Old Feb 10, 2011, 02:22 PM
Martin@ul.ie is offline
Find More Posts by Martin@ul.ie
Ground-Attack!
Martin@ul.ie's Avatar
Spain
Joined Jan 2005
Originally Posted by gm.cnc View Post
BTW, have a look to my rafale in my blog http://blog.gmfcsoft.com/
and here : http://www.gmfcsoft.com/rafaleV2
It will give you an idea of the precision you can reach...
Gilles
Wow! I'd be afraid to fly it, but it does look amazing.
Thanks for your help.
Martin@ul.ie is offline Find More Posts by Martin@ul.ie
Old Feb 10, 2011, 02:30 PM
Ground-Attack!
Spain
Joined Jan 2005
Originally Posted by Ward Hagaman View Post
Martin, I'm not sure where you are located, but if you want to try dense(ish) expanded bead foam, you might be able to look for an architectural foam cutting service and purchase foam from them. Here in San Diego there is a place called Foamco that cuts columns, moldings and trim pieces for stucco or plastering. They have 8' by 8' by 20' pieces of 1, 2 and 3 pound/cubic foot foam that they will just slice off whatever size piece that you need.
Ward
Thanks Ward. I live in Spain (Just updated my location) You got me thinking... I see a lot of moulded foam used in buildings here. I'll keep a look out.
Old Feb 11, 2011, 02:42 AM
Ground-Attack!
Spain
Joined Jan 2005
Driver Conflict?
Me again!
I am considering saving up for GMFC pro, but I want to retain Mach3 on my desktop to control my milling.
Is there any conflict between the Mach3 and GMFC paralell drivers?
Can they co-exist successfully?
Will I need to get the USB Dongle?
Thanks in advance...
Martin
Old Feb 11, 2011, 03:15 AM
gm.cnc is offline
Find More Posts by gm.cnc
gm.cnc's Avatar
France
Joined Feb 2006
Originally Posted by Martin@ul.ie View Post
Me again!
Martin
Hi Martin,
There is probably a conflict between the drivers. Still I never tested this.
GMFC needs a timer on the parallel port. You can build one based on the schematics on my site.
The alternative is the GGC USB interface that has its own internal timer.
Gilles
gm.cnc is offline Find More Posts by gm.cnc
Old Feb 17, 2011, 03:53 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Version 3.88.5 is online
Hi All,
This version corrects few bug fixes:
- Motor timeout in the Zero dialog
- Panel selections in the project menu
Enjoy
Gilles
Old Feb 17, 2011, 07:49 PM
Mel Duval is offline
Find More Posts by Mel Duval
Missileer Extraordinaire
Mel Duval's Avatar
Joined Jun 2001
Giles,
Has there been any progress in adaping teh drivers for XP for GMFC PE?
thx,
Mel Duval
BTW, the GCC USB interface works great.....mhd
Mel Duval is offline Find More Posts by Mel Duval
Old Feb 18, 2011, 01:15 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Originally Posted by Mel Duval View Post
Giles,
thx,
Mel Duval
No, the reason is that this is a commercial choice. Also the PE version will not evolve anymore in term of features.
XP is supported by the LIGHT, PRO and EXPERT versions
Gilles
Old Feb 20, 2011, 09:21 AM
The End is offline
Find More Posts by The End
Terry Harner AREA-52
The End's Avatar
United States, AZ, Litchfield Park
Joined May 2007
Gmfc !!
Gilles, glad to see you here!
The End is offline Find More Posts by The End
Old Feb 21, 2011, 09:42 AM
kcaldwel is offline
Find More Posts by kcaldwel
The post-truth world
kcaldwel's Avatar
Joined Jan 2007
kcaldwel is offline Find More Posts by kcaldwel
Old Feb 21, 2011, 09:59 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Originally Posted by kcaldwel View Post
Finally, a solution to the foam waste problem:
http://www.blest.co.jp/seihin-english.html
Make it into oil! The 10k price tag is a bit high though.
Kevin
Do you mean that you are still wasting foam
Old Feb 21, 2011, 05:46 PM
BobB is offline
Find More Posts by BobB
Billings MT
Joined Jan 2002
GMFC and Mach3 on same computer
Hi Group,
I have run both with out driver problems on the same computer.
When I switch from one to the other I just change out the printer port cable.
I have been using a Atom mother board that has a printer port and have not had
any problems.
My driver boards are from Hobby CNC,
on the GMFC side I have the one with the timer.
Regards
Robert
BobB is offline Find More Posts by BobB
Old Feb 23, 2011, 04:38 AM
Ground-Attack!
Spain
Joined Jan 2005
That's encouraging Robert.
When the new power supply for the wire arrives, I'll try it too.
The Mach3 driver seems to load only when Mach3 is running...
I'll post how I get on later...
Old Mar 08, 2011, 04:41 PM
Kevin Matney is offline
Find More Posts by Kevin Matney
Kevin Matney's Avatar
United States, MI, Erie
Joined Mar 2000
Foam waste
Kevin
This is what I do.
Kevin Matney is offline Find More Posts by Kevin Matney
Old Mar 08, 2011, 04:52 PM
Ward Hagaman is online now
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Very impressive!
Ward Hagaman is online now Find More Posts by Ward Hagaman
Old Mar 09, 2011, 12:03 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Sweet. Packing material to boot! How are you powering the wires?
wyowindworks is offline Find More Posts by wyowindworks
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 12:24 PM
Discussion Foam works foam cutting software issue airmcn_3 The Builders Workshop 5 Aug 29, 2008 10:02 AM
CNC software for foam cutting KAMarks The Builders Workshop 0 Sep 15, 2002 08:20 PM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 10:08 PM
Foam cutting CNC software foam_man Foamies (Kits) 10 Sep 08, 2001 08:50 AM
