Old Jul 04, 2011, 11:30 PM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Originally Posted by Ultra_Spitfire View Post
My Mosquito is going back to HH. I had a gutful of reciever lock outs, losing bind in-flight and most of all, I only flew it 6 times!!!! If they don't replace it, I am going to the Consumer Services Board and taking action. HH has always stuffed me around, one way or another. My little T-28's reciever shorted when I flew it for the first time. What did they do? You flew it, you replace it! In the end they replaced it, but with my luck, they won't do a thing.
You're right to be pisssed-off. But do not forget that 99% of radio faillures are due to user 'mistakes'/bad handling/lack of knowledge. It's is so easy to imagine the load of complaints HH gets and then the % of claims that simply aren't founded.
Still, I've had only great responses from HH when contacted and of all the companies I've had to complain to, HH is deffinately the most responsive one.
Good luck :-)
Chrizz is offline Find More Posts by Chrizz
Old Jul 05, 2011, 04:33 PM
kevin finn is online now
Find More Posts by kevin finn
United States
Joined Oct 2008
radio
what radio are you using to fly this plane
kevin finn is online now Find More Posts by kevin finn
Old Jul 06, 2011, 07:09 AM
Ultra_Spitfire is offline
Find More Posts by Ultra_Spitfire
Super Man's cousin! No cape!
Ultra_Spitfire's Avatar
Australia, New South Wales, Wangi Wangi
Joined Sep 2010
DX6i, on DSM2.
To add to my trouble's, I got a call from HH, saying the new charger had been sent to my LHS, and upon inspection, its for a UMX Beast! Not buying from HH again, unless they improve on customer support. One more thing they stuff up, I am bringing the Consumer Service's board into it.
Ultra_Spitfire is offline Find More Posts by Ultra_Spitfire
Old Jul 08, 2011, 12:40 PM
awacsCZE is offline
Find More Posts by awacsCZE
awacsCZE's Avatar
Joined Aug 2010
Hello again,
finally I finished repairs of my Mosquito and I have two glitches to ask.
First is, if you can hear any proble in servo move? Because I think it sounds weird
Mosquito servo move (0 min 12 sec)
And then I have maybe bigger problem. Right motor seems to going less smoother, than left in low rpm. In high rpm it seems to go well, because plane is taxiing in straight line, but I ask for your opinion, if it can be flown.
Mosquito engine run (0 min 21 sec)
awacsCZE is offline Find More Posts by awacsCZE
Old Jul 08, 2011, 09:14 PM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
The servos sound fine, its likely they are making different sounds because of where they are positioned. The slower motor, try adding some lube to it, it will probably loosen it up.
Lberry.88 is offline Find More Posts by Lberry.88
Old Jul 09, 2011, 02:29 PM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
My (and other's) right motor problem was a bad brick. See much earlier in the thread.
You can replace the motor for a temporary fix. Ultimately, you need a new brick. there were some bad bricks in the early release of the plane.
Lubing will do no good, but can't hurt.
Suggest you call HH support.
BlazingStar is offline Find More Posts by BlazingStar
Old Jul 09, 2011, 08:31 PM
LtColSpit is offline
Find More Posts by LtColSpit
"I'd rather be flying..."
LtColSpit's Avatar
United States, SC, Beaufort
Joined Mar 2004
Ultra micro light kits
SF Design Solutions micro lighting kits are designed for the ParkZone and E-Flite ultra-micro (UMx) F-4U Corsair, T-28 Trojan, P-51 Mustang and Mosquito. Kits are also available for the UMx Beast.
The 1S (3.7-4.2 volt) micro light kit weighs 2.5 grams and and consists of red/green wing-tip navigation lights, blue tail light and white landing light. A red flashing LED tail light is available upon request. The 5-light micro kits (Mosquito and Beast) have an additional (white) landing light. The lights run full time and are powered by the stock 1S battery pack (or 2S for the Beast) . Flight tests have demonstrated 6 to 8 minute flight times at normal power. Installation involves opening the fuselage, routing the wiring harness and taping it to the airframe. The wiring harness plugs directly into the AR6400 X-port and sip power at approximately 10mA per 6 minute flight.
**The Nano-JST plug is only compatible with the AR6400 series combination board and is not compatible with the AR6300**
Prices are $15 shipped for the 4 light kits (F-4U, P-51, T-28) and $18 shipped for the 5 light kits (Beast and Mosquito). Visit www.sf-design-solutions.com for more information. You can also follow a thread on HorizonRcFlyers.com. LCS
LtColSpit is offline Find More Posts by LtColSpit
Old Jul 11, 2011, 05:20 AM
awacsCZE is offline
awacsCZE's Avatar
Joined Aug 2010
Good day,
I have good news. Yesterday I remaidened my reapaired Mossie and it was succesfull. Itīs still great plane and flies perfect. There is no issue about right engine. Itīs wonderful and I want to thank Parkzone for that plane
Old Jul 11, 2011, 05:25 PM
Scottmac737 is offline
Find More Posts by Scottmac737
CV-63/VR-62
Scottmac737's Avatar
New Haven, MI
Joined Aug 2009
Any pics or video of the Mossy or Corsair with lights?
Scottmac737 is offline Find More Posts by Scottmac737
Old Jul 11, 2011, 07:54 PM
LtColSpit's Avatar
Joined Mar 2004
UMx Light Kit Pix
Yes. Pix of all A/C are located on my website - www.sf-design-solutions.com
There is also a short video of the T-28 in-flight, and both the T-28 and F-4U on deck (day/night).
LCS
Old Jul 12, 2011, 04:27 AM
rcpilot23 is offline
Find More Posts by rcpilot23
rcpilot23's Avatar
Perth, Western Australia
Joined Feb 2007
Hello again,
http://www.youtube.com/watch?v=BE5dGQWFM6A
http://www.youtube.com/watch?v=codg8cYRTm8
Mine has the same problem. the left motor sticks and I have to turn the prop by hand. Its back at my LHS having the motor replaced.
Common problem I have been told
Very Annoying since my ultra micro P51 did the same thing.
crap motors.
rcpilot23 is offline Find More Posts by rcpilot23
Old Jul 13, 2011, 04:11 AM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
im just waiting for my mosquito to arrive and have a quick question.
is the battery connection that same as other pz um aircraft? i have some 190mah miniaviation batts and wondered if i would be able to use them? i saw a video on youtube where they guy said the battery was unique to the model and then went into ways of using other batterys.
lord chris is offline Find More Posts by lord chris
Old Jul 13, 2011, 07:04 AM
Lberry.88's Avatar
Joined May 2007
Chris - the battery connectors are the same as in PZ UM planes - the battery is only unique for this plane because of its capacity.
Old Jul 13, 2011, 11:21 AM
RAFMAA
Joined Jun 2005
ok thats cool. 190mah should give me ok flight times tho? right?
Old Jul 13, 2011, 12:27 PM
Lberry.88's Avatar
Joined May 2007
probably only 4 or 5 minutes, the stock battery is 250mAh and gives 7-8 minutes.
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
