Old Aug 27, 2012, 03:41 PM
mclarkson is online now
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I finally got in my Hyperion 550s today. My Mossy has been a total hanger queen - I've probably flown in six times since I got it, and I got the first one my LHS received. I'm hoping these new batteries will change that.
mclarkson is online now Find More Posts by mclarkson
Old Sep 05, 2012, 03:56 PM
jdwolters is online now
Find More Posts by jdwolters
Fly, be free! (splat)
United States, CA, Danville
Maiden
I just got the same (550) batteries, and my replacement Mossie, and all I can say is TAIL HEAVY!! After dialing full down trim (which wasn't enough) I landed and tried the 550 -- that was much better -- just about right. I'll be flying with 550's from here on.
I converted my other micros to brushless, but I like the twin gearbox sound on this one; looks like it will stay this way for a while. Good looking plane.
jdwolters is online now Find More Posts by jdwolters
Old Sep 05, 2012, 04:19 PM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Hi,
Can anybody tell me what is involved with fitting GWS 5030 props to the mossie prop shafts?
Thanks in advance
valiantGLX is offline Find More Posts by valiantGLX
Old Sep 05, 2012, 06:47 PM
richos is offline
Find More Posts by richos
richos's Avatar
Joined Mar 2008
Originally Posted by valiantGLX View Post
Hi,
Thanks in advance
Yes i can
I use GWS Plantraco Propeller Adapters. Not the cheapest but the best.
Pop one off the sprue and push fit into the GWS 4mm hole and screw onto the shaft (thats it no messing around) in my opinion the best i have ever come across.
Plantraco Prop Adapter Set. Google it valiantGLX
These prop adapters enable you to fit GWS and other props with 4mm bore to 1mm, 1.2mm (0.047") and 1.5mm shafts. The set includes 2 of each type.
http://www.micronradiocontrol.co.uk/prop_adapter.html
Happy to help valiantGLX
richos is offline Find More Posts by richos
Because they are made for a thicker shaft with a prop saver or prop adapter. They work quite well with ap05 brushless motors, but not with the gearbox. The 5030 will also have to be cut down to 4.5" to clear the fuselage. (there is a three-blade 5030, by the way)
Edit: I see -- you can do it after all. Now you just have to cut down the props. The stock ones are still more slender and scale looking.
Old Sep 05, 2012, 06:51 PM
Does anyone know how long I can fly this on a 550? How about a 320? (my 1S charger doesn't tell me how much energy it puts back into the battery so unless I run it to LVC I just don't know.)
Old Sep 06, 2012, 06:58 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
On 500 I fly until I get tired! not sure but probably more than 10 minutes.
Tim
w4yn is offline Find More Posts by w4yn
Old Sep 07, 2012, 03:31 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Originally Posted by richos View Post
Yes i can
Thanks heaps for the nudge in the right direction
I am equipping the mosquito electrics in a scratch built carbon cub, so scale looks and limited prop space is not an issue. Now bearing this in mind what propeller combo will produce the most amount of thrust without overworking the motors too much?
You guys pointed me to the gws 5030s in the past, but what would be the difference between the 2 blade and 3 blade versions?
Latest blog entry: Please ignore....... for now
Old Sep 07, 2012, 11:34 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
One third
Sorry, couldn't help myself there
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Sep 07, 2012, 01:46 PM
alset is offline
Find More Posts by alset
Gunbarrel, CO
Joined Dec 2006
Do you balance the prop? If so, how? Or do just measure and cut carefully and not worry about it.
alset is offline Find More Posts by alset
Old Sep 08, 2012, 04:43 PM
First measure carefully and try spinning with a drill and touch to sandpaper - pretty close. You can get a bit more thrust because the blades are quite a bit wider, but it doesn't look as nice. (reminds me of a turboprop)
Old Sep 08, 2012, 04:51 PM
Battery time to LVC
I tried the two new batteries and ran one of each to LVC. They went for quite a long at basic cruise speed with no aerobatics. I got 10:20 from the 320mAh and 16:50 from the 530mAh. That is proportionally the same so the extra weight was no bother at all. With aerobatics my times are about half that. The Hyperion 530 (made for the blade 120) seems quite ideal. Both were quite warm at LVC. If I stop before LVC the 320 is warm but the 530 is cool to the touch.
Old Sep 09, 2012, 06:25 AM
BMFA 190658
Joined Mar 2007
LVC will kill your batteries!!!
Old Sep 09, 2012, 10:28 AM
I know! I just had no idea what to set the timer to; now I do. (I'll half each time.)
Old Sep 09, 2012, 05:59 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I just bought one of these...I've been wanting a Mossy for a while and finally got a deal on one...Is it very acrobatic???...I expect my planes to easily loop from level flight...I plan on weathering my Mossy as well...Can't wait!!!...All I need is the UMX AS3X Spitty for a competent WWII RAF fighter group............
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
