Old Mar 27, 2011, 10:05 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
Originally Posted by Kamov View Post
had a problem with the mossie I left my call back number and they called back in 30 minutes and had a broken part shipped in 2 days no charge. HH has superb support in the industry.
I flew the Mossie in high winds today and it was just floating above my head. Im using a TP 360mah 25c cell and the weight seems to help. I want to try the eflite 1s 500mah
but does anyone know a 1s cell between 360-500 that would fit the battery tray?
I'm getting 9 minutes on the 360mah and stock just around 6min before it hits lvc normal flying with occasional WOT. Is 6min on the stock about average?
I don't fly in windy conditions, but set my timer for 10 minutes now on the mossie and never get near pulse or low voltage cutoff. It still seems to have full power. I have flown it for 12 minutes numerous times without power loss. I only have the stock 250 batteries. Several others here report this same flight time.
bobly is offline Find More Posts by bobly
Old Mar 27, 2011, 10:13 PM
Gary Hoorn is online now
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Weather was not conducive to flying today so I set about seeing how many of the functions on my new DX8 I could lay on the Mossie. Separate ailerons, spoilerons, triple rates and throttle hold on Mix 1. I ran the motors slowly for about 3 minutes to set the brushes, let things cool and then gave it a blast of throttle. It almost looks like it will hover. Motors sound great and in sync. Come on Mr. Weatherman give me a break as it is time for a maiden...
Gary
Gary Hoorn is online now Find More Posts by Gary Hoorn
Old Mar 27, 2011, 11:07 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Gary
I hear you on the westher Gary, I've been grounded for about a week now of constant 30 km / hr winds, and it's getting darn frustrating. Can't wait to get my little mossie back in the air, it's a blast to fly.
You have to try to hook up a vid of that maiden for us!
Marlin
Fish99 is offline Find More Posts by Fish99
Old Mar 28, 2011, 01:02 AM
maxwellmark is offline
Find More Posts by maxwellmark
Bakersfield, California
Joined Jan 2007
<edit>
but does anyone know a 1s cell between 360-500 that would fit the battery tray?<edit>
I've got 2 240mAH with a parallel plug that fit perfect. I can get 15 minutes if I manage my throttle right. I usually set my watch for 10 minutes. Figure thats long enough wear on the motor for each flight. While it cools I fly 1 of my other UM's.....Too many planes, not enough batteries
maxwellmark is offline Find More Posts by maxwellmark
Old Mar 28, 2011, 09:02 AM
ChuckTseeker is online now
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
was doing a bit more reading and searching and found out that right here in good ol Australia we built over 200 of the Mosquito's and i found this old Aussie news reel vid on the tube, it shows it being built and it has some good flying at the end too
cheers chuck
Wooden Mosquito Airplane Manufacturing in Australia -1944 de Havilland DH98 (3 min 1 sec)
ChuckTseeker is online now Find More Posts by ChuckTseeker
Old Mar 28, 2011, 12:26 PM
Dualquad62 is offline
Find More Posts by Dualquad62
Joined Aug 2010
cheers chuck
http://www.youtube.com/watch?v=c7cVvYdLeek
Great vid Chuck! Thanks for posting!!
Dualquad62 is offline Find More Posts by Dualquad62
Old Mar 28, 2011, 12:38 PM
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Chuck,
Thanks for finding that video. I am dying to maiden my Mossie but the blasted weather simply will not cooperate
Gary
Old Mar 28, 2011, 01:11 PM
mitsudriver274 is offline
Find More Posts by mitsudriver274
Joined Jul 2009
Picked up my mossie the other day, maidened her. With a hyperion 240mah should she be able to loop from level flight?
mitsudriver274 is offline Find More Posts by mitsudriver274
Old Mar 28, 2011, 01:21 PM
GradyLee is offline
Find More Posts by GradyLee
Parkstormer!
Raleigh, NC
Joined Jan 2010
cheers chuck
Great video! I'd known the Mosquito was done in part with balsa . . .
GradyLee is offline Find More Posts by GradyLee
Old Mar 28, 2011, 02:03 PM
Fish99 is offline
Fish99's Avatar
Joined Jun 2010
I loop mine from level flight with the stock battery, just have to get it going good, high end throttle, and it loops fine. I imagine it will loop even better with the Hyperion battery.
Marlin
Old Mar 28, 2011, 03:27 PM
Kamov is offline
Find More Posts by Kamov
Kamov's Avatar
CA
Joined May 2007
looks like any competent carpenter[or RC modeler] can make a full size mossie from plans
now where do we get a pair of Merlins ? and buckets of wood glue
Kamov is offline Find More Posts by Kamov
Old Mar 28, 2011, 03:51 PM
Joined Jul 2009
Thats interesting mine def won't loop from level flight, it also came with both the aileron servos plugged into there own ports
Old Mar 28, 2011, 06:23 PM
Fish99 is offline
Fish99's Avatar
Joined Jun 2010
Hmmm, I just looked at some video I posted earlier, check out 1:58 of this vid where it is a pretty level loop, then again at 2:58 where I pull a loop after a short CLIMB from mostly level flight.
Parkzone Mosquito Parking Lot Flying (6 min 3 sec)
You can sort of see a WOT throttle loop from level at about 1:00 of this vid as well.
PZ Mosquito UM Test Flight (7 min 12 sec)
I have not pulled mine apart so don't know if the ailerons are set up in a Y or not. I will say the loops are more like a written L than an O, but not too much issue at all. I do pull up to go into a roll, as the roll rate is a bit slow. I may also be cheating the loops just a hair in dropping the nost just before going into them ... but you can judge from the vid yourself.
All the best,
Marlin
Old Mar 28, 2011, 07:36 PM
aracer is offline
Find More Posts by aracer
UK, Hereford and Worcester, Worcester
Joined Feb 2009
Scrap a couple of Spitfires?
aracer is offline Find More Posts by aracer
Old Mar 28, 2011, 07:51 PM
BigD1961 is offline
Find More Posts by BigD1961
Team OFG (Old Fat Guys)
BigD1961's Avatar
United States, KY, Leitchfield
Joined Jul 2008
Expo on Mossy.
I am sure someone has posted it, but I am too short on time to look throgh all the threads to find it. So what does everyone recommend on expo? I programmed it into my DX6I and put in 80% on everything, but it's too windy to fly today so I can't try it out yet.
Any suggestions?
I already have the leading edges taped up and I applied a few details with a sharpie to "sharpen" it up a bit. I may paint it up a matt black to make it into a night fighter like someone else did.
SEFF awaits and I need to maiden her before then, so lets hear it guys and gals.
BigD1961 is offline Find More Posts by BigD1961
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 23, 2012 12:51 AM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 02:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 03:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 01:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 02:28 PM
