Old Jun 01, 2012, 08:30 AM
acesimmer is online now
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Anyone switching to a balsa model may want to try the Ultra Stick. I picked up an estate sale with a bunch of Balsa built aircraft. I converted the Ultra to electric in a couple of hours. Cut the gas tank bay top off and used for battery compartment. ESC on bottom nose outside for cooling. Dropped a 700KV motor in with a 12x8 prop. Needs a bigger prop. Set up Crow so that I can drop vertical into a landing from a hundred feet or so. Having a blast with this sucker.
acesimmer is online now Find More Posts by acesimmer
Old Jun 01, 2012, 08:53 AM
jasturkey is offline
Find More Posts by jasturkey
United States, WI
Joined Dec 2009
b.b.4. check your p.m.'s
jasturkey is offline Find More Posts by jasturkey
Old Jun 02, 2012, 12:24 PM
h2oman is offline
Find More Posts by h2oman
h2oman's Avatar
West Michigan
Joined Feb 2010
Originally Posted by b.b.4 View Post
Wolfe, Ace, Crucial and others,
On my 1st solo, I over controlled and shut it down , so I would not crash TOO badly. Prop shaft, cowl, bent rt. wing. All repaired now, but I don't want to repeat my mistakes. Mine is the AIRFIELD 182, all stock w/ a dx6i and ar6115e.
My question, WHAT trainer should I get to learn flying w/ ailerons.......
I fly the HZ CUB w/ no problem, and on my SIM flying the NEXSTAR, I have no problems w/ take offs or landings.
Any suggestion will be very much appreciated..................
b.b.4
I started with the HZ Super Cub and ended up putting ailerons on it. It flys pretty well, but I didn't flatten the wing, so I have to use a lot of rudder mix, which makes rolls a little wonky. If i had to pick a good aileron trainer, I would pick the AXN Floater from hobbyking (USA warehouse). I watch Bruce Simpson's YouTube videos a lot (Xjet and RCModelreviews), so I was convinced to buy the AXN Floater and I'm glad I did. It can fly and glide really slow and stable, but once the throws are turned up, it can really fly quite fast and sporty. The motor is on top of the fuse so little risk of breaking a prop, and it belly lands so no risk of bent/broken landing gear.
h2oman is offline Find More Posts by h2oman
Old Jun 02, 2012, 10:21 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
H20,
You might just want to dial down the throws on low rates to about 50% with about 30% expo - that should tame her down quite a bit.
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Jun 02, 2012, 10:30 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Arnav,
I would go to the bigger Edge from 3DHS
http://www.3dhobbyshop.com/48-Edge-5...e_p_15879.html
Should fly well set up just like the Mosa 2 and use the same batteries. It will be smoother than the smaller one
Wolfe
Old Jun 02, 2012, 10:31 PM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
The AXN sounds a lot like the Wild Hawk.
crucial is offline Find More Posts by crucial
Old Jun 02, 2012, 11:06 PM
h2oman is offline
h2oman's Avatar
West Michigan
Joined Feb 2010
Originally Posted by wolfewinde View Post
H20,
Wolfe
I like it fast and sporty (been flying it for a while). I was just trying to recommend a good aileron trainer for b.b.4... I fly my big FMS/Airfield P-51 or Skytrainer for my tame Sunday afternoon flying...
The AXN is similar to the Wild Hawk, Hawk Sky, Bixler, Easy Star, and other powered glider types. Other than the AXN, the only other powered glider type I've flown is the Dynam Hawk Sky, and I think the AXN flys slightly better (just my opinion of course). The plastic motor mount/housing on the Hawk Sky can develop some weird resonance sounds at different throttle ranges...
Cheers!
Old Jun 02, 2012, 11:24 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
ahhhh - my bad H2o
Wolfe
Old Jun 03, 2012, 07:41 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Wolfe, oh wow, I like the bigger version but now I am confused. Isn't the 47" Extra 300 SHP the other quintessential 3DHS first balsa airplane? Maybe Edge vs. Extra doesn't make much difference. Not sure.
arnav is offline Find More Posts by arnav
Old Jun 03, 2012, 08:35 PM
vhuang168 is offline
Find More Posts by vhuang168
United States, CA, Sunnyvale
Joined Mar 2011
The Extra is a little more precise but not as tumblely. The Edge is easier to stall and has a very stable stall envelop. The Slick sits nicely in the middle with an excellent mix of the 2. Draws nice lines but still able to do the majority of the Edge's repertoire with about similar ease.
This is not to say that the Extra will not 3d like an Edge, you just need to be more conscious of your stick inputs to have the same results. Just like the Edge needs more attention when you want to do a nice hammerhead or an even M with 1/4 up 1/4 down.
vhuang168 is offline Find More Posts by vhuang168
Old Jun 03, 2012, 10:56 PM
chuckman49 is offline
Find More Posts by chuckman49
OCD RC Freak
United States, CA, Riverside
Joined Aug 2011
Upgraded the prop to a 12x8, added a 40A ESC, and used a Dubro 1-1/2" spinner to put it all together.. Now I'm not afraid to go WOT!! Here is a quick vid...
Flyin 6_3_12 (7 min 30 sec)
chuckman49 is offline Find More Posts by chuckman49
Old Jun 04, 2012, 12:05 PM
crazybear is offline
Find More Posts by crazybear
crazybear's Avatar
Irvine, CA
Joined Oct 2001
Prop Strike
Hello,
This past weekend I had a prop strike while landing . I had a strong and gusty cross wind (close to 90 degrees). During the flare, I lost control and the nose dived into the runway. The prop was still spinning and one blade got bend and the other two just lost some top layer material (I have the stock 3-bladed propeller). Is there any way I can bend back the blade?
Thank you in advance for your help,
CrazyBear
crazybear is offline Find More Posts by crazybear
Old Jun 04, 2012, 12:14 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
You can bend and trim the tip a little. Just make sure you balance it afterwards. They should all be the same length too.
Old Jun 04, 2012, 02:48 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
my Cessna is back on dry ground...the lake I fly off is rather overgrown with seaweed and makes getting on and off the water from shore tricky....
JDMJim is offline Find More Posts by JDMJim
Old Jun 04, 2012, 10:46 PM
OCD RC Freak
Joined Aug 2011
I agree, just sand all the blades down so they are smooth and equal length and balance it for sure... It happened to me once and I just sanded all of them down so they were all the same and balanced it and didn't have any problems for many flights. I have recently upgraded to a 2 bladed 12x8 prop, if your ESC can handle the amp draw I highly recommend it.
---Chuck
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 803 Jun 25, 2016 10:25 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
