Old Oct 30, 2012, 06:35 PM
a320jockey is offline
Find More Posts by a320jockey
a320jockey's Avatar
Ecuador, Pichincha, Quito
Joined Aug 2002
Originally Posted by donaldlo View Post
Hi Carlos,
I have attached a picture of the items that you will get in the window set; hope this help.
Donald
Hi Donald, many thanks for the info. This is exactly what I am looking for. Sorry for having responded so late, lots of work!!
Cheers,
Carlos
UIO
a320jockey is offline Find More Posts by a320jockey
Old Oct 31, 2012, 07:50 PM
jasturkey is offline
Find More Posts by jasturkey
United States, WI
Joined Dec 2009
Originally Posted by jacob006a View Post
I recently bought the FMS skytrainer it came with the twin blade propeller and the large nose spinner. I would like to remove the spinner but cannot figure out how to remove the large circular piece that is behind the propeller.
I want to upgrade the front nose wheel steering as I flew it for the first time today and already locked up the nose wheel and rudder servo. We were able to fly it using just the ailerons for turning.
Any advice on how to remove the large plate behind the propeller as I have to remove the Cowling to replace the nose gear with something more suitable and heavy-duty.
That plate behind the prop should just pull off with your thumb at the end of the prop shaft and 2 fingers behind the plate (if you are refering to the stock setup).
jasturkey is offline Find More Posts by jasturkey
Old Oct 31, 2012, 07:54 PM
United States, WI
Joined Dec 2009
Originally Posted by btown2 View Post
What would you guys recommend for the control throws? currently I am using 100% and 65% of Full throw as my duals, but I would bet that my 65% is still even way too much.
You are gonna have to figure out what works for you. The set up on this bird seems to vary alot between pilots. I personally don't use any low rates on mine. I run 100% on all my surfaces.
Old Nov 02, 2012, 10:25 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
I got my 4ch Cessna out after having to let it sit for nearly a month of high winds. My landings were still dead on light as a feather...yay!
JDMJim is offline Find More Posts by JDMJim
Old Nov 03, 2012, 07:09 AM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Stock NOSE Wheel Repairs holding up GREAT!
Hi Guys!
My Sky Trainer is still taking off and landing with great results after two solid months after I repaired the front Nose Wheel Gear and yes, it still have the rip on top where the plastic pant cover meets the strut.
Can believe that I was able to bend that stock Strut back into it's original shape and not need to modify anything!
http://www.rcgroups.com/forums/showp...postcount=3396
This is a very robust model and I get lots of compliments when I land it!
PittSpecial is online now Find More Posts by PittSpecial
Old Nov 03, 2012, 04:49 PM
Donnyd21 is offline
Find More Posts by Donnyd21
United States, OK, Oklahoma City
Joined May 2012
Guys I have not been on here in a while, havent had time to fly until recently, had about 10 great flights in the last week. I am sure it has been talked about but could I run this battery/will it fit? -
http://www.hobbypartz.com/77p-sl3300...-hardcase.html
Donnyd21 is offline Find More Posts by Donnyd21
Old Nov 03, 2012, 06:17 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
It is a little too big.
Old Nov 03, 2012, 07:48 PM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
My dad has flown his with a 3300 but it wasn't a hard case. Measure the battery bay and see if it will fit.
crucial is offline Find More Posts by crucial
Old Nov 04, 2012, 07:16 PM
Donnyd21 is offline
Joined May 2012
Can you get me the brand or part number on it?
Old Nov 05, 2012, 09:04 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jul 2011
It's chilly here in WV, but it was way too pretty not to get out and fly a bit. As usual, this plane made me look good;-)
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Nov 06, 2012, 07:52 PM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Jim
Jim,
Looks like a great day in WV. Your flying season has to be somewhat longer than here in Michigan.
Cool pics. Looking like a nice landing.
Good Luck
Bill B.
wjb111 is offline Find More Posts by wjb111
Old Nov 08, 2012, 07:49 PM
JDMJim is offline
JDMJim's Avatar
Joined Jul 2011
Not so sure about that now....-anyways, does anyone want to part with their front strut and wheel skirt from a 4ch version?
Old Nov 08, 2012, 08:16 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Hum, seems like you have the bend a itish on that front nose wheel strut, huh?
I took a pair of pliers and carefully bend my back into shape and all else is history!
Pitt
Old Nov 08, 2012, 08:41 PM
WVrailfan's Avatar
Joined Jul 2011
Originally Posted by wjb111 View Post
Jim,
Good Luck
Bill B.
I fly all winter as long as the wind is calm. I have a Cub with skies and one on floats and fly them both off of snow. I hope to get some video this winter.
I may look at getting some skies for the Cessna.
Jim
Old Nov 09, 2012, 11:33 AM
MrMention is offline
Find More Posts by MrMention
Joined Sep 2012
I just ordered one of these plane from BH and I'm really excited. Its the N9258 blue version. I've got 2 Turnigy Nanotech 2650 25C battery that I plan on using. What amount of flight time should I be expecting with these batteries.
Also is there anything that needs to fix or improve before I fly this bird?
MrMention is offline Find More Posts by MrMention
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 785 Nov 23, 2015 11:16 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 05:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 10:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 06:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 06:15 PM
