Old Apr 18, 2012, 10:30 PM
MooseHead13 is offline
Find More Posts by MooseHead13
MooseHead13
United States, IL, Darien
Joined Mar 2012
So what size batteries is everyone use I'm lookig to get some more I have 25c 2200mAh how big can I go any suggestion??
MooseHead13 is offline Find More Posts by MooseHead13
Old Apr 18, 2012, 10:40 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
2200 give a nice and easy 9 min flight with lots of reserve.
acesimmer is offline Find More Posts by acesimmer
Old Apr 19, 2012, 08:36 AM
stoopidmonkey is offline
Find More Posts by stoopidmonkey
Flight Risk AMA # 986105
stoopidmonkey's Avatar
United States, UT, Cedar City
Joined Oct 2011
I use sky lipo 3s 2200 30 and 40c batteries I have 2 of each from hobbypartz.com (the only thing I will buy from companies affiliated with nitroplanes). The 40c batteries last longer. From what I understand, the planes will accept up to 3S 3300MAH with no mods to the battery bay. The reason I use Sky Lipo is they have a metal plate on the front and back of the battery wich helps protect them in-case they get ejected during a crash. I have gotten 14 min flight times on the 30c batteries flying at 50% throttle, however I have hit LVC doing so. For safe fun flights I set my timers to 9 min.. Enjoy!
stoopidmonkey is offline Find More Posts by stoopidmonkey
Old Apr 19, 2012, 08:38 AM
Joined Oct 2011
Originally Posted by arnav View Post
I have been following this thread for a while and I am not aware of anyone who have moved it (i.e. flies with the CG either more forward/backwards). In addition, the Plane flies remarkably well even if it is extremely nose heavy.
+1 it is uncanny how well the plane flies with more nose weight.
Old Apr 19, 2012, 08:56 AM
RedLine19k is offline
Find More Posts by RedLine19k
United States, OH, Youngstown
Joined Nov 2004
I use Turnigy 3.3s but the leads exit the side of the battery, and fitting was a real hassle. It was a very tight fit and there was also some binding on the nosewheel pushrod.
I hollowed out a channel so the battery could sit "on edge" instead. No binding, much easier fit and cooling path. Just make sure the plastic notch at the front of the bay is smooth or far enough from battery not to cut, and use a strap or crossbar to keep the battery secure.
RedLine19k is offline Find More Posts by RedLine19k
Old Apr 19, 2012, 02:51 PM
arnav is online now
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Here is how a 3000mah one fit. RedLine is correct, i had to bore a small hole (1/4" to 1/2") to make room for the wires:
http://static.rcgroups.net/forums/attachments/3/8/5/6/6/9/a4600401-223-IMG_20120201_231150.jpg
To get appreciation of how much the wires are sticking out above and beyond the advertised specs see this pic (about 1/4" wider than the HK spec)
http://www.rcgroups.com/forums/attac...mentid=4585260
arnav is online now Find More Posts by arnav
Old Apr 19, 2012, 03:12 PM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
Arnav has the older version of the plane. The pics before his show how much more room the newer versions have.
crucial is offline Find More Posts by crucial
Old Apr 19, 2012, 03:20 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
Correct. good call. I wonder what are the measurements of the 6CH version are then. At least from both pics it seems like you can easily identify the older version from the new one (i.e. the new one seems to have grooves in it?).
Old Apr 19, 2012, 04:28 PM
sdjb is offline
Find More Posts by sdjb
sdjb's Avatar
Apache Junction,Arizona
Joined Jul 2003
Well I am ready to maiden mine. I got 332.4 watts@32.59 amps, with 11x7 APC prop, 11.1v 2200 mah 25C SkyLipo. The prop that came with my kit was messed up.
sdjb is offline Find More Posts by sdjb
Old Apr 19, 2012, 05:53 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
Good luck!
I have been making good progress on fixing mine. It is basically all done. I just need to put the electronics in. If there are no major surprises it should be ready for flying this weekend (minus a cowl - oh well). It is also going to look a little different next time you see it but I am not saying/showing more until i get a cowl and maybe some decals..
Instead of taking the easy way out, I actually used it to experiment with fixes I haven't made yet:
- I had Nylon hinges but instead decided to give CA hinges a try as I have never used these before. Assuming they hold (almost) as well as Nylon Hinges they are definitely a breeze to put in. Right now I have either CA or Nylon hinges all around. No more foam hinges for me...
- I implemented the wire mod for the elevator. It is nice to see the two halves moving equally now...
- I have a NIB Plane which I need to paint. I never painted EPO before so I figured better practice on this one first... My findings:
  • The quintessential HomeDepot rust-oleum primer and spray paint works great on this foam without melting it away.
  • The basic painters tape from HomeDepot pulled the primer and paint which I guess means the primer did not adhere well enough to the foam (granted they tell you it will take 5 days to dry on plastic). I am not sure if paint without primer would work any better. I still need to pull some tape away and I am scared...
  • Primer and paint would not make bad looking foam new again. it is almost as if you really want to spackle it first... I am not sure what you would use in this case. I found the hard way epoxy is a terrible filler...
Old Apr 19, 2012, 08:01 PM
sdjb is offline
sdjb's Avatar
Joined Jul 2003
arnav , Krylon H2O works real good on EPO, I have lots of luck with it, and I do not use primer.
Old Apr 19, 2012, 08:08 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
Yes, I used the krylon shortcuts spray before on the vertical stabilizer. I was just curious how the rust-o brand would work.
I am happy I used a primer. It did improve the look of the foam.
Old Apr 19, 2012, 11:11 PM
sdjb is offline
sdjb's Avatar
Joined Jul 2003
Well I have tired all kinds of paint on faom over the years and I have yet to find anything that will stick real well. There are some plastic skins out that you paint on, that are really light.
I have not tried them yet. I'll try and find the web page and post the link.
Old Apr 19, 2012, 11:28 PM
vhuang168 is offline
Find More Posts by vhuang168
United States, CA, Sunnyvale
Joined Mar 2011
Some other things to try:
lightly sand the surface to give the paint more surface to adhere to
give the surface a wipe down using a mild soap solution to remove any mold release used during manufacture
I usually follow the above 2 steps with a coating of wbpu before the actual paint.
Vincent
vhuang168 is offline Find More Posts by vhuang168
Old Apr 20, 2012, 12:05 AM
arnav is online now
arnav's Avatar
Joined Nov 2011
Yes I actually did sand but in some cases the foam developed this "hair" (if that makes sense). Do you know what I am talking about? It was happening even when I made sure to not over sand and when I tried different grits. Do you use a particular WBPU or will any do? How many coats do you apply?
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 790 Yesterday 05:04 PM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 15 May 20, 2011 05:13 PM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
