Old Feb 01, 2013, 12:50 PM
megadaz is offline
Find More Posts by megadaz
United Kingdom
Joined Mar 2012
Just maidened mine and I had to give it full right trim just to keep it level,original batteries made it nose light so some 500s did the trick. Anyone else had this problem.
megadaz is offline Find More Posts by megadaz
Old Feb 01, 2013, 02:19 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Congrats on the maiden!
Most of the UM Mossies are tail-heavy. Many of us are using larger batts to compensate. Regarding the trim - did you make sure that all control surfaces are mechanically trimmed for zero deflection, per the instructions? If not, do that first. Then zero your tx trim & take her up again.
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 03, 2013, 07:24 PM
hifinsword is offline
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Tail heavy Mossie
I haven't had the right drift problem but my Mossie has been tail heavy since I got it. I've put 3 one quarter oz weights in the nose and forward fuselage area to keep the nose down and have mechanically adjusted the elevator for more nose down trim. Finally got it to fly level. I tried a larger Hyperion 550mAh batt and it allows me to remove 1 of the 3 weights.
Don
hifinsword is offline Find More Posts by hifinsword
Old Feb 04, 2013, 03:21 PM
Speedy Gonzales is offline
Find More Posts by Speedy Gonzales
Joined Nov 2012
Flew her again yesterday in windy conditions; 10 knts winds gusting 20. But that was on a large field, so moderate turbulences.
I took her quite high this time so I could recover in case it was tossed. And tossed it was twice but I had room, so did not crash .
All in all 30 minutes of very nice time because she gave you the sense of how nice she could fly under calm conditions still staying upright under rough conditions. CoG was set a little bit forward an helped a lot.
The compliments go to the plane rather to the moderate skills of the pilot.
Under these conditions I did not even try to loop, roll or whatever else. Flying her high caused some orientations issues and did not wanted to increase them.
Speedy Gonzales is offline Find More Posts by Speedy Gonzales
Old Feb 04, 2013, 11:35 PM
Joined Jul 2009
Sorry, but the brushless motor was a false alarm. Turns out that the motor won't work with the factory gearing & the UM-sized props.
Joel
Old Feb 05, 2013, 02:35 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Too bad
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Feb 11, 2013, 05:11 PM
GoatRider is offline
Find More Posts by GoatRider
United States, MN, Maple Grove
Joined May 1999
Just flew mine on Friday for the first time, it was quite tail heavy. Might as well throw a bigger battery in there, any recommendations?
GoatRider is offline Find More Posts by GoatRider
Old Feb 11, 2013, 05:28 PM
Cocg is offline
Find More Posts by Cocg
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
I put two bats in parallel with a harness from RC Connectors..
Cocg is offline Find More Posts by Cocg
Old Feb 11, 2013, 05:58 PM
Joined May 1999
Originally Posted by chulian1819 View Post
Thabk you guys for the tip of using a 600mah lipo
this one makes the engines run smooth, it fits pefect and the CG its ok
http://www.hobbyking.com/hobbyking/s...dProduct=20385
So I have a lot of batteries of this size from my Quadrotors. How do I adapt the connector? I don't really want to solder a different connector into the plane until I've seen how it flies.
Old Feb 11, 2013, 06:22 PM
Joined Jul 2009
Hyperion 550. Lots of thrust, higher top-speed, and they're usually good for around 300 cycles at 5c charge before they start to fade away when cared for properly.
Get an adapter from Glenn at RC-connectors. He does excellent work & provides great customer service. Plus, he's a fellow modeler.
Joel
Old Feb 11, 2013, 06:29 PM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
GoatRider,
RC Babbel, Horizon and Glenn at RC Connectors sell the adapter that will mate JST to UM.
Gary
http://www.horizonhobby.com/products...r-lead-BLH3126
Gary Hoorn is offline Find More Posts by Gary Hoorn
Last edited by Gary Hoorn; Feb 11, 2013 at 06:30 PM. Reason: Forgot to mention Glenn at RC Connectors
Old Feb 11, 2013, 07:25 PM
Joined May 1999
Thanks guys!
Old Feb 14, 2013, 01:56 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Man I wish this thing was brushless. It flies quite well for the brushed setup it has but imagine.. One can dream right?
3d astronaut is offline Find More Posts by 3d astronaut
Old Feb 14, 2013, 07:21 PM
doug.wagner is offline
Find More Posts by doug.wagner
I can fix that!
doug.wagner's Avatar
United States, ME, Bangor
Joined Jul 2011
Don
I haven't read the thread from start to finish, so stop me if this is old news, but I dealt with the need for nose weight by drilling out my broken cannons, and replacing them with black painted, brass tubing. I have a second, stock nose to use with my heavier batteries, that don't need the extra weight. As an extra bonus...I don't snap off my guns anymore.
doug.wagner is offline Find More Posts by doug.wagner
Old Feb 15, 2013, 04:51 PM
Blue Skies
hifinsword's Avatar
Joined May 2012
Broken cannons
That's a good solution to the broken cannons. First thing to go in a nose-in crash!
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 23, 2012 12:51 AM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 02:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 03:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 01:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 02:28 PM
