Old Nov 18, 2012, 01:23 AM
GrahamWilson is offline
Find More Posts by GrahamWilson
Beating air into submission!
GrahamWilson's Avatar
Australia, NSW, Vaucluse
Joined Aug 2011
Try moving the TX further away at least 2 metres Harrow. At least his has not flown off yet!
GrahamWilson is offline Find More Posts by GrahamWilson
Old Nov 19, 2012, 06:03 PM
Redbrickman is offline
Find More Posts by Redbrickman
Maintain Thine Airspeed !
Redbrickman's Avatar
Wiltshire UK
Joined Apr 2010
Help diagnose sudden tails whip round
Mcpx Ver 1, not too many hours on the clock.
Flew it last week indoor everything was fine. I'm a beginner with CP so still learning hovering, and I went home well pleased with my progress, although the heli seems much more twitchy than my friends model, and has been from day one.
This week I take it out of the box, same settings on TX, spool up and find it very hard to hover, then on any increase of throttle it whips the tail round and shoots off across the room.
I checked it over visually and can find no problem, also rebound it to the tx. I have looked at the board connector and it seems like it is quite solid with no break in the sealant holding the plug to the main board.
Also checked I don't have any trims moved on the Tx.
Any ideas on what might be the cause?
Redbrickman is offline Find More Posts by Redbrickman
Old Nov 19, 2012, 06:31 PM
M3ATpl0w is offline
Find More Posts by M3ATpl0w
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Originally Posted by Harrow View Post
A question for you Version 2 mCP-X owners.
A friends V2 mCP-X would not bind today. The blue light is flashing on once every 4 seconds. This was strange to me, because the blue light on my V1 flashes very fast before it binds.
I'm guessing he just needs to get a new main board, but the slow flashing light has me wondering if it is indicating some other problem. Any ideas, or just a new board required?
Harrow.
+1
Only have 6 flights on mine, but had to rebind twice yesterday.
Any ideas?
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Nov 19, 2012, 06:44 PM
JForbes is offline
Find More Posts by JForbes
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
Tx and rx batteries fully charged? Make sure you see the moving LED's and not just the flashing Ines on your charger.
Just a thought....
JForbes is offline Find More Posts by JForbes
Old Nov 20, 2012, 12:01 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
So, is it normal for the blue light on the V2 to flash only once every 4 seconds while waiting for a bind?
Harrow is offline Find More Posts by Harrow
Old Nov 20, 2012, 01:27 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
No. I believe it should flash faster than that.
J_skaggs is offline Find More Posts by J_skaggs
Old Nov 20, 2012, 03:30 PM
JForbes is offline
Parkfly Padawan
JForbes's Avatar
Joined Aug 2011
when you bind it, do you hold right rudder for a while? I'm thinking mine might have flashed slowly like that the first time I tried to bind it and I held the right rudder input for too long.
Old Nov 20, 2012, 08:41 PM
Harrow is offline
Sydney, Australia
Joined Dec 2008
I'm using a computer radio (DSX9), not the one that comes with the RTF package.
Old Nov 21, 2012, 07:31 AM
JForbes is offline
Parkfly Padawan
JForbes's Avatar
Joined Aug 2011
I understand. I used a DX8. Still, when I binded mine, with the V2, you have to input right rudder during binding.
Old Nov 21, 2012, 04:29 PM
Joined Aug 2011
I have the manual in front of me. Page 7 BNF transmitter and receiver binding.. Computer radios do not require the rudder input whilst binding.. Non computer radios do.
Old Nov 21, 2012, 04:44 PM
cr5bst is offline
Find More Posts by cr5bst
Joined Jan 2012
I just picked up another mcpx v2 the other day...I may use my original for bl some day... Anyway, I have one 300mah battery that always lasted longer and was stronger than the supplied 250s. I used the 300 on my new mcpx and i've been getting loss of power(light goes out briefly on occasion). When the power stays on, the tail will not hold on simple things like pitch pumps i guess you call them. It's almost like there's too much power with this battery or something. It never happened on my original mcpx v2.
The 250's work fine. Has anyone had this issue before? I know about the tail hold issues but i'm not flying inverted or anything.
I still just hover around the living room and very seldom crash.
I wondering if I should take this one back? I don't yet know enough about these things to know if i have a defective one or am just asking too much from the tail.
ps my original does have a 1" extended solid boom.
cr5bst is offline Find More Posts by cr5bst
Old Nov 22, 2012, 04:58 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
If you do it without right rudder, you will be binding in 'computer radio' mode and will be able to make better use of the programmable features of your radio to customise how your mCP-X flys.
Old Nov 22, 2012, 07:14 AM
deonjams is offline
Find More Posts by deonjams
Philippines, NCR, QC
Joined Dec 2011
Have just fitted a tail support to my mcpx as i seem to crack the tail boom too often. rakon heli tail support fits well to standard mcpx tail or extended tail. Problem with tail losing power - found old batteries cause this, even have mine having the hiccups (all servos move every few seconds, and power drops) and only does this with my bad batteries
deonjams is offline Find More Posts by deonjams
Old Dec 25, 2012, 06:52 PM
Jsejalisco is offline
Find More Posts by Jsejalisco
United States, GA, Calhoun
Joined Apr 2012
mcpx v2
Hi all, I'm new using my dx7, I don't know how to set up, INH
On the pitch settings or throttle curve. Any body can help me?
Thank you. For your time
Jsejalisco is offline Find More Posts by Jsejalisco
Old Dec 27, 2012, 07:21 PM
Joined Aug 2011
Hi Jsejalisco, there are a lot of how to videos on YouTube that will hell.
Read the manual and follow the factory setup to start with as this works well.
Have a look at this
Blade mCPx Radio Setup & Binding (2 of 3) (12 min 32 sec)
Rant Blade MFP and the Blade MCP? Hellysmack Micro Helis 49 Jun 28, 2011 08:53 PM
Wanted Parkzone BNF or Blade heli tftcrider Aircraft - Electric - Airplanes (FS/W) 3 Feb 02, 2011 05:52 PM
Sold E-Flite Blade MCX Micro CX BNF Elec Coaxial Ultra-Micro Heli ttucker Aircraft - Electric - Helis (FS/W) 3 Dec 08, 2010 03:17 PM
Sold E-Flite Blade MCX Micro CX BNF Elec Coaxial Ultra-Micro Heli ttucker Aircraft - Electric - Helis (FS/W) 0 Nov 21, 2010 06:45 PM
Sold 260mm MCP woodie blades for mico heli's seattle_helo Aircraft - Electric - Helis (FS/W) 6 Jun 04, 2008 10:58 AM
