Everyone that owns AS2000 servos should have one of these servo reversers in their tool box (they also come free with a AS2000 replacement servo) |
Latest blog entry: AR6400 guillows Space Shuttle
Put the Rx into dual aileron mode. I think you power up the plane with the right stick top left if I remember correctly (it says how to do it in the manual), then reverse either the aileron of flap to achieve the correct movement.
This opens up many more possibilities such as differential or spoilers, with no drawbacks! |
Latest blog entry: Ridge Flying Fun :)
The TX can reverse the servos individually, after the brick is put into separate channel 2/6 mode. |
Tom,
Very cool shot! ![]() Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined Aug 2012
Actually, I didn't discover the problem until today, and the store was closed, so to not much that either they or myself could do. I'm just going by the fact that it's a HobbyTown franchise, and they have a no return policy (which I wasn't really aware of beforehand, but my impatience got the better of me so I went ahead), but as you said it's defective, so it should be an exception. I'll just have to check with them tomorrow, as some of the franchises are apparently easier to deal with than others. I'm just thinking that it might be easier in the long run to deal with HH directly, and either send it back to them to fix or just have them send me the parts so I can do it myself.
You could try warming the foam up with a hair dryer and just bending it back the other way. The top of my V. stab. bent right over & cracked, so I used a little glue. You could get some small carbon fiber rod if you reall wanted to stiffin things up. If it's not perfect, a little trim should solve it.
United States, NC, Charlotte
Joined Jan 2007
I cut clear package tape and taped elevator and stab. Made a huge difference. I do run 500Ma battery so did not change CG enough to notice. Tim |
JFS61,
Be very careful with those tail feathers. Too much heat from either a heat gun, hair dryer or hot water will render them useless. Gently massage them into position using a hair dryer but do not let them get very hot. Hold them in the correct position while cooling. I used some clear scotch tape on both sides of the rudder to hold it straight and add some reinforcement. Same for the horizontal stabilizer, especially the tips. Work carefully and it will come out just fine. The bird is usually tail heavy and I use 500mah lipos for some nose weight. Gary |
| Thread Tools | |
| New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? | Smokescreen38 | Micro RTF | 316 | Aug 22, 2012 11:51 PM |
| Discussion Parkzone New Ultra Micro Mosquito Mk VI | ChuckTseeker | Indoor and Micro Models | 4 | Feb 03, 2011 01:22 AM |
| For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan | ED3 | Aircraft - Electric - Micro & Indoor Airplanes | 3 | Nov 06, 2010 02:19 AM |
| Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts | major.monogram | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 08, 2010 12:00 AM |
| Found Parkzone Ultra Micro P-51D BNF (New or like new condition) | CGReload | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Oct 09, 2009 01:28 PM |
