Old Apr 12, 2012, 12:47 AM
gm.cnc is offline
Find More Posts by gm.cnc
gm.cnc's Avatar
France
Joined Feb 2006
Originally Posted by Trellian View Post
Hi,
I have generated a .CUT file from a Profili wing Panel. I'm picking up problems with the wire almost stopping, normally at turnarounds (like on the leading edge, spars and lightening holes). The outer surface seems ok, except for the very point of the leading edge.
It slows down so much that there are huge voids in the foam, up to 5mm at times. Is there a way to solve this?
The reason that I'm using Profili Pro to generate the cut files is that it aligns the trailing edge with the Y axis so that I can fit the cut on the table. I can't do that in GMFC directly.
I notice that the Profili .CUT file contains only absolute coordinates:
T:0.270552 XG:453.130359 YG:70.903123 XD:452.460262 YD:74.908200
T:0.270436 XG:452.795886 YG:70.163969 XD:452.065756 YD:74.233953
T:0.270509 XG:452.443406 YG:69.432987 XD:451.663564 YD:73.565713
T:0.270498 XG:452.069726 YG:68.712649 XD:451.223326 YD:72.919815
whereas the cut files created by GMFC has mostly relative coordinates:
44 +XG -XD
// Upper surface cut, point 478
T:3.278628 XG:31.601722 YG:84.120001 XD:149.179987 YD:73.047776
// VXG:2514127197 VYG:1088652776 VXD:0 VYD:1092158354
127
127
127
19 +XG
127
69 +XD
127
58
19 +XG
127
127
127
11 +XD
7 +XG
127
127
127
19 +XG
127
62 +XD
127
etc.
Could this be causing the problem?
Any help would be appreciated!
Adrian
Dear Adrian,
The problem is not the format of the .cut files, but what is generated by profili.
If your wing has a lot of taper, the solution is often to cut it as two separate panels. Another solution is to rotate the wing. There is a utility for doing that on the CNCNET web site.
Gilles
gm.cnc is offline Find More Posts by gm.cnc
Old Apr 12, 2012, 01:12 AM
Trellian is offline
Find More Posts by Trellian
Joined Sep 2011
Hi Gilles,
Thank you! I'm not French though, can you tell me which utility that is, or where it is? I can't seem to find it,
Also, I'd like to understand better what Profili is putting out, so that I can perhaps get it to work. Can you give me a bit more detail about what is not working with Profili's output?
Many Thanks
Adrian
Trellian is offline Find More Posts by Trellian
Old Apr 12, 2012, 03:40 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Hi Gilles,
Try the delta utility from this page:
http://www.teaser.fr/~abrea/cncnet/l...es/utils.phtml
Many Thanks
Adrian
I have no idea of what profili is doing. A .cut file is just a set of absolute coordinates and the time to go from one point to the next one.
Gilles
Old Apr 12, 2012, 05:17 AM
Trellian is offline
Joined Sep 2011
Thank you very much Gilles! I looks like we might have the problem sorted out. I couldn't see any specific problem in the Profili file, but a dry run on a trial version of GMFC on another machine that is not connected to the network seems to be producing better results.
I will let you know if I can pin it down.
Many thanks for the help so far! I will be building my own cutter in the next few months, and will be using GMFC for sure.
Adrian
Old Apr 20, 2012, 04:18 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Gmfc v3.89.15
Hi All,
This version corrects a bug in panel splitting.
Gilles
Old Apr 21, 2012, 04:23 PM
danfield is offline
Find More Posts by danfield
Fossilator
danfield's Avatar
Fullerton, CA
Joined Nov 2004
Backordered no more, the wait is over for USA GMFC Foam Cutters. New Stock order of GGC v2 interfaces has arrived in Calif. I will be advising those on the waiting list as well.
