Old Mar 02, 2011, 10:47 AM
PositivelyJoe is offline
Find More Posts by PositivelyJoe
add lightness
PositivelyJoe's Avatar
Big time Minneapolis, Good Ol' St Paul
Joined Oct 2007
Originally Posted by stalyoni View Post
http://www.youtube.com/watch?v=_z6kPFFXkj4
looks like it wants to tip stall very badly, i think ill pass on this one. Not that impressed with it.
I have the need, the need for speed. I love my umx beast.
looks like it wasn't balanced, wasn't trimmed and not sure about the pilots skills. from the other videos I've seen this looks to be a very stable and sweet flying plane. I'd love a P-38. hopefully HH have one coming.
PositivelyJoe is offline Find More Posts by PositivelyJoe
Old Mar 02, 2011, 10:49 AM
add lightness
Joined Oct 2007
Originally Posted by skyjet View Post
Well, I thought the wind had died down enough. I did get the maiden in. This plane does not like wind or at least I don't like this plane in wind. The next time I fly it will be with VERY little or no wind. I hand launched it because I was flying it at a grass field. I flew it with a 240 HYP. I plan on flying it with a varity of different batteries when the wind is low. I do think it will be a pleasure to fly in no wind. You will see in the launch, the wind got underneath it and blew it back over my head, of course into the sun.
http://www.youtube.com/watch?v=qho6uHPYJIU
in the wind I'd suggest 1) move the cg forward some, 2) use a larger/heavier battery or maybe add a keychain camera.
I like the sound of those twin props. I was thinking of waiting for a P-38 version of this, but after that video, I might have to get this Mosquito = can't wait.
Old Mar 02, 2011, 10:50 AM
G-Man is offline
Find More Posts by G-Man
I've reached my critical AoA
G-Man's Avatar
United States, VA, Winchester
Joined Dec 2005
Picked mine up yesterday. It does suffer from that bad Wheel Wobble and looks like the hole is drilled off-center.
Has anyone contacted HH about this yet?
G-Man is offline Find More Posts by G-Man
Old Mar 02, 2011, 11:07 AM
skyjet is offline
Find More Posts by skyjet
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
Originally Posted by maxwellmark View Post
Nice video Skyjet, thanks. I had very similar conditions with my first flight. You get that big wing at an angle to the wind and wow.... she's a sail! Once trimmed she will float pretty good. You mentioned another good observation too, she likes to point to weather. Almost automatic. She flies very different from any of the other UM's. I'm glad too. Just what I wanted. Not just different looking but a different flight. She likes to be flown scale. Not a speedster like the P-51 and not as docille as the T-28. Thanks again for sharing.
Thanks! On that launch, it pitched up like everybody has mentioned, and then the wind took over. I checked my radio and found that I had put 13 clicks of down elevator(DX6i). I may mechanically put in some down elevator before I fly it next.
skyjet is offline Find More Posts by skyjet
Old Mar 02, 2011, 11:09 AM
jdwolters is offline
Find More Posts by jdwolters
Fly, be free! (splat)
United States, CA, Danville
I like the sound in the videos - very cool and different. Yes, it looks like a pain in the ass in the wind, just like the cub. Some extra weight in front of the cub works wonders, and I'm sure it will on this too. When the is no wind these are great to fly. Looking forward to this one!
Ps: I also have a hot-rod 2S micro P51 that rips its way through the wind pretty good.
jdwolters is offline Find More Posts by jdwolters
Old Mar 02, 2011, 11:17 AM
skyjet is offline
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
The CG was dead on 38mm with a HYP 240 all the way forward. I do plan on trying dual 160's 180's and 240's. The dual 160's only move the CG forward 1mm to 37. The 180's and 240's will be able to move it farther forward if needed.
Old Mar 02, 2011, 11:41 AM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Re: stock batteries
Yes got the 20C,,,, so everybody seems to be saying the Hyperions are better for this bird?????
Airman74 is offline Find More Posts by Airman74
Old Mar 02, 2011, 11:43 AM
Flyboy70 is offline
Find More Posts by Flyboy70
Joined Apr 2001
Mosquito Battery
It may have been mention earlier in the thread..But can anyone tell me where I can get some extra batteries for the Mosquito.
