Old Jul 24, 2012, 07:05 AM
PawnBoy is offline
Find More Posts by PawnBoy
Canada, ON, Waterloo
Joined Jul 2012
I've recently come into possession of one of these mossie's, unfortunately the airframe came pre-totalled. On the other hand it came with a replacement airframe, so all need to do is migrate the electronics over onto the new set of foam and glue the whole contraption together. I've already taken the electronics off the old airframe and before I started gluing it onto the fresh frame I just wanted to do a quick check of all the electronics to make sure they were still functional, but I can't figure out how to connect the motors to the receiver.
I think i'm missing a part (maybe an adapter from the two motor connectors to the single 4-pin connector at the center of the board), but I don't see it in parkzone's parts list.
Does anyone know what I'm talking about?
PawnBoy is offline Find More Posts by PawnBoy
Old Jul 24, 2012, 07:49 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Motors plug into those two black connectors protruding from the receiver. (one per connector). On your picture, they are between the antenna and the battery cable.
RealGambler is offline Find More Posts by RealGambler
Old Jul 24, 2012, 07:51 AM
peterswolf is online now
Find More Posts by peterswolf
peterswolf's Avatar
United States, FL, Riverview
Joined Apr 2012
Those two black little boxes sticking off the main board, are they not 2 pin connectors?
peterswolf is online now Find More Posts by peterswolf
Latest blog entry: http://www.peterswolf.com
Old Jul 24, 2012, 07:53 AM
PawnBoy is offline
Joined Jul 2012
Doh, I don't see any blushing emoticon... The receiver was already removed when I got it and I just figured those were power transistors or something and assumed the 4 pin connector was meant for the motors!
Thank you!
Old Jul 28, 2012, 08:10 AM
awacsCZE is offline
Find More Posts by awacsCZE
awacsCZE's Avatar
Joined Aug 2010
Good day,
yesterday I wanted to fly my Mossie, but I had problem with two E-Flite stock batteries. One, which I assumed, was fully charged and should be fully charged, but after 30s of flight, Mossieīs ESC cut off and I landed. I took the second battery and WOW :-O like a baloon and some weird mass come out. Still giving 3.9V But motors wont run.
Do you know, how many amps the mossies engines takes? Because I had an accident and one engine is slower at low RPM
Mosquito engine run (0 min 21 sec)
Do you think, this problem can cause too many power drain to destroy battery?
awacsCZE is offline Find More Posts by awacsCZE
Old Jul 28, 2012, 08:25 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
It's my experience that the E-flite batteries don't last very long. Nearly every E-flite battery I own is dead (all of my Mossy 250's are). I'd get a new battery and see what it does, then look at new motors.
UNGN is offline Find More Posts by UNGN
Old Jul 28, 2012, 08:29 AM
awacsCZE is offline
awacsCZE's Avatar
Joined Aug 2010
Ah, ok, thank you
Do you think, I can use this battery? Could it be better? I donīt know, if it is same connector.
http://www.bestbuymodel.com/detail.a...i=120102000048
Old Jul 28, 2012, 08:35 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by awacsCZE View Post
Ah, ok, thank you
Do you think, I can use this battery? Qould it be better? I donīt know, if it is same connector.
Yes, the Hyperion 240 is an excellent choice. They provide considerably more power than the factory battery, they're designed for 5c charging, and Hyperion LiPos usually last for hundreds of 5c charge cycles when properly cared for.
Joel
turboparker is online now Find More Posts by turboparker
Old Jul 28, 2012, 08:46 AM
awacsCZE is offline
awacsCZE's Avatar
Joined Aug 2010
Joel
Thank you, i was worried, because it costs a third of E-Fliteīs here. So I will use it
And no need to sold another connector, i fits good?
Old Jul 28, 2012, 09:31 AM
Joined Jul 2009
You're welcome! And yes, that one has the proper 'UM' connector.
Joel
Old Jul 30, 2012, 08:36 AM
Beltpilot is offline
Find More Posts by Beltpilot
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
Hey guys,
just bought that bird, will get it tomorrow. If I understand right, it uses the "standard" UM-connector that the other micro warbirds and the Blade mSR (X) heli use, not the "high current" UM-connector of the mCP X, right? Just larger batteries...
That said, these do NOT work?
http://www.hobbyking.com/hobbyking/s...dProduct=17808
Any plug'n'play replacement for the stock battery available at HK?
What about these:
http://www.miniaviation.com/mCPX.html
They are said to be for the mCP X as well, so normally wouldn't fit... that said, I am having a hard time finding plug'n'play batteries (no cable) with the standard UM-connector
I am a little confused about the micro connectors... I always thought there was only one type, but it seems not... so is it really true there are two different kinds, standard (mSRX) and high current (mCPX)?
Cheers,
Bernhard
Beltpilot is offline Find More Posts by Beltpilot
Old Jul 30, 2012, 10:05 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Just use the charge adapter that comes with the MCPx.
All 1S planes and helis come with an adapter to convert to standard UM.
It may not be the most effiecient but it sure works! I use the 500mAh 120SR batteries in mine
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jul 30, 2012, 10:19 AM
Wilde Sau
Beltpilot's Avatar
Germany
Joined Sep 2009
I don't have the mCPX, so I don't have the charge adapter... which is the battery connector on the Mosquito is the more interesting question? I might wanna change that to the mCPX connector (if it doesn't have it) to use all those aftermarket batteries...
Cheers,
Bernhard
Old Jul 30, 2012, 10:55 AM
BMFA 190658
Joined Mar 2007
The Mosquito uses the smaller, regular size 1S connector.
As for aftermatket packs, I'm not sure who will be best choice for delivery to Germany. I use Miniaviation (UK supplier) 190mAh packs in my Sukhoi XP and Polecat.
RCBabbel (US supplier) does awesome lightweight packs with any connector you want. I use his 2S & 3S Hyperions both 180 and 240mAh.
The Mosquito is well known to be tail heavy but I'm sure he would be able to offer you some Heavyweight (ie large capacity) Hyperions or Thunder Power packs.
HK does have a German warehouse though doesn't it so postage may well be quicker for you there. I have Nanotec 300s for my MCPx which were a good power up, though not too heavy. Remember that the Mosquito likes a lot of weight up front
Old Jul 30, 2012, 11:00 AM
tbullard is offline
Find More Posts by tbullard
United States, GA, Appling
Joined Jul 2012
Cheers,
Bernhard
This is what you need to use the MCPX batteries http://www.rc-connectors.com/index.p...roducts_id=299
tbullard is offline Find More Posts by tbullard
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
