Old Jan 23, 2013, 06:12 PM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Originally Posted by MrMention View Post
This is my Cessna as it sits today. I decided to changed the front landing gear with a shock absorbing strut. I had it in my tool box from another plane I had crashed ages ago.
I have a 5mm motor shaft screwed into the strut so it should provide enough strength to prevent the front gear from bending. I also decided to double up the front wheels with 2 inch dubro low bounce. I have 2.5 inch wheels on the back.
I like it. Nice & beefy.
Any issues with the prop hitting the ground with smaller tires in front?
wjb111 is offline Find More Posts by wjb111
Old Jan 23, 2013, 06:19 PM
MrMention is offline
Find More Posts by MrMention
Joined Sep 2012
Originally Posted by apriliamgt View Post
great vid do you find flaps help landing?
Thanks. Flaps help for a steeper decent but they are not necessary, especially flying into the wind. I usually jut cut the power and let it float down. Its one of the easiest planes I have landed.
No issues with the prop clearance. I have the front raised up a little, but these wheels are bigger than the stock ones so they already raise the plane up a little
MrMention is offline Find More Posts by MrMention
Old Jan 24, 2013, 08:31 AM
Donnyd21 is offline
Find More Posts by Donnyd21
United States, OK, Oklahoma City
Joined May 2012
Anyone know where I can find the part that connects the 2 rods on the nose landing gear together? Its a metal rod that has holes in either end with 2 allen screws to connect the landing gear to the steering input, I lost my allen screw and have no steering now
Donnyd21 is offline Find More Posts by Donnyd21
Old Jan 24, 2013, 08:52 AM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
You'd probably have to purchase spare landing gear. Check rc-castle.com, probably take a long time on shipping but they seem to have a lot of parts always in stock for FMS 1400mm Cessna 182.
I replaced my front landing gear with a Dubro 1/2A Steerable Nose Gear, and 2" Dubro wheels.
http://www3.towerhobbies.com/cgi-bin...P?I=LXD845&P=8
bhoov128 is offline Find More Posts by bhoov128
Old Jan 24, 2013, 01:29 PM
Donnyd21 is offline
Joined May 2012
^I have that SNG already but running that alone would make the stance off on the plane (2 3/4" wheels), the extender I need made the stance perfect and it looks like the landing gear set does not include the peice I need.
Old Jan 24, 2013, 01:55 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
I just bent the nose gear axle at the right height to align with the rest of the wheels. The stance is fine. It was a bear to get installed and attached to the control rod though.
Old Jan 26, 2013, 11:57 AM
apriliamgt is offline
Find More Posts by apriliamgt
Joined Dec 2012
in the FMS cessna 182 MK2 . Im using a 2200mah 3s lipo. Can I go any bigger for longer flying times? and any lipo suggestion
apriliamgt is offline Find More Posts by apriliamgt
Old Jan 26, 2013, 12:32 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
I have flown mine with 3300 3 cell no problem.
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Jan 26, 2013, 03:02 PM
GrandpaInFlorida is offline
Find More Posts by GrandpaInFlorida
United States, FL, Floral City
Joined Dec 2012
The front connector did not come with the landing gear set I got...at least the FMS version. RC Castle has it for $5. In a pinch it wouldn't be hard to make one out of 1/4" aluminum rod or whatever the diameter is.
http://rc-castle.com/shop/product_in...oducts_id=2764
GrandpaInFlorida is offline Find More Posts by GrandpaInFlorida
Old Jan 26, 2013, 03:04 PM
Donnyd21 is offline
Joined May 2012
Thats what I need, got it on order, thanks!
Old Jan 26, 2013, 03:24 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
I decided to use the floats on This frozen grass since it doesn't snow in Chicago...works quite well
JDMJim is offline Find More Posts by JDMJim
Old Jan 26, 2013, 10:42 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
I use 3300 and 4000 mAh but my cg is sketchy but that's probably just me being a bonehead about the situation.
Old Jan 28, 2013, 03:53 PM
Joined Dec 2012
Added some bigger wheels on the cessna for better grass landings.
Old Jan 30, 2013, 03:07 PM
tdford is offline
Find More Posts by tdford
Comin' in HOT!
tdford's Avatar
United States, CO
Joined Dec 2012
aprilla, nice pics again. I found them here in the states (towerhobby had everything) and got them ordered. Let us know if you ever get good weather how those wheels work in grass.
Looks like from some posts above, that a 3000-3300mah lipo pack should fit. This FMS v2 cessna has a huge compartment. I was able to barely squeze a 5000mah 2s in just for fun. I need to get some measurements in mm though.
tdford is offline Find More Posts by tdford
Old Jan 30, 2013, 03:27 PM
Joined Dec 2012
3000mah lipos are not widely available in the UK. hopefully weather changes soon.
Looking at getting the FMS T28 as my next plane
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 819 Aug 06, 2016 07:24 PM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 17 Jul 31, 2016 08:57 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
