Sounds to me like you need one of the servo reversing tools available from HH. You can selectively reverse either servo to get it going in the desired direction. If they work at all the servos are probably ok and one of them just needs reversing.
Gary http://www.horizonhobby.com/products/SPM6825 |
Given that the Mossie uses the same motor/gearbox/prop (one motor/prop being a RR version) as the F4U, the Mossie draws approximately twice the current of the other 1s UMs at a given throttle setting. I've got my throttle-timer set for 13 minutes, and I never hit the 80% discharge point with the Hyp 550. Of course, this is highly dependent upon one's flying style & use of throttle-management. I modulate the throttle as the situation dictates, and tend to use WOT only when a maneuver requires it.
Unfortunately, it's been long enough since I last flew the plane that I can't remember if I had the timer set for regular flying or carrying a keychain cam last time around. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
![]() Tony |
Latest blog entry: Maybe my fleet is too big...
South Africa, WC, Cape Town
Joined Mar 2012
Hi All
I had two flights the last two days, finally the wind dropped. Now that I have the CG worked out and she is no longer tail heavy, she is a joy to fly. I flew at around 7am this morning with the sun coming up, had to really concentrate as orientation could become a massive problem i think. Did some nice loops, stall turns, immelmans and a few practice landings on the cricket pitch, had one decent landing and a few nose overs unfortunately but nothing serious as I was coming in really slow. Thinking of getting the UM Spit Will have to convince the wife that its a matter of life or death
Just tell her the Mosquito needs an escort!!
Hmm...
Not sure I'd want my wife getting to like twins ![]()
United States, TN, Knoxville
Joined Oct 2012
Got the servo reversed and tried to fly it again. There was more wind than I realized but got it down. A wind gust flipped it before I could grab it and clipped the back of the fusilage on a metal fence posts.
Not going to reglue. Parts are on classified: http://www.rcgroups.com/forums/showthread.php?t=1764292 Thanks for all the help. Lynn |
Joined Nov 2012
Maiden flight
Bought a Mosquito second hand. Pretty good shape. Both motors run fine.
Maidened her today in moderate wind. Former owner flew her with almost all the way down trim. However this was not much a CoG issue. The elevator needed to be mechanically trimmed. Once it is levelled you only need two or three clicks on the radio. She is not tailheavy but on maiden I should have pushed the battery a little bit forward. I have balanced her on theoretical CoG, 38 mm from leading edge but I think 36 or 37 would be more appropriate when the atmosphere is not completely calm. Since I am not an experienced flyer I was somewhat stressed during the flight but fortunately everything was fine. Takeoff was handlaunched and she was landed on grass. I wish i could practise touch and go's but I feel I need some more practice before that. I am very interested in setting up differential since I use a DX6i. Will do that at a later stage. Last point: she put such a smile on your face that I suggest reimbursement by the social security. |
Using differential ailerons and deflecting the "spoilers" up for slow flight really makes the mossy much easier to land, without the tendency to tip stall.
Latest blog entry: AR6400 guillows Space Shuttle
Joined Nov 2012
2nd flight
Flew her again this week end in very windy conditions. 10 knts established and 18 kts gusts. She flew quite steadily most of the time but I was unable to recover her after being completely bounced by some gusts.
Since I was flying quite low in order to avoid more important turbulences above 50 feet every lost of control resulted in non desired landing (grass fortunately). I need a little less air... I need more agile thumbs... I need more time... I need AS3X... Not so much in fact. I am intellectually happy to fly "natural". At least as long as I do not experience a major crash. |
| Thread Tools | |
| New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? | Smokescreen38 | Micro RTF | 316 | Aug 22, 2012 11:51 PM |
| Discussion Parkzone New Ultra Micro Mosquito Mk VI | ChuckTseeker | Indoor and Micro Models | 4 | Feb 03, 2011 01:22 AM |
| For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan | ED3 | Aircraft - Electric - Micro & Indoor Airplanes | 3 | Nov 06, 2010 02:19 AM |
| Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts | major.monogram | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 08, 2010 12:00 AM |
| Found Parkzone Ultra Micro P-51D BNF (New or like new condition) | CGReload | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Oct 09, 2009 01:28 PM |
