Old May 01, 2012, 07:40 PM
sdjb is offline
Find More Posts by sdjb
sdjb's Avatar
Apache Junction,Arizona
Joined Jul 2003
JDMJim, Try another ESC.you are right about dropping one of the power legs. I am pretty sure.
sdjb is offline Find More Posts by sdjb
Old May 01, 2012, 09:22 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
Im ordering a new ESC tomorrow for my Thunderbolt and the Cessna can have the 30amp out of it...
JDMJim is offline Find More Posts by JDMJim
Old May 01, 2012, 09:23 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Dont fry it!
Alex Schauer is offline Find More Posts by Alex Schauer
Old May 02, 2012, 09:19 AM
JDMJim is offline
JDMJim's Avatar
Joined Jul 2011
So far so good
Old May 02, 2012, 03:46 PM
Joined Feb 2011
VERY cool!!
Old May 02, 2012, 03:51 PM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
nice plane and as the person before me said very COOL!!!!
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old May 02, 2012, 04:33 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Nice to see someone else has the older 4CH version. I thought myself and SM were the only ones... It is increasingly difficult to get parts for this version tough. For example, I am no longer able to find a cowl for it anywhere (except NP) so my suggestion Jim is to be very careful with it....
arnav is offline Find More Posts by arnav
Old May 02, 2012, 06:18 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
Originally Posted by acesimmer View Post
Tail incidence could could have changed due to repairs. This happened to my Trojan after a near fatal write-off that I was able to repair. Everything looked fine until I powered up. Shot down the runway and she rotated by herself. I knew I was in trouble within a second. Wanted to climb vertical so tried to trim her out. Not enough trim left so had to fly like never before to get it back in one piece. Got home checked the incidence which was 6 deg positive on the tail. Heated the top fuse rear and bent over my knee. Before next flight I trimmed a little down prior to TO. Had to force the rotation and she wanted to nose down just a little. Trimmed a little up and she flew quite nice.
Wing to tail incidence can cause wicked seesaw effects and very difficult to trim out in flight. You could also have a twist in the tail horizontal stab. Also check lateral balance of wings. Is the motor thrust angle correct?
Thanks ACE as always for the insight. I wanted to do your response justice and verify everything before I responded back which took some time. In fact i actually had to look up what tail incidence is. Almost every single thing you mentioned was wrong on the Plane and I had to fix it. My post crash checklist consisted of things like CG, and making sure the controls are ok, but not the things that you mentioned. I guess I thought that merely having to re-attach the motor mount and painting it doesn't necessitate an "overhaul/tune-up" but at the end of the day it was a bad crash so a comprehensive check is required. In fact, it is probably sensible to check all these before each day of flying given the flexible nature of foam.
Issues I noticed based on your response:
- The right wing is pointing upwards whereas the horizontal stabilizer was twisted in the opposite direction CCW. I was able to mostly straighten it out but it is still not perfect. In the pic below you can clearly see the right wing is still pointing upwards slightly in relation to the left wing and stabilizer.
- The motor mount is at a 5 degrees. Is it suppose to be only 1 degree? The angle is not based on anything I have done. It is all provided by the motor mount. All the motor mounts I have used to date had a similar angle and most definitely greater than 1 so are they making them wrong?
- The down thrust angle is at 2.5 degrees. Too much?
- The lateral balance was wrong! It must have changed by the paint job. I am amazed how much weight the paint added. I used to have this thick screw in the back and the nose was still heavy. After paint it is tail heavy even without the screw. Granted I did use a lot of paint to try and make up for the awful looking foam i had.
- The CG was wrong as well (see pic below). I did test it originally using the "fingers" method but putting it on the stand as in the pic below i think shows it is too tail heavy, right? I have since added some weight upfront. The cowl SM sent me should help once it arrives.
- I still didn't find a good way to measure the tail incidence using the crude "instruments" I have here... Eye balling it seems to suggest it is slightly upwards. What should it be exactly on this Plane? 0 degrees?
Also worth mentioning:
- My nose is probably 1/4 to 1/2" shorter then stock given the various FW fixes.
- In the most recent fix I put the motor mount on a 1/4 ply patch so it makes up for the above somewhat.
Hopefully the above steps will help this wicked seesaw affect. I will give it another shot this weekend and lets see what happens.
Old May 02, 2012, 06:19 PM
MaladroitFL is offline
Find More Posts by MaladroitFL
Flyin' low & slow T-28s!
MaladroitFL's Avatar
United States, FL, Vero Beach
Joined Feb 2011
Thinking of doing a complete overhaul - cosmetically. I love painting my planes, and my poor ol' 182 is looking a lil' long-in-the-tooth lately.
BTW...anyone got a set of wing struts they aren't using? ($$) And the anchor pieces?
If you have any really great Cessna photos, why not post them and help me choose a new color scheme?
This thread's been slow, so I'd enjoy seeing some feedback.
Thanks!
Mac
MaladroitFL is offline Find More Posts by MaladroitFL
Old May 02, 2012, 06:33 PM
arnav is offline
arnav's Avatar
Joined Nov 2011
haha, funny timing. I just posted my new scheme (see previous post to yours). I can't take credit for it. This was the inspiration: http://grubbyfingersshop.com/index.p..._image&pID=100. it would look better with a cowl and of course I still need to add decals (I do have the G-KEMY ones but I figured I will put the AMA # instead).
Old May 02, 2012, 07:27 PM
b.b.4 is offline
Find More Posts by b.b.4
b.b.4
b.b.4's Avatar
United States, IL, Hoopeston
Joined Jan 2012
Arnav
I got a cowl and prop from Hobby-paradise last week. Go to FMS parts and 1.4mm, also RC castle has your parts, if 1.4.............b.b.4
b.b.4 is offline Find More Posts by b.b.4
Old May 02, 2012, 11:05 PM
JDMJim is offline
JDMJim's Avatar
Joined Jul 2011
I got everything fabbed up and epoxied...I need to fasten the setup to the struts.
Thanks for the concern guys. I am fairly easy on this plane...or all of mine for that matter.
I need to do a static test now in the water to see how well the floats are sealed....ESC ordered too
Old May 03, 2012, 05:32 AM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
heres a interesting scheme..
dazza44 is offline Find More Posts by dazza44
Old May 03, 2012, 05:35 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
and this one..
Old May 03, 2012, 06:34 AM
Joined Feb 2011
Wheredya get the floats?
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 790 Apr 28, 2016 05:04 PM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
