Old Mar 31, 2011, 10:33 PM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
United States, FL, Ponce De Leon
Joined Nov 2005
To start, I have a mosquito, it is awesome. I have had ZERO of these issues with it. It flies straight, tracks true, and will do a full throttle fly by no with little input.
That being said, why should the plane, out of the box, need as much as claimed, down elevator trimmed in
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old Apr 01, 2011, 12:14 AM
maxwellmark is offline
Find More Posts by maxwellmark
Bakersfield, California
Joined Jan 2007
Originally Posted by mclarkson View Post
Tell me if this looks right.
I taped a bamboo skewer flush with the bottom of the wing. Then I placed a second skewer flush with the bottom of the tail.
It seems to me I'm seeing at least an 8 degree up angle on the tail plane compared to the wing.
Is this a valid measurement? Is this what it should be? Can anyone confirm their own measurements?
That is a good way to display the angle of attack.
I used a Robart wing incidence gauge, and found that the rear stab is at -.5 deg. and the LE of the wing is at +2.5 deg. from center line.
maxwellmark is offline Find More Posts by maxwellmark
Old Apr 01, 2011, 09:04 AM
F18 is offline
F18
Find More Posts by F18
F18
United States, MA, Onset
Joined Apr 2008
Mine flys great too! I dial in a little down elevator only in windy conditions but that is about it. The plane should fly level with all control surfaces neutral and no wind if the plane is balanced correctly. Mine has a nice glide angle even with dead stick!
The only real variable I see with the Mosquito is that it is available only as
a BNF..... so everyone is binding different Spectrum compatible transmitters which makes me wonder........?
F18 is offline Find More Posts by F18
Old Apr 01, 2011, 09:11 AM
Jack Brewer is offline
Find More Posts by Jack Brewer
United States, IN, Lafayette
Joined Dec 2003
Mine flew perfect right out of the box, even the trim was right on. With stock battery it did loops, rolls. split "S", inverted flight and hammerheads, I couldn't ask for anything more.
I am very pleased.
Jack
Jack Brewer is offline Find More Posts by Jack Brewer
Old Apr 01, 2011, 09:52 AM
GradyLee is offline
Find More Posts by GradyLee
Parkstormer!
Raleigh, NC
Joined Jan 2010
I am very pleased.
Jack
+1. As much as I like my Suhoi XP I find myself flying the Mossie first, until I'm out of batteries for it!
GradyLee is offline Find More Posts by GradyLee
Old Apr 01, 2011, 10:08 AM
Navy Fly Guy is offline
Find More Posts by Navy Fly Guy
Navy Fly Guy's Avatar
Lubbock, TX
Joined May 2008
Great little scale aircraft
I have to agree with those just above here. I have had no flying problems with my Mossie. I love flying it in the front yard along with the micro T-28. My ONLY grief is the noseovers have chave cost me two cannons. No big deal.
NFG
Navy Fly Guy is offline Find More Posts by Navy Fly Guy
Old Apr 01, 2011, 10:46 AM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
More rain and wind so I don't think I'll be flying her today. Can someone post a side view photo showing how much the trim is set in the elevator?
thanks,
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Apr 01, 2011, 11:25 AM
aginzu is offline
Find More Posts by aginzu
Aptos, CA, USA
Joined Apr 2001
Elevator Servo Not Centering
We figured out why mine seemed to be wanting to pitch up excessively.
I thought it was a CG problem but it turned out that the elevator servo was not centering. That is, if I went from up elevator to neutral the elevator would not return all the way to neutral unless I put in some down elevator. This caused the plane to pitch up when coming out of turns or climbs and made it feel unstable. The clue was that it wasn't unstable when coming out of a dive, as it would be if the CG were too far aft. Looking at the elevator position when going from up to neutral, it was then obvious what was happening.
I called ParkZone and they are sending me a new board.
aginzu is offline Find More Posts by aginzu
Old Apr 01, 2011, 11:56 AM
wrcsti is offline
Find More Posts by wrcsti
wrcsti's Avatar
UM DC-3 next?
wrcsti is offline Find More Posts by wrcsti
Old Apr 01, 2011, 12:35 PM
Joined Dec 2003
UM A-26 Invader should be next on the list.
Old Apr 01, 2011, 12:58 PM
F18 is offline
F18
F18
Joined Apr 2008
Originally Posted by wrcsti View Post
UM DC-3 next?
Oh ya! That could easily be painted and decaled to resemble the US Navy's YC-129 or the C-47 troop transport. 1936 was a very good year!
Also a P-38 Lightning or a Northrop P-61B Black Widow night-fighter. I am facinated with double tailed aircraft!
Old Apr 01, 2011, 01:16 PM
kingsnake11 is offline
Find More Posts by kingsnake11
kingsnake11's Avatar
Langley, British Columbia
Joined Oct 2009
NFG
Me too. No real problems once trim is set with a little down elevator. No problem doing basic aerobatics and siimply a fun plane to fly. I really like doing scale takeoffs and landings. Apart from a sticky wheel (easy to fix) it has been fun flying.
kingsnake11 is offline Find More Posts by kingsnake11
Old Apr 01, 2011, 01:46 PM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
Regarding nose high attitude flying
I thought I'd add my experience here too.
Right out of the box my mosquito also flew very "tail heavy", nose high attitude. Perhaps not as severe as mclarkson, but still bad enough that I had to add all the down trim the Tx would allow and still needed more.
Easily fixed by bending the elevator control rods at the U joint.
So mine was not "perfect out of the box" as the above two posts suggest.
My other "negtive" experiences have been:
  • weak right motor (which died after 12 flights - replacement seems to also have issues)
  • Having to cut both motor nacelle and fuse to swap out the motor
  • easy rudder damage from nose overs
All in all, a pretty positive experience and I know HH is reading this and implementing improvements in their next release (P38? B25? B17?....)
BlazingStar is offline Find More Posts by BlazingStar
Old Apr 01, 2011, 03:28 PM
F18 is offline
F18
F18
Joined Apr 2008
Scale pilot for the Mosuito?
Sorry...but I did not do a search and this topic may have been posted on before!
But does anyone know of a source for scale pilots that would fit the Mosquito and the other Ultra Micros? I would say they would need to be 1/32 scale
to look right.
I googled it and most of the companies that were doing unpainted scale pilot figures in 1/32 at one time are out of business......
Old Apr 01, 2011, 03:35 PM
Joined Dec 2003
http://parkflyerplastics.com/cart/in...roducts_id=505
Sparky has 1" pilots at the end of his list of pilots kits, you paint.
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
