Old Aug 27, 2012, 05:17 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
All these places used to carry parts for this Plane:
http://www.snhobbies.com/product_inf...6fec29ebfdf7ae
http://www.hobby-paradise.com/en/en/...r_id=42&page=6
http://rc-castle.com/shop/index.php?cPath=154_153_169
http://www.pw-rc.com/index.php/cPath...45f033c1cc6607
http://www.toysonics.com/fms/?catid=258
http://www.bananahobby.com/electric-...pare-part.html
http://www.nitroplanes.com/aircgltrr.html
I haven't visited some of them in a while. With the recent FMS distribution woes, some may no longer carry FMS parts (e.g. Philip and rc-castle ) or at least about to stop.
Why not switch to a 2 blade prop from LHS?
arnav is offline Find More Posts by arnav
Old Aug 27, 2012, 08:24 PM
jondon69 is offline
Find More Posts by jondon69
johnd
1 Stoplight town East of Lansing, MI
Joined Aug 2006
Ha, few there that I hadn't found... I really like three blade look... what would be the equivalent 2 blade prop for replacing the 3 blade 11 x 9?
jondon69 is offline Find More Posts by jondon69
Old Aug 27, 2012, 08:57 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
Start at 12x6, 12x7 and go up from there if you want something more aggressive. I am using a 12x10, but to be honest there is probably no reason to have such a high pitch prop on this plane.
Old Aug 28, 2012, 11:36 AM
arnav is offline
arnav's Avatar
Joined Nov 2011
Hurray, I successfully converted the stock 3536 motor to a collet style adapter
No more proprietary hex adapters! Now I can walk to my LHS and pick a prop adapter when I need one.
I tried two shafts from headsuprc. The first one actually fit better without any modification. However, it uses a C clip and I am C clip challenged. I could not get that clip on for the life of me until it finally lost shape. So I ended up using a longer shaft so I can close it in the back with a collar and I shaved about 3 4mm from it. I ran it on the bench and it works great. The bearings of the motor are surprisingly still in a good shape. Maybe now I will be motivated to fix my much neglected Cessna...
Old Aug 31, 2012, 09:37 PM
ny_hawk is offline
Find More Posts by ny_hawk
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
That would be a 12x9 which is what mine came with stock. I normally run a 12x8.. Running a much lower pitch means lowering the speed the plane is capable of and it means that much less headroom over stall speed.. You can run a large prop but run too low a pitch and you will not fly, not fly well or have to keep the throttle way up all the time.. Pitch means how fast you can fly and larger diameter of the prop means more thrust but they are also interrelated.
ny_hawk is offline Find More Posts by ny_hawk
Old Sep 03, 2012, 05:33 PM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Had my 9th flight today with my Cessna & my first crash. I'm rather cr@ppy on landings. I usually nose over as she lands. I believe due to a grass field at the club & of course my rookie skills or lack of. The last flight I tried to slow down more than usual & somewhat lower but hit the tall weeds before the runway. She did a couple cart wheels on the wing tips.
All in all it was rather amusing to see & the only damage is the rear stab got a little banged up. Some welders & she will be good to go.
ONE TOUGH BIRD !!!!!!!!!!!!!
Bill B.
wjb111 is offline Find More Posts by wjb111
Old Sep 03, 2012, 11:34 PM
minivation is offline
Find More Posts by minivation
Professional tree finder
minivation's Avatar
United States, TX, Longview
Joined Dec 2010
True, true, my Skylane tends to do the same thing - the plane tends to do weird things when I slow her down on short final. I was on short final on top of an asphalt runway when the plane suddenly slowed down, sank (maybe a gentle stall?) and hit the ground hard. A bit of maintenance had to be done on the landing gear assembly, but else than that, things looked good.
Now I come it slightly fast with a steeper glideslope - by the time I flare out the speed bleeds off and makes for a nice landing. Flight characteristics may differ depending on each plane, though.
minivation is offline Find More Posts by minivation
Old Sep 04, 2012, 01:19 AM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Do you have flaps?
If not they are easy to setup and she'll land like a dream with them.
Old Sep 04, 2012, 04:55 AM
minivation's Avatar
Joined Dec 2010
Mmm-mm...
No, I don't have flaps... But I do have a lot of servos lying around...
Old Sep 04, 2012, 06:02 AM
jondon69 is offline
johnd
Joined Aug 2006
Flaps are the whole reason I have this plane! BUT, if you get used to the nice slow landings with flaps, and then forget them once? Boy this thing rolls on! (I usually fly off a nice smooth road, but begin to see the advantage of a grass strip!)
Old Sep 04, 2012, 11:56 AM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Mmm-mm...
Very easy to add them, just follow the lines on the wing and cut carefully.. If if you need any info I think there is at least one video and probably a few posts on it...
She lands very slow and graceful with them...and should you want to add a camera or whatever additional equipment they help too--mine is way over weight and she needs them.
Old Sep 05, 2012, 01:50 AM
minivation's Avatar
Joined Dec 2010
Ooh - but adding flaps on my plane means it'll make the radio setup 5ch, which means I'll have to ditch the stock 2.4Ghz for my 72mHz Optic 6, but I don't have a spare receiver. BUT: I'm ordering one from AbellHobby (along with a replacement NiMH for the Optic 6) and I should get it by October-ish. Sorry for the random question, but anybody know anything about this vendor?
Old Sep 09, 2012, 06:30 AM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Stock nose wheel assembly without any spring action!
Hi guys!
Been a few weeks that I have not posted as been busy with new projects.
Took my wonderful Sky Trainer Cessna 182 for two super flights in rather calm conditions in my Central Florida RC Club. I was able to take-off and land amongst lots of miniature lakes around my field but, the artificial Asphalt Runway was dry!
Both flights were terrific and on the start of the 2nd Flight, I forgot to start my Countdown Timer and using an old tired Li-POLY Battery which did not help things I found my model put putting low and slow and when I noticed the battery dumping on me, it was too late and I allowed the model to land down wind and North of the landing strip which caused an Ugly nose landing gear hit and complete flip over. There was NO damage except the Nose Wheel Gear metal assembly got pretty bent and front wheel cover cracked at the top end where strut comes out.
I have been looking and looking for the freaking Nose Wheel assembly and every one wants lots of $$ and forcing you to buy the main gear assembly as well!
Instead of buying the same sorry BUTT assembly without any spring loaded bend, I am going to follow a few suggestions here and most especially going to install the Du-Bro 1/2A Nose Wheel Assembly, Part Number 234 as shown in this Video!!
Nitroplanes AirField Sky Trainer Landing Gear Modification (6 min 32 sec)
PittSpecial is online now Find More Posts by PittSpecial
Old Sep 15, 2012, 01:19 PM
C. Alan is offline
Find More Posts by C. Alan
Certified cat herder
United States, CA, Tehachapi
Joined Aug 2004
Would any one know where I could get a replacement battery hatch? I lost mine today over the field.
C. Alan
C. Alan is offline Find More Posts by C. Alan
Old Sep 15, 2012, 01:24 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
Nowhere, sorry... You would need to fabricate one from scratch, use velcro, or stretch a rubber band between two pins... I created one from ply and it looked and worked great (view attachments in the thread..).
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 790 Apr 28, 2016 05:04 PM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
