Old Mar 30, 2011, 04:14 PM
Ultra_Spitfire is offline
Find More Posts by Ultra_Spitfire
Super Man's cousin! No cape!
Ultra_Spitfire's Avatar
Australia, New South Wales, Wangi Wangi
Joined Sep 2010
Originally Posted by NWarty View Post
Went to my LHS today to get a BNF Micro T-28 and bought the Mossie instead! HOLY COW I didn't know that this thing was out! She sure is a looker
Weather here is crummy but luckily I have three softball fields less than 250 yards from the house
Can't wait to maiden!
Hahaha, I was after a BNF T-28 and walked out with a Mosquito She is a really good plane. Flies alot like The Beast!
Ultra_Spitfire is offline Find More Posts by Ultra_Spitfire
Old Mar 30, 2011, 04:43 PM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Indoor or outdoor?
I'm sure that I will not be the last to have a first flight on this cute little Mossie.
The weather has been its usual non-cooperative self, so even though I knew it was going to be a bit windy I went for it.
Our club has a lovely smooth hard-top runway so the wheels were used. The good news was that my 250mAh batteries from the Chinook were the same. Just added a bit of Velcro and bingo, spare packs.
You really do need to get the pack all the way forward, but the nose cover stops you. Hmmm...
The (bloody cold) wind came and went unpredicatably. Before the first flight the wind was blowing so hard that it needed 3/4 throttle to just hold its ground on the runway.
The wind then dropped so off we went. Of course, she climbed a lot, so much that I landed ASAP and dialed in a bunch of down-sub-trim and took the regular trim back to the center. Much better. Left the sub-trim command on and added some more rather than use the flight trim. Ended up about 1.16: down. There is definitely a climb (nose-up efect) on full throttle. Fixed that with some throttle to elevator down trim point-mix startingat about 1/4 stick and increasing to 10%.
Ailerons were right on and no rudder trim was needed. Fying was much better with the correct trims. Rolls were easy but they do drop off on the fourth quarter. Rudder did not help much. I saw this later in stall turns. I would submit that the two props fight the rudder- Most of my twins do this. Thought/hoped it might be different with contra-roating engines! (Oops! I mean motors).
The best way that I found to get a good roll was to pulse the elevator. With the right timing the rolls looked realy good. Inverted was solid straight ahead and in turns. You could push out in a 1/2 outside loop to get level again, instead of rolling.
Landings were a treat with or without a headwind. The slow flight was really good in a straight line.
Now to indoor flying. In a basketball court--I would say nope! In two courts side by side--maybe. Bigger than that no problem. The prior conclusions should be couched with some flying skill metrics--if such a thing could ever exist.
The wind did drop for significant periods of flying time and I tried flying at gym-speeds which are inherently slower for most of us.. The Mossie will fly slowly but you get into trouble in the turns. Flat turns with a twin usually suck unless you can modulate the engines in favor of the turn. So instead of rudder/yaw you bank and then gently yank. Then everything either speeds up or you drop the nose badly.
Stick four soccer-cones, to mark out your indoor facility, on the grass and see if you can stay within their boundries. Then take 20% off that space to allow for the reality and effect of solid walls on your eyes (and courage!)--Bon voyage!
Anyway, I now adore my Mossie and need more of the AR6400T boards!!!
FYI - I did do some CAR and that really helps the indoor skill-set needed but messes up rolls etc.
Regards,
Eric H.
Eric Henderson is offline Find More Posts by Eric Henderson
Old Mar 30, 2011, 09:29 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Was busy today so didn't get to peek out the windows too much but it looked pretty breezy. Thanks for all of the info and suggestions fellas. If the wind is low in the early AM she will be flying. Doesn't look too promising though. Rain and snow for tomorrow. What part of NJ are you in Eric?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Mar 30, 2011, 10:29 PM
NWarty is offline
Find More Posts by NWarty
It's the Water!
NWarty's Avatar
Olympia, WA
Joined Apr 2005
Got two full flights on her tonight, YAY!!!
