Old May 15, 2012, 08:50 AM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Originally Posted by Davey NY View Post
I don't suppose I can delay my flaps that that with a DX6i huh?
David
No Idea, I only use Hitec Aurora 9. However, you can buy servo speed controllers or use digital servo and program the speed in.
acesimmer is offline Find More Posts by acesimmer
Old May 15, 2012, 10:08 AM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
No, need some sort of electronic device to slow the servo's.
JDMJim is offline Find More Posts by JDMJim
Old May 15, 2012, 10:17 AM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I run 9% on mine. I have a slow down feature on my radio but it isn't necessary. If you don't deploy the full flaps in higher winds or when going too fast it won't balloon too much. Another option would be to use a 3 position switch and set 2 flap positions. This would let you gradually deploy. Unfortunately the dx6i is lacking in this are as well. I think you would have to setup a mix using 2 different switches. Throw one for half flaps and the other for full.
crucial is offline Find More Posts by crucial
Old May 15, 2012, 10:22 AM
BrundleFlyBy is offline
Find More Posts by BrundleFlyBy
Never stop being a kid.
BrundleFlyBy's Avatar
United States, CO, Manitou Springs
Joined Jan 2012
I got this one:
Turnigy Servo Regulator
You also need a female-female servo cable to go between the Rx and the regulator.
BrundleFlyBy is offline Find More Posts by BrundleFlyBy
Old May 15, 2012, 01:25 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
To glue, or not to glue, that is a question.
The instruction don't indicate gluing the two wing halves together, they just show sliding the halves onto the support tube and then attaching to the fuse.
It seems like it would make for a stronger/stiffer wing if the halves were glued together before screwing to the fuse.
Any veterans here have insight or suggestions regarding gluing the wing halves together?
On another topic, anyone know of a source for the clear wing tip nav light covers?
Thanks for any help.
Jim B.
WVrailfan is offline Find More Posts by WVrailfan
Old May 15, 2012, 04:15 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I don't think gluing them together makes a bit of difference. I've never seen a problem with the wings separating. The strength comes from the spar in the wing and the screws in the wing hold it in place. If you want less flex in the wing I would replace the fiberglass spar with a carbon fiber tube.
I have seen the plastic parts that glue onto the leading edge of the wings that hold it in place rip off. I would check those out and maybe reinforce that section if it is questionable.
Old May 15, 2012, 04:38 PM
JDMJim is offline
JDMJim's Avatar
Joined Jul 2011
mine are glued together
Old May 15, 2012, 09:42 PM
WVrailfan's Avatar
Joined Jun 2011
I think Crucial is correct and the plane is sturdy enough with the wings attached with the screw. But, mostly for aesthetics, I glued them together and covered the seam.
Jim
Old May 16, 2012, 05:01 PM
WVrailfan's Avatar
Joined Jun 2011
N703CP is done
Well, I got it finished. Like most foam planes, it looks best from a few feet, but overall, I am happy with it. I hope to have it in the air tomorrow or Friday.
Thanks for the help and info guys.
Jim
Old May 16, 2012, 05:31 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Looks good
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old May 16, 2012, 06:10 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Nice!
Alex Schauer is offline Find More Posts by Alex Schauer
Old May 16, 2012, 08:25 PM
Donnyd21 is offline
Find More Posts by Donnyd21
United States, OK, Oklahoma City
Joined May 2012
It was a good flying day today but I lost my battery cover, anyone know where to get another one?
Donnyd21 is offline Find More Posts by Donnyd21
Old May 16, 2012, 10:10 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
A piece of thin plywood, or plastic sheet, from you LHS, and some way to attach it, is probably your solution. Don't forget air holes.
Or, you could just secure you battery with a strap, and not worry about it. I use a Velcro strap, passed through the cockpit, with something to reinforce the floor where the strap passes over it.
Wintr is offline Find More Posts by Wintr
Old May 17, 2012, 06:40 AM
Davey NY is offline
Find More Posts by Davey NY
Ya gotta land eventually...
Davey NY's Avatar
United States, NY, Mahopac
Joined Sep 2010
Thanks guys.
I did set up 2 mixes on my DX6i but still balloons even at half. I just need to mix in some down is all.
nice paint job!
David
Davey NY is offline Find More Posts by Davey NY
Old May 19, 2012, 07:00 AM
MaladroitFL is offline
Find More Posts by MaladroitFL
Flyin' low & slow T-28s!
MaladroitFL's Avatar
United States, FL, Vero Beach
Joined Feb 2011
Wow! As we'd say in New England: That paint job is "wicked nice!"
Flaps?
I experimented with 10, 15 and 20% down elevator mixes and found that 15% is perfect (for me). There's no up or down movement now when I deploy flaps.
No wind....Got the planes loaded...it's Saturday... I am outa here!
Mac
MaladroitFL is offline Find More Posts by MaladroitFL
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 803 Jun 25, 2016 10:25 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
