Old Oct 11, 2012, 06:53 PM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
Jondon I am with you. When I discovered it fit in my car without taking off the wings, I was a happy camper. I usually take this plane and my Grim Reaper from CTH, plus a few smaller planes when I fly.
cmaynex is offline Find More Posts by cmaynex
Old Oct 18, 2012, 10:08 PM
svtdoug is offline
Find More Posts by svtdoug
United States, WA, Gig Harbor
Joined Oct 2009
I am looking at this FMS 55" Cessna - but have a question. Do you know the difference between the G-Kemy version at BH (currently out of stock) - http://www.bananahobby.com/sky-train...5362-prd1.html
and the N9258 version at BH - http://www.bananahobby.com/sky-train...1350-prd1.html
They seem to have the same specs and price. Any advantage to either, or differences other than decals?
Thanks!
svtdoug is offline Find More Posts by svtdoug
Old Oct 18, 2012, 10:14 PM
davidrd is offline
Find More Posts by davidrd
davidrd's Avatar
Portland, OR
Joined May 2010
Same plane, different markings. I have the blue G-KEMY 55 inch version purchased earlier this year. I like having N numbers on my models but the N9258 version color scheme seems kinda busy and takes some of the sleek looks away from the airplane. Just my opinion. It flies awesome
davidrd is offline Find More Posts by davidrd
Old Oct 19, 2012, 12:02 AM
Scooch is offline
Find More Posts by Scooch
Scooch's Avatar
United States, NJ, Jackson
Joined Nov 2011
Thanks!
I love the pic on BH of the plane upside down on the grass. Mine has looked liked that a couple of times
Scooch is offline Find More Posts by Scooch
Old Oct 19, 2012, 06:04 AM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Hi guys!
I have been flying the Tar out of my 182 and yesterday was super calm and flew two flights with mixed throttle. In the first 4 minutes it was fast passes and hammer heads, inverted flight, and slow scale rolls.
The reminder (another 4 minutes) of the flight it was super slow with Flaps and those lights at the super early morning just made it stand out and everyone was asking questions!
I just Love this model!!!
PittSpecial is offline Find More Posts by PittSpecial
Old Oct 19, 2012, 07:49 AM
jondon69 is offline
Find More Posts by jondon69
johnd
1 Stoplight town East of Lansing, MI
Joined Aug 2006
Sigh, I need to get my new prop on the plane. Also, on my previously posted video, if you look and listen closely, you hear the motor cutting out and see an obvious lack of control... I just ordered a 40amp esc, so hopefully that will be the solution!
Has anyone put this bird on floats yet? Is the float kit for the 182 Skywagon too big?
jondon69 is offline Find More Posts by jondon69
Old Oct 19, 2012, 08:41 AM
Davey NY is offline
Find More Posts by Davey NY
Ya gotta land eventually...
Davey NY's Avatar
United States, NY, Mahopac
Joined Sep 2010
This plane will cutout with less than 40 amps. Stock prop and motor setup can WOT as high as 37amps, so its a time bomb.
Also, make sure your throttle is calibrated on you Tx..that can cause pulsing as well at WOT
David
Davey NY is offline Find More Posts by Davey NY
Old Oct 19, 2012, 09:49 AM
jondon69 is offline
johnd
Joined Aug 2006
Thanks for the tips -- I rarely run at WOT -- only take off up and climbout to about 20 or 30 feet, then throttle right back. Then I usually idle along at half or so. I will be glad to stop worrying about it though... might even try some aerobatics now if I know I can run it flat out without cutouts or bursting into flames :-)))
Old Oct 19, 2012, 09:58 AM
btown2 is offline
Find More Posts by btown2
United States, IN, Bloomington
Joined Sep 2012
Hey guys... I have the Nitro Planes Aeroksy version of this model (G-KEMY). I am having horrible problems with the nose gear bending to hell and this is after switching out the stock for a Dubro 1/2 A. The problem inherently is that our field is grass and the extra drag on the wheel from the grass is enough to bend it during landing. Does anyone have a good landing gear set up for grass?
btown2 is offline Find More Posts by btown2
Old Oct 19, 2012, 10:09 AM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Check the attachments in this thread and the post they are pointing to, Myself and Ace and others are using the "it can tow a car" du-bro 5/32 heavy duty NG (cat #152).
arnav is offline Find More Posts by arnav
Old Oct 19, 2012, 10:10 AM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
how tall is the grass at your field, Unless it is really tall i think you need to work on your landings. The Dubro setup will stand up to grass just fine if you are landing on the mains first.
crucial is offline Find More Posts by crucial
Old Oct 19, 2012, 10:13 AM
arnav is offline
arnav's Avatar
Joined Nov 2011
+1. This for me was back when I was learning. I was coming in hot and fast (even dead stick). If you bend the du-bro 1/2A you probably need to work on your landings. Read this first, I suspect you will find the du-bro 1/2A is just fine..
Old Oct 19, 2012, 10:15 AM
jondon69 is offline
johnd
Joined Aug 2006
I know I need to work on MY landings :-))) I've straightened that dang nose gear enough times that I think it's gonna snap next time I do! Of course my runway's a country road, which has its plusses and minuses too I guess!
Old Oct 19, 2012, 10:17 AM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I've witnessed the nose gear snapping after being bent back a number of times. Not on MY plane of course.
Old Oct 19, 2012, 10:59 AM
Davey NY is offline
Davey NY's Avatar
Joined Sep 2010
Common misconception: whether you run at WOT or not the ESC does not care. The ESC "pulses" full amps to the motor. So for example, if you run at 1/4 throttle, it means your ESC will pulse the motor more rapidly than say, at half throttle.
Picture you manually blipping your throttle to vary your speed..this is what the ESC does at nano-second speed.
So, whatever you run at a static WOT test (removing minute variables, ,such as prop unloading when you are actually airborne- the load decreases 10-15%) this is what is passing thru your ESC.
This plane needs minumum of 40amp ESC .
Hope I kinda explained this well...
David
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 819 Aug 06, 2016 07:24 PM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 17 Jul 31, 2016 08:57 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
