Old Sep 09, 2012, 10:29 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Originally Posted by Kevin Greene View Post
I just bought one of these...I've been wanting a Mossy for a while and finally got a deal on one...Is it very acrobatic???...I expect my planes to easily loop from level flight...I plan on weathering my Mossy as well...Can't wait!!!...All I need is the UMX AS3X Spitty for a competent WWII RAF fighter group............
Kevin
Will loop at 1/2 throttle, add weight up front or use a 500ma cell.
Tim
w4yn is offline Find More Posts by w4yn
Old Sep 09, 2012, 10:41 PM
martimer is offline
Find More Posts by martimer
USA, MO, O'Fallon
Joined Dec 2003
As you might expect rolls are a little slow so you have to take that into consideration.
martimer is offline Find More Posts by martimer
Old Sep 09, 2012, 11:13 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Good to know!!!...I have batts from 350mAh to 500mAh to try with the Mossy...I'm a bit concerned with the width of the battery compartment, though...My 500mAh batts are fairly wide...(Hyperion)...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Sep 10, 2012, 01:22 AM
jdwolters is online now
Find More Posts by jdwolters
Fly, be free! (splat)
United States, CA, Danville
The narrow bats made for the SR 120 are perfect (Hyperion 550). The 320s are a great fit also. The 250s aren't so great -- they don't handle the extra current requirement well and they leave the plane tail heavy.
The Mossie will do aerobatics, but it is no fighter -- nothing like the mustang. Still, it can do all the tricks and it looks really good. The twin engine sound is really cool.
jdwolters is online now Find More Posts by jdwolters
Old Sep 10, 2012, 09:24 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Mine looped just great
I needs to post pics on here some time, mine has pulled so much G that it now has a curved wing! It rolls out of loops if your not on he ball
On the plus side though it self rights now and can be flown R/E only!
A very relaxing flyer if flown with a heavy battery up front
Tony
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Sep 10, 2012, 09:57 AM
chulian1819 is online now
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
Throttle and aileron problems
Hello guys,
First of all I have my 1s lypos (200mah froma blade mcpx and a 300mah nanotech) and work fine on my mcpx so i know my lipos are good.
When I give it throttle the engines dont run smothly, and at some point they quit, during this erratic start up the controls start to repond very slow and to make things even worse I have a frozen aileron
Any ideas how to fix this throttle issues?
chulian1819 is online now Find More Posts by chulian1819
Old Sep 10, 2012, 04:40 PM
I have the same problem. Even though the lips are good on the mcpx, they can't produce as much current as the Mossie wants and they just don't work. The smallest batt that works well on mine is a 320 but I've come really like the 550 made for the SR 120. Put on a 250 and all the problems you mention happen again.
Old Sep 10, 2012, 04:48 PM
BMFA 190658
Joined Mar 2007
Do you think it might be the Mozzie wanting more Amperage to feed its twin merlins, sorry twin motors!
Old Sep 10, 2012, 07:07 PM
You bet -- that's a lot of propeller blades. (Don't they sound good?)
Old Sep 11, 2012, 04:20 AM
BMFA 190658
Joined Mar 2007
Oh yes
Old Sep 11, 2012, 11:22 AM
Medellín, Colombia
Joined Apr 2010
thanks guys for the replies,
but even at low rpm the engines run irregular, also the lipo is a nanotech 300mah 35c and it used to work fine with this one.
what batteries are good for the mossie?
Old Sep 11, 2012, 11:34 AM
BMFA 190658
Joined Mar 2007
Everyone seems to use 500mAh+
The Mosquito can be very tail heavy, instead of adding dead weight just go for a huge battery and put up with the longer flight times!
Old Sep 11, 2012, 01:55 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
+1!! And don't forget the increased thrust-to-weight (provided that high-quality cells are used).
Joel
turboparker is online now Find More Posts by turboparker
Old Sep 11, 2012, 06:55 PM
barmonkey is offline
Find More Posts by barmonkey
WHAT THE...
barmonkey's Avatar
Evansville, Indiana
Joined Jan 2005
Getting ready to maiden my brand new Mossie. But first, I have a question for those flying with the STOCK E-Flite battery...As others have mentioned before...I seem to have a tail heavy plane. It appears that a dime (2.268 grams?) placed on top of the battery shows a good balance point...does this seem about right?
barmonkey is offline Find More Posts by barmonkey
Old Sep 11, 2012, 08:29 PM
Joined Jul 2009
The recommended CG is a good starting point. Simply measure the CG on your plane & adjust it to what it says in the manual. Then you can fine-tune it by flight-testing. When you get it just right, the elevator will be close to neutral for level flight, the nose will drop slightly in turns, the nose will drop moderately when power is cut, there will be enough elevator authority for a power-off flare, the plane will easily fly inverted with no more than a moderate amount of down-elevator, and it won't feel overly pitch-sensitive or darty. See my blog for a tutorial on flight-trimming: http://www.rcgroups.com/forums/showp...51&postcount=1
Joel
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 23, 2012 12:51 AM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 02:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 03:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 01:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 02:28 PM
