Old Aug 13, 2012, 06:55 AM
Sabastian is offline
Find More Posts by Sabastian
Jagd Flieger
Sabastian's Avatar
Canada, ON, Mississauga
Joined Apr 2011
Originally Posted by Beltpilot View Post
A Micro Heli? Come on...
No, seriously, I am totally NOT into Helis (not any more, I started with them) and I don't want any Especially no 3D Helis...
I don't care for any "mega" power, but I indeed want to have "massive" long duration, yes
That said, 300mAh are plenty enough, I'm just gonna buy 4 of those packs from MA and all is good.
Thanks and cheers,
Bernhard
Hello Bernhard
The last few days I have been reading this forum because I am deciding if I should buy the mosquito or not? I heard that you bought some 300 mah Nanotech batteries from Hobbyking and are looking for a adapter cable for it, I have the same batteries and I use them on my Parkzone UM P-51. The adapter cable that I use is a E-flite EFLA7002UM, that cable fits perfectly on the battery and the UM connector.
Hope that helps Sabastian
Sabastian is offline Find More Posts by Sabastian
Old Aug 13, 2012, 01:03 PM
Beltpilot is offline
Find More Posts by Beltpilot
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
Thanks Sabastian!
I first thought that this cable was just an extension, so I went ahead and ordered the other adapter cable from the US... could've bought the EFlite cable locally, but well...
Cheers,
Bernhard
Beltpilot is offline Find More Posts by Beltpilot
Old Aug 13, 2012, 02:04 PM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Get yourself a 120SR and use the JST charge adapter!
It's not the cheapest option but you will end up with an adapter cable, a 500mAh battery and a bonus helicopter
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Aug 13, 2012, 03:57 PM
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
LOL!
That would be a fairly pricy cable and batt at around 120€... wouldn't wanna have the Heli... now if it were flybarless and had some scale looking fuselage we'd be talking
Old Aug 13, 2012, 04:21 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Also, the Eflite cable is designed for charging batteries - not powering planes. It is very lossy at the relatively high current that the Mossie draws, so it robs a lot of power.
Joel
turboparker is online now Find More Posts by turboparker
Old Aug 13, 2012, 04:23 PM
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
Ok, thanks for that info! Now I am happy again I ordered my cable from RC-Connectors.com
Old Aug 13, 2012, 08:41 PM
jdwolters is offline
Find More Posts by jdwolters
Fly, be free! (splat)
United States, CA, Danville
New plane, no maiden
Natch. Fresh out of the box and one of the propellers is screwed on crooked.
jdwolters is offline Find More Posts by jdwolters
Joel
Ah hah. I was going to use of those too.
Old Aug 13, 2012, 11:13 PM
Joined Jul 2009
It's always best to avoid adapters - especially on a plane that draws ~3 amps @ WOT. But if you're going to use one, get it from Glenn at RC Connectors. His are lighter & they have a lot less loss. If you want to get maximum performance from this plane, switch it over to the red JST connector & use the Hyperion 550 mAh batteries that are made for the 120SR & mQX. If you're not up for soldering-on a new connector, shoot RCBabbel a PM & ask him to make you a few direct-fit Hyperion 320 cells with the UM connector. With either the Hyp 550s or 320s, you'll get way more thrust along with increased flight-time. Plus, the Hyperions are designed for 5c charging, which means 10-12 minute charges from the 80% discharge point. The Hyps also last for 200-300 cycles or more before they start to fade away - unlike most of the competition. And the extra battery weight solves the Mossie's slightly tail-heavy problem.
Joel
Old Aug 14, 2012, 09:05 AM
Sounds like a plan!
Old Aug 15, 2012, 09:49 PM
JFS61 is offline
Find More Posts by JFS61
Joined Aug 2012
Hope you didn't buy it from Hobby Town (still waiting to here back from Parkzone).
JFS61 is offline Find More Posts by JFS61
Old Aug 16, 2012, 06:22 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i order mine from horizon hobby.com and they have super helpfull. its like 1950 where the customer is all ways right vs ever where else, where the dollar is all way right.
i buy new mircos from them just cuz the service.
nemoskull is offline Find More Posts by nemoskull
Old Aug 16, 2012, 11:05 AM
I usually buy everything from HH but this time I had a bunch of Amazon dollars so I bought through them. I was going to replace the propeller myself but during bench testing I found that the rudder would slam all the way to the right once it reached about 50% input. It didnt appear to be physically stuck. After a fair amount of coaxing I got it to return to center. Full left to 25% right worked great but any more to the right and it would slam itself full right again and stay there. I figured this was a defective servo so I returned the plane. If all works out, I'll get a replacement.
Old Aug 16, 2012, 11:29 AM
Daydreaming of brushless conversion
Sure, it is ridiculously expensive but I've done other micro conversions so I've already got 2/3 of the parts. (I am aware of the difficulty and have a spare AR6400 Rx standing by.) I did 2S on the mustang but I think I would keep this at 1S with twin GWS 5030x3 props cut down a bit. These props come in both forward and reverse. I would run them on a couple of AP05's with XP3A ESCs.
I saw someone threaten to convert their Mossie, but I couldn't find an entry where anyone actually did it. Has anyone converted their Mossie to brushless? Who knows, maybe the twin gearbox noise will start to grow on me?
The 2S mustang is just incredible, by the way. (It also works on 1S, but you have to fly at full throttle.)
Old Aug 17, 2012, 07:44 AM
nemoskull's Avatar
Joined Sep 2009
i wanted to do the BL conversion on my mossie, but those gearboxs are hard to beat. there is very little room in there. a 1S BL gearbox (GB has the right kind of sound for a pistion, BL sound better in jets IMHO), but a 2S DD would have problems with weight and were to put the battery. the CG would be too far forward for a 2S battery in the nose. hence, the need to put it some where else, like the belly. tho it would look funny. and there is little room under the belly, thats more or less where the RX is.
then again is the problem of the brushed ESC only. i can be done, but PWM to PPM conveters are very simple to code in a uC, but most peopl cant do that. and PWM to PPM converters are hard to find.
so my idea was this: buy new mossie. sell rx. buy ar6400 rx. buy ap05 x 2, buy 1g 1S BL esc. install. but the blasted plane never flew right. it was slightly off, like the cg was wrong, or the elevator was lifting, or it had too much up thrust.
edit: by the way, im working on a 2S mustang, tho its a guillow 905
something with the pitch is not quite right. and the wing area is not scale. i want one, but i might just end up build one out of balsa, so i can arrainge everything inside like i like. foam may be king of tough and light, but it takes up a lot of room.
its almost 4am, and i guess im kinda rambling. sorry.
nemo
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