Flyboy70 is offline Find More Posts by Flyboy70
Old Mar 02, 2011, 11:54 AM
jpt1205 is offline
Find More Posts by jpt1205
Mayday! Mayday!
jpt1205's Avatar
Joined Aug 2010
Originally Posted by Ensign Jimmy View Post
This is a quick and dirty video that I took yesterday. One of these days, I need to pick up an HD video editor, as I now have an (authentic) HD keychain camera.
Great vid Jimmy. Thanks for sharing!
jpt1205 is offline Find More Posts by jpt1205
Old Mar 02, 2011, 11:55 AM
represent is offline
Find More Posts by represent
Please excuse me..
represent's Avatar
United States, TX, Dallas
Joined Feb 2011
Ok I wanted to see the cause of the tight motor. I thought it might be the pinion/gear contact. I was wrong. It is the motor itself. It is tight inside the motor housing. I lubed with a bit of food grade tri-flow. It helped a little but this motor is not the same as the other. Time will tell if it causes early burn out.
My port motor was noticeably tight from the moment I opened the box. It wouldn't freespin well at all, maybe 2 rev's after flicking it. It lasted 5 flights before screeching and seizing during flight. Good luck, Horizon is sending me a new one.
Too bad I have to rip off the plastic exhaust port to remove the nacelle. Thats what hacks me off.
represent is offline Find More Posts by represent
Old Mar 02, 2011, 12:10 PM
TMO is offline
TMO
Find More Posts by TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
The stock battery is EFLB2501S20- which is not yet available separately, but is slated to ship in 1 week or so. EFLB2501S, which is a 12C battery and somewhat marginally up to the task, is available and I can confirm does work and I've only seen a couple flights to this point.
As I'm sure you have gathered from the thread, an excellent choice would be the Hyperion 1S 240's as an upgrade, and actually is cheaper than the stock 20C.
There are a wide variety of single cells, such as EFLB5001S that would work, but would present issues as far as weight, connectors, and "drop in fit" ability.
Most of these cells should be available from your LHS, and I stock them if you're looking for online choices (quantumhobby.com). Other vendors such as Allerc or RCBabbel usually stock them as well and I would vouch for either of them as good dealers.
TMO is offline Find More Posts by TMO
Old Mar 02, 2011, 12:18 PM
lenrev is offline
Find More Posts by lenrev
lenrev's Avatar
Grayslake, Illinois, United States
Joined Mar 2001
Hmmmmm, ordered mine from Atlanta Hobby yesterday with three extra batteries. They never said there was any delay expected for the batteries. I have a bunch of eFlight and Turnagy's to use though.
lenrev is offline Find More Posts by lenrev
Old Mar 02, 2011, 12:21 PM
AggressorBLUE is offline
Find More Posts by AggressorBLUE
Park Stormer
United States, NJ, Brooklawn
Joined Jul 2008
Seemed to fly ok in the Wind from what I saw in the video. How much throttle were you feeding when you were "hovering"?
AggressorBLUE is offline Find More Posts by AggressorBLUE
Old Mar 02, 2011, 12:27 PM
Park Stormer
Joined Jul 2008
Unless you know something I don't, a P-38 is gonna be a looooong way out. The issue is the tail: Both getting it consistently lined up properly (we can't seem to get a decent, error free batch of mossies, now imagine how bad the lighting would be!) and getting the dual rudders to work in such a compact frame (the micro servos are too large to fit each in a tail boom).
Chances are better the next twin will be either something like the A-26, P-61, or my personal best guess: a micro twin otter. In my dream world, a quad like the B-17 exists as well. (pretty pretty pretty please horizon?)
Old Mar 02, 2011, 12:43 PM
TMO is offline
TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
In all likelihood, you are going to get EFLB2501S. I'm an HH dealer and fastserve currently shows 3/9 for an availability date on the 20C version. Not the end of the world to get the old ones though- they're pretty cheap and they seem to get the job done. Atlanta Hobby is a good vendor too.
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
