Old Feb 03, 2011, 02:13 AM
James K.G. is offline
Find More Posts by James K.G.
New Westminster, B.C., Canada
Joined Apr 2010
Question
A Brushless system for HPI Sprint 2 Sport?
Hi!
Q#1.Is this a decent BL system for HPI Sprint 2 Sport(http://www.hpiracing.com/kitinfo/708/) or too low quality? If it is not good enough, any BL system recommendation, please (If it is around $100, it will be ok.)
Here is the link fo the BL system.http://www.hobbypartz.com/26p-blcomb...9r-4370kv.html
Because the battery compartment of HPI Sprint 2 Sport only accepts 2-cell li-po in terms of the size, I am planning to use a 2 cell li-po 40C 5,000 mAh.
Q#2. For this battery, is the higher KV (4370KV) better or the lower KV (3000 KV) better? Or something between better?
Q#3. Could anyone give me an explanation about the relationship between "KV rate" & "the cell numbers of Li-Po", please?
Q#4. At this moment, I am using 2-cell li-po 20-30C 5000 mAh for my brushed HPI Sprint 2 Sport. Does it kill the brushed motor or not?
Thank you very much for your attention!
James K.G. is offline Find More Posts by James K.G.
Old Feb 03, 2011, 04:24 AM
Redfisher is offline
Find More Posts by Redfisher
Nice day for RC'ing
Redfisher's Avatar
Palmerston On. Canada
Joined Jul 2010
I would go with a higher KV motor for the onroad car if all you can run is 2s, Like 6000kv or more.
Redfisher is offline Find More Posts by Redfisher
Old Feb 03, 2011, 07:08 AM
iamahuman is offline
Find More Posts by iamahuman
iamahuman's Avatar
India, KA, Bengaluru
Joined May 2010
Q#4:The brushed motor will die on its own.The battery supplies just how much power the motor needs.
Does your brushed ESC have a lipo LVC?
iamahuman is offline Find More Posts by iamahuman
Old Feb 03, 2011, 07:10 AM
iamahuman's Avatar
Joined May 2010
http://www.rcuniverse.com/forum/m_87...tm.htm#8705858
Old Feb 03, 2011, 10:32 AM
Joined Apr 2010
Thank you very much for your responses!
There is no li-po lvc in the stock ESC, but I always check the voltage with a li-po voltage meter while running, so that I don't kill the li-pos
Any comments on the Leopard BL system? It is cheap, but I am wondering about the quality. But I should find out a higher kv BL system.
Your advices will be appreciated again! Thank you!
Old Feb 03, 2011, 10:14 PM
iamahuman's Avatar
Joined May 2010
I've not heard much about the leopard system.The EZrun combos are said to be good.Just make sure you get ones with turns like 13.5,6.5 and so on.It should end in '.5'.
Wanted WTT HPI Sprint 2 Sport Impreza StrangeFlightz Cars - Cars and Parts (FS/W) 0 Oct 18, 2010 05:18 PM
Wanted WTT HPI Sprint 2 Sport Impreza StrangeFlightz Cars - Trucks and Parts (FS/W) 0 Oct 18, 2010 05:15 PM
Discussion hpi sprint 2 drift, an sprint 2 ?'s kgsprint2 Car Talk 0 Oct 14, 2009 01:35 PM
Help! HPI Sprint 2 Sport Help!! RCdudeJF03 On-road Cars 0 Feb 28, 2009 11:46 AM
Sold HPI Sprint 2 Sport + drift set $150+s/h Zero3803 Cars - Cars and Parts (FS/W) 3 Jul 14, 2008 03:07 PM
