Feb 12, 2013, 03:37 PM
United States, CO, Denver
Joined Dec 2012
So I accidently ordered the 5/32 size Durbo nose gear instead of the 3/32. Whoops. I did get the pre-bent one as well. Also, I went with the 3'' wheels due to the grass I land on. I didnt think it would work because the nose gear is too long. But I didnt want to re-bend and cut it so I just modified the firewall a bit to accomadate it, lol.
The spring portion is up in the cowl, I'll get a better picture of it next time. But as for how it works, its GREAT. I can actually taxi and steer through that grass you see. The nose is still a bit longer then the main gear, as you can see the tail is almost on the ground (especially in the grass). But it also helps with limiting prop strikes. Take-offs and landings have been really smooth actually. If it was asphalt or concrete it would probably drag the tail too much and cause some scraping.
I've been getting better at landings, so with practice and some larger wheels its been a bit of a good combination.
PS: thats my original cowl, epoxied a few times. I didnt run a spinner cap that day, the nut holds it anyways. And I hate trying to take it off without break it.
