Old Aug 11, 2012, 06:46 PM
ny_hawk is offline
Find More Posts by ny_hawk
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Originally Posted by wjb111 View Post
Jim,
Does it really pan? If so, what are the mechanics to function it?
I have the #808 key cam & just looking for some other options than using velcro somewhere on the plane. Looks like a slick setup.
Bill B.
Yes it really actually pans.. It is capable of panning 360 degrees but is presently setup to only do about 180..90 degrees left to 90 degrees right..
For such a simple function it took a lot of work really... I started modifying a servo to do continuous rotation with reverse, then added a variable resistor to slow it down...
The ping pong ball was cut in half...and one half drilled out for the lens and sanded. Then two halves cut for the boom to go inside.
The cam was mounted inside half the ball and fixed with some silicone..
Then the two halves joined with CA.. Cam wiring into the boom, not yet affixed.
The ball then mounted on the aluminum alloy boom, sealed and a small epoxy pour to hold it in place..
Outside of ball sanded smooth..
Made a bearing using a soda cap, epoxy and aluminum skin from old antenna.
Sizing and fitting done before hand.
Bearing epoxied into wing..
Servo mounted under bearing and fits into a servo arm end which was epoxied into bottom of boom..
The servo going directly into bottom of boom.
Servo controlled via 3 position switch on radio, left, stop, right.
Key cam is mounted on top of ball which has a hat on top, another shorter bottle cap epoxied on..providing a flat surface for the mount.. Tether used in case of mount failure.
Entire plane can be picked up and carried by the ball but it's not recommended... lol
Body work done to hide the scars..
If you need more info just ask..
I'll shoot a vid of the cam moving at some point soon..
Jim
ny_hawk is offline Find More Posts by ny_hawk
Old Aug 11, 2012, 07:29 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Wow thats well thought out! What did you need to do to make the servo continuously rotate?
What TINY cam did you use?
Thanks!
Alex
Alex Schauer is offline Find More Posts by Alex Schauer
Old Aug 11, 2012, 07:38 PM
RoryG is offline
Find More Posts by RoryG
The Shetland Flyer
RoryG's Avatar
United Kingdom, Scotland, Lerwick
Joined Jun 2008
Fun!
Cessna at the Knab (9 min 12 sec)
I love this plane
RoryG is offline Find More Posts by RoryG
Latest blog entry: Aith in Springtime
Old Aug 11, 2012, 07:52 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Thanks!
Alex
Well most servos want to continuously rotate except for the fact that there is a potentiometer that reports the position to the electronics and then there are normally little plastic stops that prevent the output shaft from turning past a certain point...
It was a while ago I did this so I may be a little fuzzy.. But I found a short cut over the methods I have seen online.. This involved simply using CA to lock the potentiometer at exactly the middle position according to the Rx.. So IOW you plug the servo in and get it centered... Then CA the pot to make it stay there...(a drop right on the mechanism seems to do the trick.) Then remove the stops that prevent turning... At first it will be tight because the pot is not turning however on my servos I found that with a little help while it is apart turning the shaft with a wheel by hand loosens it up so it turns freely although the pot does not move.. You have to be certain that: The pot is centered and cannot move and that you get no CA near anything else, then allow the CA to totally set before moving servo around. Then finally remove, file off the stops.
This cam is old now although still well regarded.. It's this one, in 12volt, but they make them even smaller these days...
http://www.123securityproducts.com/kpc-vsn500nhb.html
Old Aug 11, 2012, 07:58 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Guys,
Going to take out my STOCK Cessna 182 out for some more action at the Maiden Site with the large Concrete High School Band Practice surface! I will see about someone to record my Flight using my High Definition Digital Camera.
Happy landings!
Carlos
PittSpecial is offline Find More Posts by PittSpecial
Old Aug 11, 2012, 08:12 PM
WVrailfan is online now
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
Got in two flights this evening. I do like this plane!
Jim
WVrailfan is online now Find More Posts by WVrailfan
Old Aug 11, 2012, 08:22 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Jim
Great pics and very nice finish on that.... Was that paint or trim?
Jim
Old Aug 11, 2012, 08:29 PM
WVrailfan's Avatar
Joined Jun 2011
Jim
Thanks, a buddy took the photos for me.
The Cessna is covered with Oracal vinyl and Callie Graphics decals.
Jim
Old Aug 12, 2012, 02:48 AM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Here's a clip of the pod panning...
Icarus FPV Pong Cam (0 min 57 sec)
Old Aug 12, 2012, 05:55 AM
eagle1933 is offline
Find More Posts by eagle1933
Dallas USA, TX
Joined Jul 2010
I'm having trouble putting the wings on. The screw hole in one wing doesn't line up with the screw hole in the fuselage. Anyone else have this problem? How did you overcome it?
eagle1933 is offline Find More Posts by eagle1933
Old Aug 12, 2012, 01:46 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Some pics would help..
Which holes are not even, on the wings or on the fuse?
Generally the wings must be joined and then popped into the holes in front and pushed as far forward as possible.
Old Aug 12, 2012, 06:06 PM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
ny_hawk,
Thanks for the info & vid. Good stuff. I will have to try & put something similiar together.
Bill B.
wjb111 is offline Find More Posts by wjb111
Old Aug 12, 2012, 10:31 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
ny_hawk,
Bill B.
No problem Bill.. If I can help just PM me..
Jim
Old Aug 12, 2012, 11:01 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Yes, I had this problem and reported it a flew pages back.
What I did was to carefully hold the wing assembly halves together "while" holding the complete wing assembly down and applying pressure into the fuse holder.
You pretty much need another pair of hands.
Old Aug 13, 2012, 05:55 AM
Dallas USA, TX
Joined Jul 2010
Thanks Pitt. Got my wife to help and it all turned out okay.
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 803 Jun 25, 2016 10:25 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
