Old Mar 29, 2011, 12:55 AM
roger2525 is offline
Find More Posts by roger2525
United States, CA, Poway
Joined Oct 2006
Ward
Will that effect both axis? when I do a taper both are off 8 mms
roger2525 is offline Find More Posts by roger2525
Old Mar 29, 2011, 03:19 AM
gm.cnc is online now
Find More Posts by gm.cnc
gm.cnc's Avatar
France
Joined Feb 2006
Originally Posted by Ward Hagaman View Post
Roger, have you checked your Z offset very carefully? If you are a little off with that much taper, you would end up way off size. For example, for a right wing, if you are too far to the right it will cut small, if you are too far left you would cut big. You have to imagine where the wire or bow pivots from when you set up the marks on your table.
Also carefully checks the position of the foam block on the table.
Gilles
gm.cnc is online now Find More Posts by gm.cnc
Old Mar 29, 2011, 08:19 AM
Joined Oct 2006
Gilles
I am just using 50mm wide test blocks 20mm from each tower and 20mm from the wire. and thats my offset
Roger
Old Mar 29, 2011, 08:38 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Roger, it sure sounds like the Z axis offset isn't matching the placement of your foam block(s). Could you could post a pic of your setup?
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Mar 29, 2011, 08:46 AM
Joined Oct 2006
what do you mean by the Z axis offset.
Old Mar 29, 2011, 09:00 AM
San Diego
Joined Mar 2003
Sorry, I should have called it "root axis offset". That is how far the block is from the pivot point of your wire. If you are cutting a 2:1 taper, then if you are off in that measurement, then you will be under or over by that same amount.
Old Mar 31, 2011, 11:17 AM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
Percentage camber?
kcaldwel is offline Find More Posts by kcaldwel
Old Mar 31, 2011, 12:32 PM
gm.cnc's Avatar
France
Joined Feb 2006
Originally Posted by kcaldwel View Post
Gilles,
I've never noticed this before, and it may be just something strange with this airfoil I've been playing with, but the percentage camber that GMFC shows is very different than XFOIL/XFLR5/Profili shows. They all say it is 4.81% (same base program, so agreement is not surprising). GMFC says it is 3.789%.
When I calculate the percentage camber by hand, I get 4.81% too. I do notice that the chord line of this airfoil does not go through the actual farthest forward point, so maybe the real camber is lower?
Any ideas?
Kevin
I will have a look. Maybe there is a problem with the starting or end point.
Gilles
Old Apr 02, 2011, 03:24 PM
vol-haut is offline
Find More Posts by vol-haut
Michael K.
vol-haut's Avatar
Canada, ON, Burlington
Camber changes?
Why does the camber change when I input a different thickness at the tip than at the root? Try set to the tip thickness back to the same as the root and the camber back to zero...well its really messed up now.
vol-haut is offline Find More Posts by vol-haut
Old Apr 02, 2011, 03:48 PM
gm.cnc's Avatar
France
Joined Feb 2006
Hi,
This is a rectangle, not a real profile. That's the reason why thickness/camber does not work.
Gilles
Old Apr 02, 2011, 07:31 PM
vol-haut is offline
Michael K.
vol-haut's Avatar
Hi,
Gilles
OK, I was just surprised when the camber changed on its own when I changed the thickness. When I try the same with a real profile there are no surprises.
Old Apr 03, 2011, 05:56 PM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
Old Apr 04, 2011, 04:33 PM
vol-haut is offline
Michael K.
vol-haut's Avatar
Foam Cut
I guess that the Foam Cut utility is for blocking the foam to a usable size; raise the wire and cut down like a guillotine. Why does the program turn on the heat before raising the wire?
Old Apr 04, 2011, 04:38 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
...to make sure that the wire is hot before cutting. If the wire hasn't fully heated then it will drag through the foam.
wyowindworks is offline Find More Posts by wyowindworks
Old Apr 04, 2011, 07:30 PM
vol-haut is offline
Michael K.
vol-haut's Avatar
When I click the Raise button the wire heats up for 10 seconds, goes up at full speed, wire heat is off again until I click the Cut button then heats for 10 seconds and then goes down at the cut speed. It really doesn't make sense for the wire to heat when it raises nless it does this so you have a chance to wipe the wire clean.
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 12:24 PM
Discussion Foam works foam cutting software issue airmcn_3 The Builders Workshop 5 Aug 29, 2008 10:02 AM
CNC software for foam cutting KAMarks The Builders Workshop 0 Sep 15, 2002 08:20 PM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 10:08 PM
Foam cutting CNC software foam_man Foamies (Kits) 10 Sep 08, 2001 08:50 AM
