Old Feb 04, 2011, 04:49 AM
gm.cnc is offline
Find More Posts by gm.cnc
gm.cnc's Avatar
France
Joined Feb 2006
GMFC Foam cutting software
I am starting this thread to provide another forum to exchange about GMFC.
Gilles
http://www.gmfcsoft.com/
gm.cnc is offline Find More Posts by gm.cnc
Old Feb 04, 2011, 07:53 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Thanks, Gilles, I think that this forum is a much better tool than Yahoo.
Love my GMFC!
Ward
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Feb 04, 2011, 08:07 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Love my GMFC!
Ward
My pleasure
Gilles
Old Feb 04, 2011, 09:36 AM
BobB is offline
Find More Posts by BobB
Billings MT
Joined Jan 2002
Glad to see this happen!
Hi Gillies
Glad to see this Group come to life.
Bob in Billings MT
BobB is offline Find More Posts by BobB
Old Feb 05, 2011, 12:46 PM
Twinboom is offline
Find More Posts by Twinboom
Semper Fidelis...........
Twinboom's Avatar
Madagascar, Toamasina, Atsinanana
Joined Dec 2003
I wanted to post the first attachment!! Hope it brings back the warm fuzzies of your trip out here two years ago,
Doug Blackburn
P.S. Glad you had the time for us.
Twinboom is offline Find More Posts by Twinboom
Old Feb 05, 2011, 02:29 PM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Doug Blackburn
I am glad to see that you still have these pictures... This was definitely a fun trip
Note that with the GGC interface and the EXPERT version, you can have limit switches...
Hope to see you soon,
Gilles
Old Feb 05, 2011, 07:48 PM
roger2525 is offline
Find More Posts by roger2525
United States, CA, Poway
Joined Oct 2006
Doug Blackburn
Doug
I dont think he will forget about the ball bearings
roger2525 is offline Find More Posts by roger2525
Old Feb 10, 2011, 05:02 AM
Martin@ul.ie is offline
Find More Posts by Martin@ul.ie
Ground-Attack!
Martin@ul.ie's Avatar
Spain
Joined Jan 2005
Foam gets the Bends
I guess this is a good place to ask....
I have just started cutting with my CNC machine
I put the foam on the table and started cutting. The foam did not move, so I guess I was cutting with Radiant heat. After a little while, the foam started groaning and sprang out of shape, but did not move on the table.
I attach a picture.
I did some searching and I understand that I need to put a LOT of weight on top of the foam.
What else can I do? When I cut manually, this never happened.
Martin@ul.ie is offline Find More Posts by Martin@ul.ie
Old Feb 10, 2011, 06:04 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
I attach a picture.
There are internal tensions in extruded foam. When you cut it, they are released and the foam may change shape. This highly depends on the foam itself and the way it was built. Depending on the provider, you may more or less this problem.
One way to solve this is to cut a small slice on the top and bottom.
Personally, I don't cut anymore extruded foam because of this and I prefer dense expanded polystyrene.
Gilles
Old Feb 10, 2011, 07:22 AM
Ground-Attack!
Spain
Joined Jan 2005
Bendy foam
Thanks Gilles.
Will get a different foam to try the next time I go to the hardware store.
I tried slowing down by 25% and lowered the rene wire power by about 20%.
I put a LOT of weight on top.
Result was almost acceptable.
Strangely, when the cut was finished the block stayed flat. Looks like the heat allows the forces accumulated to distort the foam.
I will also try removing the top/bottom 3mm and see what happens...
Is there a particular brand of foam you use? Do you weigh it down?
Martin
Old Feb 10, 2011, 07:35 AM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
HI Martin,
Echoe-ing what Gilles said, when you cut extruded foam, I usually cut it to 5mm off the top, flip it over and then 5mm again off the top. This takes most of the stress out of the foam. That is why you do it in the first place to get rid of the stress. Aftyer you have shaved both sides a bitm when you cut your airfoils, it does not react that way as much, but still may pop up a bit. Practice with some scrap foam on smaller pieces so you don't waste your sheet size foam. Small slice on both sides, then cut it down to siz, then cut your airfoil. Nice looking table. What slides did you use?
Doug Blackburn
Old Feb 10, 2011, 08:00 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Thanks Gilles.
Martin
I don't have a particular brand. I am using white expanded polystyrene which is specifically made for foam cutting. Unfortunately, I don't know the provider, since it was given to me.
Gilles
Old Feb 10, 2011, 08:03 AM
gm.cnc is offline
gm.cnc's Avatar
France
Joined Feb 2006
Gilles
BTW, have a look to my rafale in my blog http://blog.gmfcsoft.com/
and here : http://www.gmfcsoft.com/rafaleV2
It will give you an idea of the precision you can reach...
Gilles
Old Feb 10, 2011, 08:19 AM
San Diego
Joined Mar 2003
Thanks Gilles.
Martin
Martin, I'm not sure where you are located, but if you want to try dense(ish) expanded bead foam, you might be able to look for an architectural foam cutting service and purchase foam from them. Here in San Diego there is a place called Foamco that cuts columns, moldings and trim pieces for stucco or plastering. They have 8' by 8' by 20' pieces of 1, 2 and 3 pound/cubic foot foam that they will just slice off whatever size piece that you need.
Ward
Old Feb 10, 2011, 02:18 PM
Ground-Attack!
Spain
Joined Jan 2005
HI Martin,
Doug Blackburn
Thanks, I'll try that.
The slides are Bosch Rexroth.
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 12:24 PM
Discussion Foam works foam cutting software issue airmcn_3 The Builders Workshop 5 Aug 29, 2008 10:02 AM
CNC software for foam cutting KAMarks The Builders Workshop 0 Sep 15, 2002 08:20 PM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 10:08 PM
Foam cutting CNC software foam_man Foamies (Kits) 10 Sep 08, 2001 08:50 AM