Cost shipped to you in the USA via USPS is $ 110.00. It's all included, incoming & outgoing shipping, exchange rates, bank fees, paypal fees, proof of shipment fees, dang there are a lot of fees. :-)
I also have an optional accessory kit available $ 25.00 shipped with a GGCv2. See post # 553 for details. Required if you want the GGC and GMFC to control your heat. The GMFC Foam Libraries where you teach GMFC your table or multiple tables, bows, wire, heat percentage, speed, kerf as you go and learn is one of the best features. Then you only have to select which is being used and cut away taking the guess work and scrapping foam out of the mix.
Regards
Dan
danfield is offline Find More Posts by danfield
Old Apr 22, 2012, 11:02 PM
danfield is offline
Fossilator
danfield's Avatar
Fullerton, CA
Joined Nov 2004
Thought I would post a pic of the "Kit", I know I like to see pics.
GGCv2 on the left of course.
1 ea Backlit in Blue Large character 16x1 LCD
3 ea Toggle Switches
3 ea Push Buttons
3 ea LED's, Red, Yellow and Blue
1 ea Double ended for 2 ea 14 Pin Flat Ribbon connector. 18" Lg, you cut to length you need.
Regards
Dan
Update: Also now included.
1 ea 2K resistor - Needed if the Text is too bright.
2 ea 180 ohm 1/4 watt res. for the Yellow and Red LED's
1 ea 100 ohm 1/4 watt res. for the Clear LED, that is actually Blue
Old May 02, 2012, 02:11 PM
albe359 is offline
Find More Posts by albe359
Joined Jun 2009
hi im alberto from italy,is some years that i used gmfc and i love it,i have a lot of files,p51,p40,extra330,iecc i want know somebody who wants change files so we can cut different planes this is p 51a,i must finish..extra and f4u...
albe359 is offline Find More Posts by albe359
Old May 02, 2012, 09:00 PM
Kevin Matney is offline
Find More Posts by Kevin Matney
Kevin Matney's Avatar
United States, MI, Erie
Joined Mar 2000
.15
updated to the latest ver. And I get a error USB 4.
And the speeds are off from cutting with trimming and no trimming
Kevin Matney is offline Find More Posts by Kevin Matney
Old May 03, 2012, 03:25 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
It looks like there is a problem with the GGC V1. Anyone else having this problem?
Please send me the .cnc project and the .bd files of the table and foam so I can investigate where the problem is located.
Gilles
Old May 11, 2012, 10:17 PM
Mel Duval is offline
Find More Posts by Mel Duval
Missileer Extraordinaire
Mel Duval's Avatar
Joined Jun 2001
What is the status with the GCC V1? Is it OK? I would like to order one but want to get one that is the most current design....
Mel Duval is offline Find More Posts by Mel Duval
Old May 12, 2012, 12:31 AM
danfield is offline
Fossilator
danfield's Avatar
Fullerton, CA
Joined Nov 2004
Hi Mel
For USA customers I only have V2's in stock so it's not an issue. Gilles will figure out if there is a problem with the V1 and the latest update and fix it if need be.
See posts 576 & 577
Regards
Dan
Old May 12, 2012, 12:55 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Mel,
The GGC V1 is no longer sold and has been replaced by the GGC V2 which offers better performance. Check with Dan in the US and Copaero elsewhere.
Gilles
Old Jun 22, 2012, 10:00 AM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Differing Number of Points....
Hi All,
I'm trying to cut a fueslage section and have drawn the sections that I need. They both have the same number of points (160) and the same start point but I can't get them to cut because the software tells me I have a differing number of points. Any suggestions?
Thanks!
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Jun 22, 2012, 10:39 AM
EAC is offline
EAC
Find More Posts by EAC
EAC
Eureka Springs, AR
Joined Jan 2007
What format are the files in?
Originally Posted by jtprouty View Post
Hi All,
Thanks!
Jimmy
EAC is offline Find More Posts by EAC
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 12:24 PM
Discussion Foam works foam cutting software issue airmcn_3 The Builders Workshop 5 Aug 29, 2008 10:02 AM
CNC software for foam cutting KAMarks The Builders Workshop 0 Sep 15, 2002 08:20 PM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 10:08 PM
Foam cutting CNC software foam_man Foamies (Kits) 10 Sep 08, 2001 08:50 AM
