Old Jul 09, 2012, 05:11 PM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Good advice Joel, thanks!
I'll swap it to JST. I do use throttle management, only occasional WOT.
I too have noticed good flight times with my 3Sbach
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jul 09, 2012, 07:54 PM
Sabastian is offline
Find More Posts by Sabastian
Jagd Flieger
Sabastian's Avatar
Canada, ON, Mississauga
Joined Apr 2011
I thank everyone for all the good advice on the batteries, I looked up the JST to micro connector at Horizon Hobby and found it, then I checked with my local hobby shop and they have the connector in stock. And the E-Flite 500 mah batteries
A few weeks ago I ordered some parts and batteries for my planes from Hobby King, one item which I planned on using on my UMP-51 was the Turnigy Nanotech 3.7v 300 mah lipos with the larger connectors on them, has anyone tried these on the Mosquito, they are 50 mah more than the stock battery so they should also work quite well, I ordered 6 of them, they should be arriving in the next few days. I will have to make an adapter for the batteries, I have some micro extensions with female on one end and male on the other end and the charging cable for the larger connector batteries, I will just cut and splice some of the wires together to make the right connection.
I can try out my Nanotechs and then try out some 500mah to see what the difference would be.
Thanks sabastian
Sabastian is offline Find More Posts by Sabastian
Old Jul 10, 2012, 01:54 AM
BMFA 190658
Joined Mar 2007
I've got some of the Turnigy 300s for my MCPX, I could do the same trick with them and use the eflite charge adapter to use in the Mozzie. Like Joel says though this would not be very efficient due to the losses, the only real gain would be the extra 50mAh.
They are not as heavy as the 500s either!
Let us know how you get on
Old Jul 10, 2012, 03:36 PM
Jagd Flieger
Sabastian's Avatar
Joined Apr 2011
Hi Guys
I had another question about the Mosquito, has anyone tried to convert one to a JU-88, they look very similar with the two main differences being the tail and nose\cockpit area. The reason I am asking is that I have always been into German and American aircraft and now my favorite are the Luftwaffe planes. I think with a different paint job it could pass for a JU-88, most people watching where I fly would have no idea.
Any ideas?
Thanks Sabastian
Old Jul 12, 2012, 08:46 PM
barthrh is offline
Find More Posts by barthrh
Joined Sep 2011
Originally Posted by SilentPilot View Post
The only thing really to note is that it can be very tail heavy. Easily sorted with a larger, heavier, battery
I got out on a perfect night tonight to try out the recently suggested dual ailerons. Worked great. With the calm wind and good turning, I was finally able to figure out what else made the plane squirrelly. Man, is it tail heavy! You aren't kidding!
I'll try to pick up an adaptor and put my 120SR batteries in it. What short-term fixes are there?
I also find it a bit hard to land (OK, really hard to land), but that may also be a function of fighting its tail-heavy tendencies.
barthrh is offline Find More Posts by barthrh
Old Jul 13, 2012, 02:28 AM
BMFA 190658
Joined Mar 2007
Short term just use the charge adapter hat came with the 120SR.
The Mosquito is horrible to land with a rear CG, the elevator is far too sensitive and it balloons way too easy
I'm still using the 120 lead with mine, it was only supposed to be a temporary fix but it flew so well that I left it on there.
Joel has finally talked me into changing the lead on the plane to a mini JST. More power will be available which I hope to translate into even longer flight times
Btw, my personal best is well over 30mins on a stock battery!
Tony
Old Jul 20, 2012, 04:52 PM
BMFA 190658
Joined Mar 2007
Had a couple of nice flights with this the other day.
500mAh battery up front and it was still way tail heavy!
I think that this needs stripping down now and the wings beefing up, it has very noticable dihedral and will auto level. I actually did some Rudder only turns and it will fly 3ch
I think it is time to strip it down and try to lighten the tail. There must be some foam can go without sacrificing strength.
I would love to upgrade this to 2x 2S Brushless
Old Jul 20, 2012, 07:39 PM
shepflyr is offline
Find More Posts by shepflyr
United States, SC, Charleston
Joined Aug 2011
SilentPilot,
I added a bit of lead weight in the nose...in the lower fuse in the front of the batt compartment. With RC Babbel's 240 pack, she flies just fine.
Still, there can be significant variation between individual planes. And it sounds like you're wanting to do a major upgrade mod. Love to hear how it turns out. Good Luck!
Tom
shepflyr is offline Find More Posts by shepflyr
Old Jul 20, 2012, 11:27 PM
BMFA 190658
Joined Mar 2007
I'll let you know!
The twin Brushless might be too much for the airframe, but then again WOT is optional right?
Old Jul 21, 2012, 12:09 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
If I remember correctly, Mendo was working on a dual bl Mossie at one time. Haven't heard anything about it for some time, now. Not sure what happened. I'd love a 2s bl Mossie! I'd even make the inboard flaps functional to help slow her down on approach.
Joel
turboparker is offline Find More Posts by turboparker
Old Jul 21, 2012, 03:13 AM
BMFA 190658
Joined Mar 2007
Inboard flaps and micro retracts!
Are you listening HH
Old Jul 22, 2012, 08:20 PM
Scottmac737 is offline
Find More Posts by Scottmac737
CV-63/VR-62
Scottmac737's Avatar
New Haven, MI
Joined Aug 2009
I'll let you know!
WOT may be a option but it's a temptation that is too hard to resist.
Someone telling me I don't have to use all the throttle is comparable to my wife cooking brownies naked and telling me not to touch.
Scottmac737 is offline Find More Posts by Scottmac737
Old Jul 22, 2012, 08:42 PM
BMFA 190658
Joined Mar 2007
Not to touch the brownies or her?
Old Jul 22, 2012, 08:54 PM
CV-63/VR-62
New Haven, MI
Joined Aug 2009
Depends on how hungry I am.
Old Jul 22, 2012, 08:59 PM
Joined Jul 2009
Now, that is quotable! I'm still laughing!
Joel
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
