Old Dec 02, 2012, 01:19 PM
Donnyd21 is offline
Find More Posts by Donnyd21
United States, OK, Oklahoma City
Joined May 2012
I use 5 min epoxy and after hard landings and several crashes it still holds great.
Donnyd21 is offline Find More Posts by Donnyd21
Old Dec 02, 2012, 02:43 PM
MrMention is offline
Find More Posts by MrMention
Joined Sep 2012
The supplied glue is fine for the tail, but I use gorilla glue for the wing struts
MrMention is offline Find More Posts by MrMention
Old Dec 02, 2012, 03:02 PM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Welders Adhesive worked fine for me........
wjb111 is offline Find More Posts by wjb111
Old Dec 02, 2012, 03:19 PM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Whatever you guys do, DO NOT USE the SUPPLIED GLUE for the Strut Attachment Points! I used 5-minute Epoxy!!!
PittSpecial is online now Find More Posts by PittSpecial
Old Dec 02, 2012, 06:02 PM
Eagle854 is offline
Find More Posts by Eagle854
United States, GA, Warner Robins
Joined Dec 2010
Arnav
I ordered some motor shafts for my motor but I have never changed them before. Can you please explain to me how to remove and replace the motor shafts.
Thanks.
Eagle54
Eagle854 is offline Find More Posts by Eagle854
Old Dec 02, 2012, 08:45 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
I've had good luck with this glue on foam. It sticks really well, but remains flexible.
Wintr is offline Find More Posts by Wintr
Old Dec 03, 2012, 09:39 AM
Donnyd21 is offline
Joined May 2012
Been there done that, I am glad I used the supplied glue for the rudder/elevator cause if I had used the 5 min epoxy I would have never got it off the other day when I broke them
Thanks.
Eagle54
Simple, there are 3 allen bolts on the shaft, I had to dremel a slot in my orig one and use a screw driver cause I stripped them all out the 1st time I had to change it.
Old Dec 03, 2012, 11:35 AM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Thanks.
Eagle54
Here is what I told Eagle in a PM just in case it helps someone else:
This was sometime back so some steps may be missing. it goes along the lines of:
- There are two set screws that you need to remove from the top of the bell.
- There is a C clip connected to the back of the shaft that you need to remove
- Apply force to remove the shaft, by either pressing it against something, a rubber mallet, or a hammer (very gently so as not to bend it!).
- Put new shaft it.
- Close it the back with a collar
- Close the two set screws
- I remember I had to trim the shaft as it was a little too long. You can do so with a Dremel or s metal saw.
- You want to make sure the bell is connected firmly and cannot be pulled out
- Put some thread lock on the screws or check them often just in case they get lose from vibrations.
That's about it. At your own risk... Good luck...
arnav is offline Find More Posts by arnav
Old Dec 03, 2012, 06:02 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
I see that the Airfield Skytrainer is "archived" and I assume not available from Nitroplanes anymore. I bought mine from there a couple years ago, and it is still in mint condition. (has only flown once and sat in storage since as I have been away in the military) I may want to get another one, and I am wondering where to buy now? I have seen similar models on Bananahobby, but prefer not to deal with them.
-Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: Warning!! Graphic images of...
Old Dec 03, 2012, 11:40 PM
davidrd is offline
Find More Posts by davidrd
davidrd's Avatar
Portland, OR
Joined May 2010
Nitroplanes lost the contract with FMS and now Banana Hobby sells the Cessna. You can also get it from SN Hobbies in Canada. I think Killerplanes also sells it as well
davidrd is offline Find More Posts by davidrd
Old Dec 03, 2012, 11:49 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
-Cub
If you do not want to deal with the USA Distributor and it seems like it is Banana Hobbies then, I would deal with Philip from PW-RC dot com.
Just E-Mail his and tell him that you would like to buy a complete Model. It seems like it is a Dynam model as there are parts being sold by PW-RC dot com.
http://www.pw-rc.com/product_info.php/products_id/2359
http://www.pw-rc.com/product_info.php/products_id/2354
http://www.pw-rc.com/product_info.php/products_id/2373
http://www.pw-rc.com/product_info.php/products_id/2356
http://www.pw-rc.com/product_info.php/products_id/2355
http://www.pw-rc.com/product_info.php/products_id/2443
Old Dec 04, 2012, 12:13 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
It looks like you may have the older 4CH version like I do. AFAIK, you can't get it anywhere anymore (including BH) and parts are pretty much non-existent as well (other than NP and their outrage shipping to the east coast). Your best bet is to get the newer 6CH version (with the flaps), which is sold (or at least used to) in a bunch of places such as:
http://www.snhobbies.com/product_inf...6fec29ebfdf7ae
http://www.hobby-paradise.com/en/en/...r_id=42&page=6
http://rc-castle.com/shop/index.php?cPath=154_153_169
http://www.pw-rc.com/index.php/cPath...45f033c1cc6607
http://www.toysonics.com/fms/?catid=258
http://www.bananahobby.com/electric-...pare-part.html
Old Dec 04, 2012, 06:12 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
This is the version that I have. Like I said..mine is in mint condition, I just may want an additional one. http://www.nitroplanes.com/93a300-14...-blue-arf.html
-Cub
Old Dec 04, 2012, 06:14 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
Oh so that is the new version. Yes, you can buy it in a bunch of places.
Old Dec 04, 2012, 08:31 PM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
Are there any ski or floats for this plane? Thanks in advance.
cmaynex is offline Find More Posts by cmaynex
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 803 Today 10:25 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
