Old Feb 25, 2011, 06:47 AM
aracer is offline
Find More Posts by aracer
UK, Hereford and Worcester, Worcester
Joined Feb 2009
Originally Posted by RealGambler View Post
On the other side, for the first time with the Mossie, I'm thinking: "This plane will be my show plane only, this plane will be my show plane only" (that would be a first for me!) I always bring 2 or 3 boxes with me at the local park. Well, the way I see it now is "I'll bring the Mossie and only fly it when conditions are ideal, and only for show". What did happen to me?
Well that's definitely the way I'm thinking. Will be trying to resist doing anything too radical at all with this - given I'm not much more than a beginner and this will be my first 4ch plane that's the only way I'm not going to destroy it! Some nice coordinated turns will be good.
aracer is offline Find More Posts by aracer
Old Feb 25, 2011, 07:01 AM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
What else have you flown?
Lberry.88 is offline Find More Posts by Lberry.88
Old Feb 25, 2011, 07:13 AM
aracer is offline
Joined Feb 2009
A Champ, some FP helis and plenty of Phoenix sim time - will also be getting a FZ Albatros in the air soon (probably before the Mossie given UK release times). I can certainly bring anything back unharmed in the sim provided I don't get too wild.
Please don't tell me I'm not good enough to fly the Mossie!
Old Feb 25, 2011, 07:20 AM
Lberry.88's Avatar
Joined May 2007
Haha, no I'm sure you will be fine! The mossie looks quite docile in the air, have the rates down low and you'll be rocking!
Old Feb 25, 2011, 08:30 AM
represent is offline
Find More Posts by represent
Team Legit pilot & DFWC Prez
represent's Avatar
United States, TX, Dallas
Joined Feb 2011
Ok so I'm back at work feverishly anticipating someone's unboxing & maiden photos/vids...
If you've flown a sim, just make sure it's not too windy and I'm sure you'll get the hang of the Mossie in less than 5 minutes.
represent is offline Find More Posts by represent
Old Feb 25, 2011, 09:02 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
I would have thought the best way to handle the reversed prop would be to use the same motor turned backwards (output gear facing the rear), with the large prop shaft gear on the rear end of the prop shaft and the prop on the front. Propshaft and gearbox would be different, but motor and gears could be exactly the same. Gearbox would be longer to avoid a really long unsupported section of propshaft.
Unless there's really no issue with running one of these motors backwards.
I assume the one propshaft has reverse threads.
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Feb 25, 2011, 09:14 AM
skyjet is offline
Find More Posts by skyjet
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
Just a guess but...
The motors are the same can size, I personally think that they are the same as the Mustang motors, but will require longer leads to get from the RX to the engine nacelles. There was a discussion a while back in this thread where we were discussing whether or not PZ had developed a whole new motor for the CCW rotating engine.
The part number is for 2 motors, so i guess that one is CW and the other is CCW rotating - tho i still think just reversing the polarity of one will suffice to achieve this.
It does use the same motor for left and right. "Motor (2): Mosquito
$18.99 [PKZU1309]".
skyjet is offline Find More Posts by skyjet
Old Feb 25, 2011, 09:18 AM
Lberry.88's Avatar
Joined May 2007
Originally Posted by CNY_Dave View Post
I would have thought the best way to handle the reversed motor would be to use the same motor turned backwards, with the large prop shaft gear on the rear end of the prop shaft and the prop on the front. Propshaft and gearbox would be different, but motor and gears could be exactly the same. Gearbox would be longer to avoid a really long unsupported section of propshaft.
Dave
Me too, but someone earlier in the thread was explaining that just reversing the polarity would damage the brushes - we will have to wait and see!
$18.99 [PKZU1309]".
If they are the same motor why do they sell them in packs of two? If they are the same just reverse polarised at the ESC pins then there's no need for packs of two. Anyone opened one up yet?
Old Feb 25, 2011, 09:26 AM
skyjet is offline
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
Dave
I couldn't find the prop shafts on the parts list.
Old Feb 25, 2011, 09:31 AM
skyjet is offline
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
I think I read the parts listing wrong. I was thinking the "2" ment 2 required, but I think you are correct that it comes with both motors.
Old Feb 25, 2011, 09:54 AM
merx is offline
Find More Posts by merx
Joined Mar 2010
Decided to place my order today. I wasn't planning on spending any money until next week, but I figured hell if I buy it now at least I'll be able to fly it next Sunday if the weather permits. Very excited to see how this flies!
With only one battery, I hope the 160mahs will make her fly as well.
merx is offline Find More Posts by merx
Old Feb 25, 2011, 09:56 AM
Lberry.88's Avatar
Joined May 2007
Depends on their C rating - if its high enough she will fly with them, but just not for long!
Old Feb 25, 2011, 10:09 AM
CNY_Dave is offline
Joined Sep 2010
That should have said 'reversed prop', rotaing the mnotor as describe4d would keep the motor roitating in the same direction while rteversing the prop.
Old Feb 25, 2011, 10:37 AM
RealGambler is online now
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Well, wires for the motors are in plain view, between the fuselage and the nacelles, so the first one who get a Mossie has to tell us the color of the motor wires. If they are different color (black and white on one side and something else on the other side) then they are different motors. If on the final products, the wires going from the Rx to the motors are both black and white, then, it's more likely the same motor.
So, the wait begin...
RealGambler is online now Find More Posts by RealGambler
Old Feb 25, 2011, 11:05 AM
Xargon321 is offline
Find More Posts by Xargon321
Loose Nut behind the ..Sticks?
Vancouver, Washinton
Joined Jun 2010
My mossie is on the truck for delivery!!! anyone want detailed pic that was not seen yet? (non destructive please) !
Xargon321 is offline Find More Posts by Xargon321
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
