Old Nov 09, 2012, 11:43 AM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
I fly mine for 6 minutes on a 2200 and put back between 1500 and 1700 after a flight. This allows me time for a go around or two if I need to.
The only problem I have had with mine, and it seems a common one, is the nose gear is a bit weak. I replaced mine with a Dubro piece and have flown happily ever since. I also removed the wheel skirts, but just because the plane I modeled doesn't have them. It handles our grass runway just fine.
In fact, I had it up around 1000 feet yesterday. It is a really good flying plane.
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Nov 09, 2012, 02:16 PM
MrMention is offline
Find More Posts by MrMention
Joined Sep 2012
Thanks for the info. I have couple FMS warbirds so I know this will definitely fly well based of the others that I have flown.
I will change the front gear and add some super bright leds inplace of the stock ones
MrMention is offline Find More Posts by MrMention
Old Nov 09, 2012, 04:22 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
I would not bother at first. My experience with my Sky Trainer 55 inch is a very robust Nose Wheel Strut even though it "is" not spring loaded to absorb hard landings. If you can tighten the set screw that keeps the strut from turning on its own then, it will be okay, IMO.
I have posted numerous postings of my Ugly Landing on tall grass and at a high rate of speed that the nose gear (Strut) caught and resulted with the model to completely flip upside down.
The Strut was bent very badly and I almost changed it out with the Dubro type that has been recommended here, however, I had some time one lazy evening and disassembled the entire Nose Wheel Assembly and took the Nose Wheel Strut in my hands and carefully bent it back in shape in order to slide back in the plastic parts (tight Tolerance).
It is your choice but, IMO, there is no need for changing out things right off the gate.
PittSpecial is offline Find More Posts by PittSpecial
Old Nov 09, 2012, 07:48 PM
Joined Sep 2012
Thanks. I already have a couple spring loaded struts that I used on my Dynam SR22. If the wire can fit then I will definitely change it. BTW I'll be flying off asphalt
Old Nov 10, 2012, 11:46 AM
ledpole is offline
Find More Posts by ledpole
ledpole
United States, NJ, West Deptford
Joined Jan 2012
new plane for me, correct COG?
I got one of these at a swap meet, looked pretty cool. However have no manual and wondering where the COG. I cannot find the center of gravity or manual online. can anyone with a manual tell me where it is located. I was looking under FMS Sky Trainer & couldn't find anything & somebody turned me on the this site.
ledpole is offline Find More Posts by ledpole
Old Nov 10, 2012, 12:51 PM
Joined Sep 2012
Its 60mm from the leading edge
Old Nov 10, 2012, 04:05 PM
ledpole is offline
ledpole
Joined Jan 2012
great, thanks
Leon
Old Nov 10, 2012, 05:39 PM
jasturkey is offline
Find More Posts by jasturkey
United States, WI
Joined Dec 2009
NJ!! Are you flyn off the water in the streets!? I know linemen and mechanics that are out there tryn to get the power back on for you guys.
jasturkey is offline Find More Posts by jasturkey
Old Nov 10, 2012, 10:22 PM
ledpole is offline
ledpole
Joined Jan 2012
I'm good, if if there was an eye of the hurricane we got it . 50 miles west of AC. if it had come up Delaware bay would have been different story. I lucked out. Thanks.
Old Nov 11, 2012, 08:10 AM
United States, WI
Joined Dec 2009
Good to hear. It's a mess out there!
Old Nov 11, 2012, 08:23 PM
Donnyd21 is offline
Find More Posts by Donnyd21
United States, OK, Oklahoma City
Joined May 2012
I just ordered one of these plane from BH and I'm really excited. Its the N9258 blue version. I've got 2 Turnigy Nanotech 2650 25C battery that I plan on using. What amount of flight time should I be expecting with these batteries.
Also is there anything that needs to fix or improve before I fly this bird?
I get about ~9mins on my 2650 BUT I fly very slow at about 45% throttle on calm days, once my low battery buzzer goes off (at 11.5V) I will usually do a quick full throttle climb then land it. When I fly aggressively (rare) on the 2650 I get about 5 mins on it.
Donnyd21 is offline Find More Posts by Donnyd21
Old Nov 12, 2012, 01:07 AM
Scooch is offline
Find More Posts by Scooch
Scooch's Avatar
United States, NJ, Jackson
Joined Nov 2011
I disagree with this statement. The front gear is a known weakness in this plane. I think it is the first thing that needs to be changed. The fix is quick, simple, and cheap. Switch it out and save yourself the aggravation of having a day of flying ruined because of bent gear. Another reason to change the front gear to the spring loaded dubro is that the spring will absorb some of the impact, lessening the stress on the firewall.
Scooch is offline Find More Posts by Scooch
Old Nov 12, 2012, 06:12 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Well, I guess we agree to disagree because I did buy two Dubro's and I will have a spare for my Sky Trainer in the future and another one for another project.
The FACT that I was able to bend it back with just two (2) pliers says to me that they were expecting people land rough or catch something on landing and again my model landed pretty hard and completely flipped upside down with nothing more than a bent front nose wheel strut. This stock strut exhibited easy fix by bending it back and was able to align it correctly to allow the end pin to slide through the plastic parts again without the need for any machine shop assistance or precision tools.
You can be dissatisfied with this end of the model, okay, but, it is my opinion that the stock Frontal Nose Wheel Strut is pretty good for what it is and there is no need to go off and replace it initially right out of the box.
Pitt
Old Nov 12, 2012, 10:07 AM
jondon69 is offline
Find More Posts by jondon69
johnd
1 Stoplight town East of Lansing, MI
Joined Aug 2006
FWIW, I've bent my nose strut back to original as well... by hand, in the field.
I actually looked at the DuBro set-up at my LHS, and thought it looked awful heavy...
jondon69 is offline Find More Posts by jondon69
Old Nov 12, 2012, 10:49 AM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
It;s not that heavy, if anything the cessna could use a little nose weight. It flies a little tail heavy in the stock config. The Dubro is a proven mod that beefs up the front end considerably. If you land on asphalt of a nice grass runway and actually land the plane instead of chop the throttle and hope for a smooth and perfect glide in I'm sure the stock setup will last for awhile. Eventually it will break with repeated bending back. I've seen Dubro modded front gear break due to having to bend it back into position a number of times.
The great thing is we can all choose what we want to run on our own planes.
crucial is offline Find More Posts by crucial
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 790 Apr 28, 2016 05:04 PM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
