Danville, CA
Edit: wow, motor sets are quite a bit cheaper at wholesaletrains vs HH ($12 vs $19) |
Sounds like an eventful maiden, for sure! I was just telling somebody that flying a 3D plane with an aft CG may be a blast, but flying a tail-heavy warbird is an experience you really don't want to have. I've never known anyone who wanted to do it twice! Good job getting her back down in one piece! BTW - My Sbach was also extremely nose-heavy. I also extended the battery tray back to the LE of the wing, as they have done with the Sbach 3D. I agree - most of the time, the recommended CG is quite conservative on these UMs. The notable exceptions would be the Mossie & Corsair - which are typically tail-heavy enough to require a much larger battery or some nose-ballast. Regarding the increased power after things loosen up a bit - I noticed the same thing, and I was using seasoned LiPos. The brushed motors definitely need to break-in a bit before they will produce full power, and high-quality LiPos nearly always get stronger as they break-in. I really enjoy flying the Mossie. In fact, it is the only 1s UM that I still fly with any regularity. I'm looking forward to seeing some pics of yours after you complete the weathering. So, you're the one who made the symmetrical UM P-51 wing. Cool! I wish all of the UM warbirds had proper airfoils. Bet she'll be a real screamer on 2s! She aught to look great in VooDoo colors as she 'rounds the pylons. ![]() Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
United States, TN, Jackson
Joined Mar 2007
Joel---My Mossie now flies GREAT with a nickle in the nose hatch...I'm now using 400mAh Hyperion 1S batteries and I'm enjoying some very long flight times...This is the only 1S micro I have left in my stable...Once I got the CG nailed down she grooves as if on rails...When she was tail heavy the model was extremely pitch sensitive and inverted flight required only a breath of down elevator...I can now easily fly inverted circuits....
THANKS for your help with this model...Even though I've been modeling for 42 years every now and then you get a tiger by the tail which I did with this plane...Sorting it out by reading yours posts and others now has me flying a plane I truely enjoy... Again---THANKS!!! Kevin |
Alright i have an interesting problem to diagnose!
My mossie, at lower power the motor stutter and when they stutter the control surfaces seem to flutter or stutter at the same time, but as i raise the power the problem goes away. Which makes me think it has to do something with vibration, and as the throttle goes up and vibration starts to even out it goes away. I though it had something to do with my motor, but its weird that the control surfaces are interconnected, so i then though maybe my battery lead had a bad connection somewhere. Also, i tried many different batteries, same problem. |
![]() I don't care for a speed deamon but I love having lots of park flyers now you have me thinking of getting one of these because yours sounds like it's running good and its a twin, and that's flippin cool to me.. is your mostly stock? what and if any changes besides the bigger battery? and how long are the long flight times? thank you
Joined Mar 2007
Kevin |
I regularly get 20+ minute flights, had a 30+ once!
Using a 120SR 500mAh battery, oh, and thermals
Latest blog entry: Maybe my fleet is too big...
Joined Mar 2007
I sure would like to try some Bravo motors---Even if the one running in reverse didn't last as long as the other...Hmmm...I'm wondering---Has anyone out there tried to put the end cap with brushes from a stock motor to the end of a Bravo motor???...If this is possible then the problems with running one of these brushed motors is solved!!!... I'm going to ask this very question in the Bravo motor thread... Kevin |
| Thread Tools | |
| New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? | Smokescreen38 | Micro RTF | 316 | Aug 22, 2012 11:51 PM |
| Discussion Parkzone New Ultra Micro Mosquito Mk VI | ChuckTseeker | Indoor and Micro Models | 4 | Feb 03, 2011 01:22 AM |
| For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan | ED3 | Aircraft - Electric - Micro & Indoor Airplanes | 3 | Nov 06, 2010 02:19 AM |
| Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts | major.monogram | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 08, 2010 12:00 AM |
| Found Parkzone Ultra Micro P-51D BNF (New or like new condition) | CGReload | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Oct 09, 2009 01:28 PM |
