PM
Joined May 2011
Moving the weights closer to the rotor head or removing them completely makes the cyclic response a little more aggressive. It's not something you would want to do as a beginner, they're there in the first place for added stability. It's for fine-tuning 3D performance basically.
Old Aug 30, 2011, 08:51 PM
Joined Mar 2011
3 good flights today. What a nice Heli! Just learning the ropes, flying some circutis. SO much easier to fly than the SR. Night and day. Handles a little wind pretty well also. Good job Horizon Hobby.
Old Aug 30, 2011, 10:22 PM
JIMBAKER is offline
JIMBAKER's Avatar
Oregon
Joined Jan 2009
Nick,
I figured that it would be the same as cutting the flybars down on my mSR that went to my son the first of this month. I may or may not play around with moving them just yet.
Originally Posted by JIMBAKER View Post
Nick,
jb
New Product Blade 450 3D RTF/BNF! DFflyer Mini Helis 63 Apr 08, 2013 06:26 PM
New Product New Blade 450 3D choppersrule Electric Heli Talk 0 Feb 03, 2011 10:08 PM
Wanted WTT Blade MSR BNF plus cash for a 450, 250, or Blade 400 RX ready jedi391 Aircraft - Electric - Helis (FS/W) 1 Jan 08, 2011 12:13 PM
Discussion Blade 400 3D and E-Revo, or T-Rex 450 SE V2... heliaddict22 Off-road Cars 2 Oct 22, 2008 10:51 PM
Discussion TREX 450 or EFlite Blade 400 3D or Belt CP carbon? emiliomuno Mini Helis 7 Oct 02, 2008 07:22 PM
