Old Feb 03, 2011, 06:05 PM
doubleduce is offline
Find More Posts by doubleduce
USA, CA, San Anselmo
Joined May 2003
Flight Times on 2200mAh
Trying to figure out flight times on my stock parkzone birds. I use Turnigy 2200mAh 3S 25C Lipo Pack on all my ParkZone planes. Corsair, Mustang BL, Wildcat, and T-28. I have my timer on my DX6i set at 6 minutes and land at that time. Can anyone tell me from experience how much flight time you are getting with the above setup? I realize there are many variables but just trying to find an average.
Am I conservative with 6 minute flights?
Also what the best way to field check a battery to see how much juice is in the battery packs?
doubleduce is offline Find More Posts by doubleduce
Old Feb 03, 2011, 06:15 PM
Stuart Warne is online now
Find More Posts by Stuart Warne
Durafly Brand Manager
Stuart Warne's Avatar
Hong Kong, Hong Kong Island, Central And Western District
Joined May 2001
I used long max tripples 2300 3s 25C in my old Trojan, I'd usually get 10-12mins of mixed throttle flying or 7-8min flying at mostly full throttle. But with the Multiplex Funcub, I can get up to 20mins, although the majority of that is at less than 1/2 throttle.
It just depends on your flying style. You could always go up to say a 3000mah, after a little bit of surgery to the battery bay. The models will take the extra weight. Just check your CG first, and maybe save the bigger packs for the windy days when the model will benefit from the extra weight in the air.
This is a great gadget to have at the field and when charging at home IMO, I wouldn't be without mine:
http://www.f1hobbies.com/shop.php?id=1505&level=
or something similar from HK, though this is only for lipo's:
http://www.hobbyking.com/hobbyking/s...dProduct=10328
S.
Stuart Warne is online now Find More Posts by Stuart Warne
Site Sponsor
Old Feb 03, 2011, 06:37 PM
BRUTUS2238 is offline
Find More Posts by BRUTUS2238
Huge member!
BRUTUS2238's Avatar
Pawtucket R.I.
Joined May 2008
I get 10 min from my F4F with an 1800 mah 3s 20 C batt. I fly scale ,no more than 60% throttle.Theres plenty of juice left after 10 min.Brutus
BRUTUS2238 is offline Find More Posts by BRUTUS2238
Old Feb 03, 2011, 07:52 PM
southernmd_man is offline
Find More Posts by southernmd_man
Gravity's a harsh Mistress....
southernmd_man's Avatar
United States, MD, Lusby
Joined Jan 2007
On all my PZ birds, I stick to 8 minutes of mixed flying.
southernmd_man is offline Find More Posts by southernmd_man
Old Feb 03, 2011, 07:54 PM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
doubleduce -
You are being conservative with 6 minutes. I fly my stock Wildcat (1300ma) and get 8 min. and use 70% of the available safe voltage from the battery.
I just use a regular multi-meter to check max.voltage (~12.4v) and then lowest allowable safe (~11.1v.) and find the percentage of the voltage used as the allotted amount for a given time. By just stretching your flight times in increments you'll discover how much time it can run to a safe low voltage. I'd think 10 mins. easily as a guess.
gnats82 is offline Find More Posts by gnats82
Old Feb 15, 2011, 01:43 PM
Joined May 2003
Great info, I'll start bumping up my flight times, 30 seconds at a time.
Thanks for the help
Old Feb 15, 2011, 02:20 PM
Brooklynstar23 is offline
Find More Posts by Brooklynstar23
NEVER GIVE UP!
Brooklynstar23's Avatar
Brooklyn, NY
Joined Nov 2010
Hey...after your done flying for those 6 minutes what are the cells reading on your battery when you go to charge it? The reading on those cells is a good indication of how long you can fly...remember to follow the 80% rule...
The 80% rule is applied by keeping track of the mAh used during a flight and keeping it below 80% of the rated capacity of the pack. That 80% is calculated by
80% of pack mAh = pack mAh * .8
For example here is 80% for the following packs
3s 850mAh 15C lipo
850mAh * .8 = 680mAh
3s 2200mAh 45C lipo
2200mAh * .8 = 1760mAh
6s 2200mAh 20C lipo
6s 5000mAh 25C lipo
5000mAh * .8 = 4000mAh
So how do you figure out what % of a lipo has been used after a flight? You charge the lipo with a smart charger capable of displaying the total mAh put in during the charge. That number represents the mAh taken out during the flight. To find the percentage
(mAh used / lipo capacity) * 100 = % used
For example take a 2200mAh lipo. Say you use this pack and recharge it to find you put in 1550mAh. The % used is
(1550mAh / 2200mAh) * 100 = 70.5%
Now use it to determine flight time...
Now that you know what the 80% rule is and how to calculate the % used during flight, lets put it to use. First you will need a flight timer. Some radios have them built-in but if your radio does not, a digital egg timer or other cooking timer can be used. Start by setting your timer for 3min and then fly for those 3min. Next you recharge the flight pack to learn how much mAh you used. From there you can make a rough estimate of how long a pack will last.
For example lets say you have a 450 sized heli that uses a 2200mAh 3s pack. You set your timer and hover the heli 3min. When you recharge the pack you find that the charger put 761mAh back into the pack. Since you are aiming to use no more than 80% of the 2200mAh pack, or 1760mAh, you now know you can more than double your flight time. So you go out and hover for 6min. That time when you recharge you find that your heli used 1568mAh. That tells you that for hovering 6min is very doable.
Another approach is to fly for a known length of time and then divide the mAh replaced by the charger by the minutes flown. That will give you an average mAh/min number that you can then use to determine max flight time. Using the numbers from the above example, a 6min flight used up 1568mAh. So each minute consumed 261mAh. Dividing 1760mAH by 261mAh will tell us how many minutes the heli will fly while consuming 261mAh per minute. That time is 6.7min.
Of course we arent talking helis here but the same concept can be applied to the airplane...when you fly for those 3 minutes how did you fly? aggressivly or leniently? Take that into account...its good to keep a bettery log as well to get a good average of the typical flight time you can expect...goodluck
Brooklynstar23 is offline Find More Posts by Brooklynstar23
Old Feb 15, 2011, 11:18 PM
Joined May 2003
Brooklynstar23
WOW thanks for the education. It all made sense to me and will use your formulas to calculate my potential flight times. Again thanks for the in depth info. Very helpful!!!!!!!
Mini-Review Walkera V100D01 Review with Pictures, Video, Flight Times, Motor and Pinion Options Tom Z Micro Helis 2114 Oct 17, 2015 01:54 AM
Discussion Hey Killbucket...Microcopter Flight (Run) Times? edwong3 Coaxial Helicopters 23 Nov 26, 2010 12:52 PM
Discussion My S107's Battery Life, and Flight Times edwong3 Coaxial Helicopters 17 Nov 02, 2010 06:45 PM
Discussion Lipo Flight Times Hossinarizona Batteries and Chargers 1 Oct 09, 2010 10:39 AM
Discussion flight times muebr Beginner Training Area (Heli-Electric) 3 Oct 08, 2010 12:25 PM
