Old Aug 01, 2012, 05:00 AM
Beltpilot is offline
Find More Posts by Beltpilot
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
Hi Joel,
thanks for your explanation. From what I have seen in various threads and graphs, I would've believed that MA batts outperform HYP batts when they have the same capacity. I guess they are pretty similar then, so that is ok because neither does HYP offer a 190mAh nor a 300mAh so my order goes to MA
Originally Posted by turboparker View Post
If I were going to use an adapter, I'd get mine from Glenn.
Well, that's where I am getting mine from
Regarding the TP batteries - just shoot RCBabbel a PM. He's been making the lightest, highest-performance UM cells & packs available for a few years, now. Another dedicated RCer who takes pride in excellent workmanship and great service. He makes them from bare cells, so they are considerably lighter than factory packs of similar capability
Any idea about his prices?
You don't need any adapters with his UM cells & packs, so you save a bit more weight. ... But TP doesn't offer it with the UM connector, nor do they offer a 2s version with the UMX connector.
That confuses me I don't need any adapter, but he delivers the packs without the UM connector? What do I need then?
Cheers,
Bernhard
Beltpilot is offline Find More Posts by Beltpilot
Old Aug 01, 2012, 05:07 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
RCBabbel strips down ThunderPower packs, lightens them and changes the plug to the UMX type
If you ordered direct from TP they would have a mini JST plug.
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Aug 01, 2012, 05:41 AM
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
So I do need an adapter, UM to UMX?
Old Aug 01, 2012, 05:55 AM
BMFA 190658
Joined Mar 2007
Ah, yeah...
sorry about that, forgot that I was on the Mosquito thread there
I'm sure RC would still make you one up if you wanted a 1S UM plug on it.
Old Aug 01, 2012, 11:06 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
As SP mentioned, RCBabbel would most likely make up some 1s TP: 325s with the proper UM connector so that you wouldn't need an adapter. Regarding prices - I'm not sure. Just just shoot him a PM & ask.
Joel
turboparker is offline Find More Posts by turboparker
Old Aug 01, 2012, 01:58 PM
Arthur is offline
Find More Posts by Arthur
Ceredigion, Wales.
Joined Oct 2000
My apologies if this has been asked before. I haven't flown my mossy for several months. I thought I'd give it another outing . Go it all connected up and everything seemed okay. I switched it off and had a cup of tea. Got it all bound again. Now the ailerons act a bit like flaps. They both go up and down together.. I have tried various mixes to no avail. It is a DX 6i Tx. Has anybody else had this problem, or any suggestions as to what is wrong. Arf
Arthur is offline Find More Posts by Arthur
Old Aug 01, 2012, 02:23 PM
BMFA 190658
Joined Mar 2007
Did you by any chance leave a battery in it while in storage?
These linear type servos have some kind of programming which it seems can change if they get low voltage.
You've got two choices. Put the Rx into Dual Aileron mode and reverse the flap or aileron, whichever it needs.
Or you could open it up and use a reversing cable.
Mine uses the dual aileron mode, there doesn't seem to be any drawbacks!
Tony
Old Aug 01, 2012, 02:36 PM
Arthur is offline
Ceredigion, Wales.
Joined Oct 2000
Thanks for the quick reply, the battery was not left in. I will give the Dual Aileron mode a try. Thanks again Arf
Old Aug 01, 2012, 03:23 PM
Joined Jul 2009
Art,
The brick supports dual-servo, single-channel ailerons (factory setting) and dual-channel ailerons. Leaving the battery connected & letting it run down sometimes causes the brick to go into dual-channel aileron mode. The other thing that can happen is that a servo can become internally reversed. If the brick is in dual-channel aileron mode, setting the tx up for dual-channel ailerons & playing with the servo directions on the tx should get things working correctly. If not, then one of the servos has most likely been reversed. You can reverse the servo direction with the servo-reversing cable that comes with replacement servos. You plug it in momentarily & then remove it. See page 10 of the brick manual. If the brick is in dual-channel mode, you can re-program the brick for dual-servo, single-channel ailerons. However, the most desirable option would be to set the tx up for dual-channel ailerons, which allows you to experiment with differential ailerons and/or spoilerons - both of which enhance low-speed maneuverability by reducing the possibility of tip-stalls. I fly Futaba, so I'm not familiar with setting the DX6i up for dual-channel ailerons. However, it is described in the manual. Someone on here who is familiar with Spektrum programming will most likely chime-in & give you a hand if you run into trouble. The directions for reprogramming the brick back to single-channel aileron mode are on page 11 of the brick manual.
http://www.spektrumrc.com/ProdInfo/F...10T-Manual.pdf
EDIT: I see that Tony types faster than I do!
