Old Mar 15, 2011, 08:45 PM
celm is offline
Find More Posts by celm
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
are the main wings easy to take off for transport?
celm is offline Find More Posts by celm
Old Mar 15, 2011, 08:50 PM
ny_hawk is offline
Find More Posts by ny_hawk
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Mine *just* fits nose down in the back of the car so I keep the wings on... To remove and attach the wing you need at a minimum to remove 4 screws, 2 on top and one on each of the wing supports... Kind of a pain but as I said I leave it on...but it's certainly not a big deal either way....
Did you order it?
ny_hawk is offline Find More Posts by ny_hawk
Old Mar 15, 2011, 09:04 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
Did you order it?
i just ordered it,what car do you transport the plane in?
sucks they dont do free shipping like there sister company hobby partz
Old Mar 15, 2011, 09:20 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Great, I am sure you will love it... If you can, do a box opening video post.. I am interested to see how well they protect the wing and fuse from dings...
It's my buddy's car, I forget the model, I can post it when I ask him... It's a medium sized car and the distance from inside rear door panel to panel is about 58-59 inches and from ceiling to floor slightly taller than the fuse so I put the spinner on the center of the floor, tail straight up and the landing gear holds the seat, works like a charm but just fits..if you have at least that much space it should work..
Jim
Old Mar 15, 2011, 09:24 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Still a great deal IMO... A plane of this quality with that much detail and durability RTF and sent to your door could cost much more and did until this thing appeared on the market...
Jim
Old Mar 15, 2011, 10:00 PM
Davedough is offline
Find More Posts by Davedough
Foam Fumbler
Davedough's Avatar
USA, AZ, Tolleson
Joined Dec 2010
I take my wings off everytime I put it in the back seat of my car. I drive a 2009 Mitsubishi Lancer, so its not exactly roomy. The wings are super easy to take off. 2 phillips on the top and 2 micro phillips that hold the wing struts on the bottom. Be VERY careful as those bottom screws like to strip and/or get lost. I've been trying to come up with some quick disconnect that is strong enough to take flight, but I haven't come up with anything yet.
I take off the wings because I dont have the room to fit it in the back of my car fully assembled. I CAN leave the wings together and put them in, but they only just fit and I got worried about the arm rests possibly bending the tips, so I just pull them apart. They're only together with the carbon fiber rod, so its not a difficult task at all.
Davedough is offline Find More Posts by Davedough
Old Mar 15, 2011, 10:51 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
I was going to do this too but since it fit in the car ready to go I put it on the back burner.. One way that I think would work although I may not end up doing this is to use snap on control rod clasps (the part that clips onto the servo arm), and connecting one to each wing support.. They are strong but can open and slip off when needed.
Oh for anyone interested my buddy has a Taurus..
Jim
Old Mar 15, 2011, 11:03 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
this is my first plane,im a heli guy. i swore i saw someone at the field have some kind hand carrier that the fuse was there and the 2 wings there also.anyone know what im rambling about?
Old Mar 15, 2011, 11:21 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
He may simply transport it that way but it's not a standard... Too much assembly for me...
Do you have any plane stick time? Much easier than CP heli but you can crash if you are not careful... Get plenty of sim time and be aware of how you need to fly her, don't over bank; get some altitude; learn to keep her in a pattern; learn where you need to be on the field and where you need to start your decent for landing etc.. This plane can go fast so don't let it get too far away to start....
Jim
Old Mar 15, 2011, 11:25 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
Jim
i have alot of sim time,on the sim i can take off and land,do torques,figure 8`s,knife edge,invert and stalls
Old Mar 15, 2011, 11:31 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Good on the sim time.. Just be calm, cautious, like you did with your heli to start..and expect the unexpected.. We don't want that pretty plane doing any unauthorized "landings"...
Set up the controls so they are the least sensitive and check the pitch of all surfaces for balance so minimal trim will be needed later..
It's also good if you can maiden her with an experienced fixed wing pilot there to help if needed.
Jim
Old Mar 15, 2011, 11:40 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
im going to have my friend build it with me and set it up and do maiden flight,i know he is capable of doing he just got his turbine certification.
Jim
Old Mar 15, 2011, 11:41 PM
Foam Fumbler
Davedough's Avatar
USA, AZ, Tolleson
Joined Dec 2010
One thing that helped me was a piece of advice I got here.... go higher than your initially comfortable with. I too came from helis and my natural instinct was to fly at about 25-50 feet.... I regularly keep this bird at over 100 feet to give myself plenty of correction and orientation room.
Old Mar 15, 2011, 11:48 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
The old saying was fly three mistakes high.. I prefer about 2.... Flying low is a no no for beginners unlike for helis...you need to take off with authority.. This plane is a little above a true trainer but if you can handle it as a beginner then it can still perform well as you get more advanced..
Just need to be sure you can see the plane clearly as the white foam can glare in the sun...
Jim
Old Mar 15, 2011, 11:57 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Another good tip I would offer new pilots is to look on youtube for your new plane and search for crashes.... Take a look at what most often caused the crash with your new plane.. Then avoid doing what they did... Let them crash for you... and you'll save yourself a lot of wasted time and money.
Jim
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 819 Aug 06, 2016 07:24 PM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 17 Jul 31, 2016 08:57 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
