Old Aug 18, 2011, 01:39 PM
oly_rcer is offline
Find More Posts by oly_rcer
what ya mean i have to land?
DesMoines,Wa
Joined Feb 2008
ya checked the cg,it's spot on.think it's just the wing design,my mini p-51 does the same thing with the undercambered wing,just have to be really easy on the up stick,the rest is okay,actually flies nice except for that,had some winds but it took it well,forgot to remove the landing gear and they snagged the grass on landing,no damage but will remove for future flight,just have to compensate for the weight of the gear.seems pretty peppy for a microalso lost 1 of my guns
oly_rcer is offline Find More Posts by oly_rcer
Old Aug 18, 2011, 01:45 PM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Try moving the CoG forward anyways, it wont harm to try!!!
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Aug 18, 2011, 01:46 PM
oly_rcer is offline
DesMoines,Wa
Joined Feb 2008
ya thx,am going to order some bigger batts,maybe around 350-400 or so
Old Aug 18, 2011, 05:39 PM
BMFA 190658
Joined Mar 2007
That's what I'm doing! Bigger batts - might as well have longer flight times instead of dead weight onboard...
Old Aug 18, 2011, 07:11 PM
rcpilot23 is offline
Find More Posts by rcpilot23
rcpilot23's Avatar
Perth, Western Australia
Joined Feb 2007
I fixed the ballooning problem by using a 1S 500Mah lipo used in the Eflite Blade 120SR heli
works great and flys way over 10 minutes
rcpilot23 is offline Find More Posts by rcpilot23
Old Aug 18, 2011, 07:14 PM
oly_rcer is offline
DesMoines,Wa
Joined Feb 2008
did you have to cut any foam or did it fit in?
Old Aug 18, 2011, 07:39 PM
rcpilot23's Avatar
Joined Feb 2007
No cutting requires it fits in easily
Just buy the lipo adapter when you buy the 500Mah lipo
was about $10 all up
Old Aug 18, 2011, 11:10 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I only flew my Mossy 3-4 times, as it was so balloony it was crazy. 'Level' flight was a 30% nose up attitude. CG was spot on.
I may have to give it another go with some more weight in the nose.
mclarkson is offline Find More Posts by mclarkson
Old Aug 18, 2011, 11:48 PM
oly_rcer is offline
DesMoines,Wa
Joined Feb 2008
howdy m,damn i keep seeing you in the same forums,we must have close tastes lol.gonna order some 500mah batts and see if that helps.for what it's worth my mini p-51 flies the same way,i moved the batt all the way forward and that helped it,no room to move this batt forward
Old Aug 19, 2011, 12:27 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Two words: down trim
Put in the right amount and it's not "balloony" even with a Hyperion 240.
BEC is offline Find More Posts by BEC
Old Aug 19, 2011, 12:32 AM
oly_rcer is offline
DesMoines,Wa
Joined Feb 2008
will try this.by the way,bec?where do you fly at?i notice your in auburn and i fly at flaming geyser
Old Aug 19, 2011, 01:16 AM
BEC is offline
BEC
BEC
BEC's Avatar
Joined Jan 2001
I haven't been to Flaming Geyser this year yet - though I have been a member of the club. Last Christmas I flew the WAA-08 airplane out at FG.
Lately I fly mostly at meets. Will be here next weekend. That is the only place I've flown my Mosquito so far - at the Memorial Day weekend meet this year.
i've recently gotten back into model rocketry and it's absorbed most of my hobby time for the past couple of years - but I couldn't resist the Mossie as it's one of my favorite airplanes of all time.
Old Aug 20, 2011, 11:30 AM
GradyLee is offline
Find More Posts by GradyLee
Parkstormer!
Raleigh, NC
Joined Jan 2010
I flew mine this morning, after replacing the left prop. On each of the flights, things would go normally a minute or two, then I'd get "the screech" and both motors would quit. I could pick it up and hand-launch it, and the same thing would happen again. Finally, it threw the left prop again. I'm sure I can get the prop re-mounted and glued securely, but I don't really understand the screech followed by motor cutoff. Any thoughts/suggestions? I doubt it's the batteries--I don't hit LVC that often and I tried with 4 different batteries this morning; I doubt they all went bad at once, and the results were the same with each. Thanks in advance!
GradyLee is offline Find More Posts by GradyLee
Old Aug 20, 2011, 03:37 PM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
Your screech is a motor that is kaput! basically the bushes are braking up.
you can order a set or mosquito motors. best replace both at the same time! as I didn't, now Iv noticed one prop freewheels better than the other so I get some in commanded yawing now and then. the motors have different end caps. so remember which motor is where and what tire is where!
have fun! it's a little tricky opening up the aircraft!
lord chris is offline Find More Posts by lord chris
Old Aug 20, 2011, 04:48 PM
GradyLee is offline
Parkstormer!
Raleigh, NC
Joined Jan 2010
Thanks for the head's up--I'll go ahead and order a set!
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 23, 2012 12:51 AM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 02:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 03:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 01:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 02:28 PM