Joel
Old Aug 01, 2012, 03:50 PM
richos is offline
Find More Posts by richos
richos's Avatar
Joined Mar 2008
Sorry for all the confusion in the posts Bernhard.
The Miniaviation one cell 300mAh 30C battery Platinum Edition Battery is a (SPECIALIST) off the shelf plug and play Li-Po for the Eflite Blade mCP X micro Heli . Made for micro heli guys who want a MASIVE 30c of puch of power to do a brushless conversion of the of the Blade mCP X micro Heli.
But as i said before the only way to connect the Blade mCP X Miniaviation one cell 300mAh 30C battery is to get a (um to mcpx Micro Adapter) from (RC-Connectors)
Um to mcpx Micro Adapter.... FROM (RC-Connectors.com)
Use your MCP-X Lipos on your Mosquito, MCX, MCX-2, 4-Site or any other regular 1S lipo plane or heli....$5.39
http://www.rc-connectors.com/index.p...roducts_id=299
Miniaviation Blade mCP X 300mAh 30C battery Platinum Edition Battery....
2 pack ....9.60
http://miniaviation.com/mCPX.html
Or why not just get a Blade mCP X Micro Heli and do a brushless conversion and put a Miniaviation one cell 300mAh 30C battery Platinum Edition Battery in it.. and go 3d Heli micro (BALLISTIC)
Do you realy want all that (MEGA) 30c power, and (MASIVE)long duration in your little Mosquito Bernhard ??.
Blade mCP X brushless video #2 (3 min 20 sec)
MCPX V2 BRUSHLESS (3 min 13 sec)
richos is offline Find More Posts by richos
Old Aug 01, 2012, 11:01 PM
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
A Micro Heli? Come on...
No, seriously, I am totally NOT into Helis (not any more, I started with them) and I don't want any Especially no 3D Helis...
I don't care for any "mega" power, but I indeed want to have "massive" long duration, yes
That said, 300mAh are plenty enough, I'm just gonna buy 4 of those packs from MA and all is good.
Thanks and cheers,
Bernhard
Old Aug 02, 2012, 03:16 AM
Arthur is offline
Ceredigion, Wales.
Joined Oct 2000
Thanks Turbo and Silent. Will give everything a go. Arf
Old Aug 02, 2012, 11:35 PM
FlyGuy3345 is offline
Find More Posts by FlyGuy3345
FlyGuy3345's Avatar
United States, WI, Sheboygan
Joined Apr 2012
My mosquito keeps losing signal or stopping mid flight, I tried different batteries, and the transmitter works fine on other planes. I get my Mossie up in the air for a minute then I lose all control, when I get to the plane everything works again. Well sometimes the motor won't run sounds like some kind of kill switch when I throttle up a little but the other controls work.
FlyGuy3345 is offline Find More Posts by FlyGuy3345
Old Aug 03, 2012, 04:00 AM
BMFA 190658
Joined Mar 2007
Sounds like there could be a bad connection (dry joint?) on the board somewhere. Spinning up the motors could be diverting too much power away from the Rx causing either reduced range or maybe even a complete brownout...
Old Aug 03, 2012, 08:37 AM
Arthur is offline
Ceredigion, Wales.
Joined Oct 2000
Further to my recent post concerning aileron problems, I tried all the electronic fixes to no avail.
I could not find a reverser any where. In the end iremoved one nacelle to get access to the servo which I removed and turned through 180 degrees. And it works !
Just bought a Mig 15 so I thought I would get my eye back in again with the Mossy. Wish me luck Arf
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 23, 2012 12:51 AM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 02:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 03:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 01:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 02:28 PM
