Old Jul 19, 2011, 07:37 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by jabsten View Post
Do you just flip the switch for the spoilerons when landing and thats it? I never really had an issue landing withought and spoilerons. I do land on grass...just raise the nose and plop.
Not really. You can pop up the spoilers and fly around slower. It makes the plane very stable and easier to land.
I land and take off from a concrete aircraft carrier that is 25' long, with a 5ft high rock wall "stern" and a 3 foot high barrier at the bow... so a predictable glide slope keeps me from breaking my planes, because I only get one shot at a landing.
UNGN is offline Find More Posts by UNGN
Old Jul 19, 2011, 09:58 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
What I meant is can u set the spoileron to a swich and activate for landing?
jabsten is offline Find More Posts by jabsten
Old Jul 19, 2011, 10:19 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That is the easiest way to do it.
Old Jul 19, 2011, 11:11 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
Sweet...I might have to program that in to see how it goes...I guess you could use the spoilerons as you said for slower flight stability. Also, do you add in some elev mix to this?
Old Jul 20, 2011, 05:58 AM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
spoilerons are good flaperons are bad
if you have a spektrum tx, it only takes a few mins to sort it all out.
lord chris is offline Find More Posts by lord chris
Old Jul 20, 2011, 08:56 PM
LtColSpit is offline
Find More Posts by LtColSpit
"I'd rather be flying..."
LtColSpit's Avatar
United States, SC, Beaufort
Joined Mar 2004
Originally Posted by Scottmac737 View Post
Any pics or video of the Mossy or Corsair with lights?
Some pix...
Will be at a night fun fly next weekend and will have pix and video of all night lit UMx aircraft (if mother nature is kind to us). LCS
LtColSpit is offline Find More Posts by LtColSpit
Old Jul 21, 2011, 12:57 AM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
I have the DX8. I don't know how to set it up yet.
Old Jul 21, 2011, 12:58 AM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
Originally Posted by LtColSpit View Post
Some pix...
Those look sweet.
Old Jul 21, 2011, 05:54 AM
RAFMAA
Joined Jun 2005
firstly you need to set the brick to run each servo as a separate channel and then reverse 1of the channels. that informations can be found by searching this forum...
http://www.rcgroups.com/forums/showp...postcount=1273
then for your transmitter. i just youtubed a video of how to set it up
DX8 Flaperon Setup (2 min 33 sec)
bish bash bosh spoilers on a mosquito
Old Jul 21, 2011, 10:16 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Ok I have spoilerons on 45%....... it was so much Easyer bringing the mosquito into line and down on the runway! had some really nice touch and goes......until!
1prop (stbd) flew off and up! my mossy went into a fast flat spin. luckily no damage!
I did have a noise prior to separation. it sounded like it was the gears spinning to fast and almost vibrate/screech.... is this the screech of death? or is it just from my loose prop?
any ideas?
also if it is the screech of death. what size are the mosquito motors? will Sp2's fit?
Cheers Chris
I could be wrong here but that sounds like you might have been coming in a bit too fast with low motor speed so the windmilling prop unwound off the thread
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jul 21, 2011, 10:54 AM
RAFMAA
Joined Jun 2005
i was cruising 50%ish thrott.
banked and nailed it for a fast low pass.... and then Screeeeeeech
followed by
then
and then
im going to lube up the gears and pop the prop back on, then see if i have the same screech noise.
after that my only option is motor swap x2 as i dont want to be yawing all over the place.
edit: forgot to mention....... tiny brite lights on the way!
gone for
1 red
1 green
2 landing
1 white strobe
1 red strobe.
should look good
Old Jul 21, 2011, 11:38 AM
BMFA 190658
Joined Mar 2007
Sounds good!!
I've just done the Dual Aileron Mod on mine and mixed in some differential, might be able to get away without Ail/Rudder Mix now for nice Scale like flight!
btw, my longest flight was about 20mins using stock battery. I was cruising round at about 1/3 throttle under a nice dark cloud... Once a Glider Pilot, always a Glider Pilot!!
Old Jul 21, 2011, 01:06 PM
F18 is offline
F18
Find More Posts by F18
F18
United States, MA, Onset
Joined Apr 2008
Sounds good!!
Dosn't it cast a damn nice silhouette? You can imagine a partial squadron of them flying overhead patrolling the English Channel in WWII. I do like this plane!
F18 is offline Find More Posts by F18
Old Jul 21, 2011, 01:44 PM
BMFA 190658
Joined Mar 2007
It's a stunning aircraft, love it to bits!
I'm after a larger scale model that I might even put twin 4stroke nitros in to sound the part, now that would be nice...
Old Jul 21, 2011, 04:41 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
http://www.youtube.com/watch?v=9MeL5hg5VY0
I tried to set up spoilerons, but both ail are going up and down together...can't get them normal.
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
