Old Aug 21, 2012, 02:10 PM
jondon69 is offline
Find More Posts by jondon69
johnd
1 Stoplight town East of Lansing, MI
Joined Aug 2006
Ahh, that's it -- the whole bearing is gone out of the back so the shaft has nothing to locate it... I'm tempted to just put in another similar spec motor as I expect parts for this are few and far between!
Thanks for the help!
jondon69 is offline Find More Posts by jondon69
Old Aug 21, 2012, 02:28 PM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I've replaced the bearings in mine once already so replacements are out there.
http://rcbearings.com/
http://www.headsuprc.com/servlet/the...NGS/Categories
If I remember right this is the rear bearing.
http://www.headsuprc.com/servlet/the...--4mm-x/Detail
crucial is offline Find More Posts by crucial
Old Aug 21, 2012, 02:35 PM
jondon69 is offline
johnd
Joined Aug 2006
hmm, you think even though I whacked the curb with it, popping in a new bearing will solve my problem? I kinda think there might be other issues?
Old Aug 21, 2012, 02:49 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I would definitely inspect the shaft for straightness and make sure the magnets are secured ok. I admit it's easier to order a new motor and not worry about it but I have a few bearings on hand that I can use to test things without ordering stuff. You could order a new motor and some bearings and if your old one runs ok you have a spare for not a lot of money. Headsuprc's shipping is $2 and is a great shop to buy from. I'm sure there is a suitable motor their to replace the stock one.
http://www.headsuprc.com/servlet/the...80-Plus/Detail
http://www.headsuprc.com/servlet/the...h-10%29/Detail
Both of these look similar to the stock motor in my plane. You might not be able to use the stock spinner but power wise they should be close.
Old Aug 21, 2012, 03:22 PM
jondon69 is offline
johnd
Joined Aug 2006
Yeah I looked at that second one already. Looks about right, but amp draw is a little high? And form what I've read, the esc's in these SkyTrainers are kinda iffy from the get-go.
Old Aug 21, 2012, 04:15 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I replaced the stock ESC right away. I saw one go up in flames and almost took out the plane. Ideally you would want an 850-900kv motor to match the stocker. The stock motor is like a bit of a hybrid. The motor mount holes are spaced out like a 450 class motor but the motor is sized like a 480 or power 10. This one looks like it might be adequate with a little less power than the bigger power 10.
Hobbyking motors
http://www.hobbyking.com/hobbyking/s...dProduct=18229
http://www.hobbyking.com/hobbyking/s...dProduct=14847
http://www.hobbyking.com/hobbyking/s...dProduct=14501 - accessory pack for NTM motor
Old Aug 21, 2012, 04:24 PM
jondon69 is offline
johnd
Joined Aug 2006
Wow, thanks for the research! Is there a recommended replacement prop for this plane? I do like the 3 blade very much, I see where the original is no unavailable.
Thanks again for the help!
Old Aug 21, 2012, 04:28 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I use the Parkzone BF-109 3 blade prop. It draws about 10 more amps than stock but I like the performance.
http://www.horizonhobby.com/products...09g-PKZ4901#t2
Old Aug 21, 2012, 04:51 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
I have a few shafts from headsuprc waiting downstairs in the mailbox in an attempt to convert the stock motor from the proprietary prop adapter to collet style. I'll let you all know how it goes...
arnav is offline Find More Posts by arnav
Old Aug 22, 2012, 09:45 AM
jondon69 is offline
johnd
Joined Aug 2006
Well, I like the idea of the different prop, but I guess I'll have to check and see if I can throw a different esc on there too... seems to me I have another one or two in my basement! Thanks again for the help.
When I get the new set-up in, I'll offer up the old one to anyone who thinks they can fix it :-)
Old Aug 22, 2012, 01:25 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I do have the bearings in a drawer here. I wouldn't mind taking a shot at getting it running.
Old Aug 24, 2012, 07:02 PM View Post
randyus
A moderator felt this post violated the following rule: Off Topic Advertisement. It is temporarily hidden while randyus edits it. Show it to me anyway.
Old Aug 24, 2012, 09:56 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
Looks neat but it costs more than the plane.
Old Aug 24, 2012, 10:52 PM
ny_hawk is offline
Find More Posts by ny_hawk
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Totally. Something best used with a serious scale project... The ST just doesn't need the extra weight, cost and current draw IMO.
ny_hawk is offline Find More Posts by ny_hawk
Old Aug 27, 2012, 03:45 PM
jondon69 is offline
johnd
Joined Aug 2006
Anybody have a reasonable source for a new prop for this plane?
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 785 Nov 23, 2015 11:16 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 05:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 10:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 06:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 06:15 PM