She looks so darn good in the air. I'm in love
NWarty is offline Find More Posts by NWarty
Old Mar 31, 2011, 03:15 AM
Rowdy_b64 is offline
Find More Posts by Rowdy_b64
Our main weapon is surprise...
Rowdy_b64's Avatar
Melbourne, Australia
Joined Aug 2006
Now don't you start .. one of the guys recommended I marry mine after a post like that! ... I asked if that was legal ....
Rowdy_b64 is offline Find More Posts by Rowdy_b64
Old Mar 31, 2011, 10:23 AM
F18 is offline
F18
Find More Posts by F18
F18
United States, MA, Onset
Joined Apr 2008
I talk to my plane more than my wife!
The comedian Red Skeleton once said, "I have not spoken to my wife in 18 months.....I don't like to interupt her"
F18 is offline Find More Posts by F18
Old Mar 31, 2011, 10:52 AM
F18 is offline
F18
F18
Joined Apr 2008
I posted a few pages back about the erratic aileron servo movement I was progressively having with my Mossie at low rpm with initial throttle imput.
After twisting wires and trying to temporarily shield some of the wire sets... nothing worked.
While bench testing I had switched to a 160mAh battery because the original 250mAh needed recharging. And the servos worked perfect with the alternative battery.
I purchased 3 new 250mAh batteries and the plane functions perfectly again.....like new! With the new batteries there is NO erratic aileron servo glitching at low rpm. So with my mossie, the problem was due to a defective/
unhealthy battery (original battery). Not sure how that manifested itself in the aileron servos being possesed.....but using a new battery cured the problem
Cheers
Old Mar 31, 2011, 10:59 AM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
While bench testing I had switched to a 160mAh battery because the original 250mAh needed recharding. And the servos worked perfect with the alternative battery.
unhealthy battery (original battery). Not sure how that manifested itself in the aileron sevos being possesed.....but using a new battery cured the problem
Cheers
That's good news thanks for the update!
I'm not sure how a battery can have that effect but glad you got it working.
jer291113 is offline Find More Posts by jer291113
Old Mar 31, 2011, 11:15 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
I had a bad battery like that, that I used with my Mustang & Cub. It had full voltage but I could not bind either plane with it. Stuck another battery in with the same exact voltage & everything was fine.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Mar 31, 2011, 11:18 AM
F18 is offline
F18
F18
Joined Apr 2008
Me neither! I had experienced alot of rc battery issues over the years.....but I have never seen a bad battery effect just one set of servos like this until now.
Must be something inherent to the Spectrum RX........
Old Mar 31, 2011, 11:59 AM
Joined Dec 2005
Mike,
I must appolgise, I did not update my profile correctly. I recently moved to Rockville MD. I missed the state field when I did my entry.
Regards,
Eric H.
Old Mar 31, 2011, 02:23 PM
taekwondo is offline
Find More Posts by taekwondo
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
You can if she's of age. LOL
taekwondo is offline Find More Posts by taekwondo
Old Mar 31, 2011, 02:31 PM
Joined Jan 2004
Originally Posted by Eric Henderson View Post
Mike,
Regards,
Eric H.
No problem Eric. Hope you have more good flying weather down there.
I might have some luck this evening. No longr raining and the wind looks to be down to 1-2mph.
Old Mar 31, 2011, 02:36 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Can the 500mAh 1-Cell 3.7V 12C Li-Po for the 120SR be used with the Mossie without any special connectors?
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Mar 31, 2011, 03:12 PM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
No, it has a JST plug so you need one #BLH3126 Blade 120 SR Variable Rate Charger Adapter.
http://www.wheelspinmodels.co.uk/air...dapter__1233f/
They cost about $3.20 over here so probably cheaper your side of the pond
Roger Lombard is offline Find More Posts by Roger Lombard
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 23, 2012 12:51 AM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 02:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 03:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 01:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 02:28 PM
