Old Oct 01, 2012, 02:26 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Thanks. I managed to find one here. It's for a friend so I won't be replacing the motor for him
http://rc-castle.com/shop/product_in...roducts_id=846
FlyWW1 is offline Find More Posts by FlyWW1
Old Oct 02, 2012, 06:12 AM
Davey NY is offline
Find More Posts by Davey NY
Ya gotta land eventually...
Davey NY's Avatar
United States, NY, Mahopac
Joined Sep 2010
Just replace it with a nice HK motor..the plane will become your favorite flyer.
TherESC needs to be upgraded too...FYI
David
Davey NY is offline Find More Posts by Davey NY
Old Oct 02, 2012, 06:47 AM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
I agree. Its not worth chasing for parts or even worst waiting for them. headsuprc have good budget motors with plenty of replacement parts (shafts, bearing, retainer clips, thrust washers, etc'). People seems to have good luck with the epbuddy motors and the hobbypartz ones as well, but I do like how headsuprc have all the parts I have mentioned readily available.
arnav is offline Find More Posts by arnav
Old Oct 07, 2012, 04:59 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
It was a little more breezy than I like, but my Cessna handled it like a pro. I got two flights with decent landing today. I even got a couple of neat photos, playing with a camera mounted on the rear stab.
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Oct 07, 2012, 05:41 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
Nice!
Old Oct 08, 2012, 08:21 AM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Hi Guys!
Glad you all are having fun with your 182's
So, it has been almost 3 weeks since my beloved 182 landed in tall grass and flipped over causing the nose wheel strut to bend and break the cover at the top stem area. Why? Because like a dummy, I decided to use a tired battery, perhaps the oldest of my battery lot and worse, decided to fly low and slow with Flaps deployed and I forgot to initiate the flight timer. I was transfixed with how well the model flew so slow and realistic. Then, I decided to throttle up a bit and was ready to bring up the flaps and at the instant I did throttle up the motor reduced RPMs worse (Battery crapped on me).
I looked for replacement and no one had them so, I waited.....I went ahead and purchased the Dubro 234 item for replacing the entire nose wheel strut with the coiled up loop and perhaps make it better etc...
I finally broke down and carefully removed the snap on chrome plastic spinner and nut, propeller and then, the super easy magnet secured cowling. The steering piece had popped out from the keeper and reason why I had to disassemble the entire frontal nose area to get it back in the keeper as tiny screw driver set was not going to allow.
The Metal Strut piece was very bent so, I carefully took two pliers and holding the fat bottom side of the metal strut, I slowly bent back the skinny portion of the strut so, it can go in the keeper (FUSE) and success!!!
I tightened up the securing screw so, the strut does no free wheel and made sure it turned with the rudder, success!
I re-assembled everything and like to make note that the threads of the cheap propeller adapter is perhaps the last time I will be able to tighten as those threads seemed to be already worn!!
The model flew on Saturday morning with great success and wonder as it was dead calm and early enough that you can see the Lights!!!
I was able to screw back the side covers as best as I could and not bothering to glue the rip on the left side for good luck against any further issues and bad landings or worse bad decisions!
A few pictures!
That Rip is staying!!
PittSpecial is online now Find More Posts by PittSpecial
Old Oct 09, 2012, 10:26 PM
WVrailfan's Avatar
Joined Jun 2011
Took my 182 up for a ride just about sunset today. I velcroed a keyfob cam to the horizontal stab.
Learned a couple of things. The camera is sensitive to vibration, especially under 1/2 throttle. At 1/2 and above it is pretty smooth. These little cameras are not the best image makers, but they are a lot of fun for the price. Another thing I learned is, I really need to clean the finger prints and smudges off of my plane. When the Sun hits the side of the plane it looks like crap.
Nothing like a cool fall evening in WV for some RC flying.
Jim
Fall sunset flight near Upper Falls WV (9 min 7 sec)
Old Oct 10, 2012, 09:04 AM
minivation is offline
Find More Posts by minivation
Professional tree finder
minivation's Avatar
United States, TX, Longview
Joined Dec 2010
I finally went ahead with you guys' recommendations for flaps on my Skylane.
Story and pictures are on my blog (sorry).
http://www.rcgroups.com/forums/showthread.php?t=1748918
minivation is offline Find More Posts by minivation
Old Oct 10, 2012, 09:26 AM
jondon69 is offline
Find More Posts by jondon69
johnd
1 Stoplight town East of Lansing, MI
Joined Aug 2006
That's awesome. I love the camera placement. So did you cover your plane with some sort of film covering or is that painted? I have one keychain cam vid I've taken on the Cessna. I mounted the camera top of the wing in the center. I think maybe you got less vibration back on the stabilizer. I'll try to post mine now :-)
jondon69 is offline Find More Posts by jondon69
Old Oct 10, 2012, 10:46 AM
WVrailfan's Avatar
Joined Jun 2011
Thanks. Part of the vibration issue is that is an older prop and it needs balanced again. Also I've learned, the further you mount a cam from the center mass of the plane the more vibration you have.
My Cessna is covered with Oracal vinyl film. It adds about 200 grams to the plane, but it looks good and protects the foam in minor mishaps. This is the 5th foam plane I have covered and I am very happy with the results.
Jim
Old Oct 10, 2012, 01:25 PM
jondon69 is offline
johnd
Joined Aug 2006
I've gotten a new prop since this video too... but I will still try with the cam at the tail. I covered a GWS Beaver and it looked great. I do want to change the scheme on mine, will do eventually!
First Aerial Video Flight aboard 55" Cessna Electric RC plane (3 min 8 sec)
Okay, why do I just see the embed code? There must be a trick to this... anybody?
Old Oct 10, 2012, 02:01 PM
WVrailfan's Avatar
Joined Jun 2011
<iframe src="http://player.vimeo.com/video/51147342" width="500" height="333" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/51147342">First Aerial Video Flight aboard 55" Cessna Electric RC plane</a> from <a href="http://vimeo.com/user14002139">John Donohoe</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
Nice roomy place you have to fly there.
Try just copying the address for the video in the "insert link" box at the top of this message box. All you need is the address that you see when you click on your video, should look like this http://player. vimeo. com/video/51147342 without spaces. ( I originally typed it without spaces and it posted your video;-))
Jim
Old Oct 10, 2012, 06:21 PM
jondon69 is offline
johnd
Joined Aug 2006
Perfecto! Thanks! Now I definitely have to do some fall color video!
Old Oct 10, 2012, 08:27 PM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
I absolutely love this plane. I fly this plane whenever I go out and it fits in my coupe without taking the wings off. Man I had no idea how nice it flies and with the flaps on take off or landings, brilliant. Slow flying is a blast with the flaps on it is so steady. I crashed the plane in a freakish accident at the soccer field but the only thing that broke was the dubros landing gear and mount. I was flying and I looked away for a second because I thought I saw a hawk above me and when I looked back at the plane it was coming straight for the batting cage I fly next to. Landed on top of the cage but pulled up so minimal damage. I replaced with dubro's 3/4 or 5/8 I forgot but it is solid now. Thanks for listening to me ramble.
cmaynex is offline Find More Posts by cmaynex
Old Oct 11, 2012, 08:19 AM
jondon69 is offline
johnd
Joined Aug 2006
I have to laugh, you say it fits in your coupe... I drive a Mini Cooper Clubman (the sightly longer version of the new Mini) and it just barely fits -- but it does! I just need to be sure I don't buy any bigger planes! I hate taking wings on and off. I mostly fly at lunch breaks and between work meetings so need to be ready to fly at a moment's notice :-)
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 790 Apr 28, 2016 05:04 PM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
