Old Mar 24, 2011, 03:12 PM
awacsCZE is offline
Find More Posts by awacsCZE
awacsCZE's Avatar
Joined Aug 2010
Fantastic plane after week of flying
Hope, my won´t have airleons servo problems and stay at one rudder stuck ( crossed fingers )
awacsCZE is offline Find More Posts by awacsCZE
Old Mar 24, 2011, 04:14 PM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
This is mine, I put some velcros on the box to stick all the lipos I have (5 in total and box only haves 3 holes), also put some velcros on the big square foam that covers the canopy for safe traveling
and had to put an improved box handle (not like the P-51 box that has handle and easy opening)
Damage a bit the tail but with foam safe glue got it fixed.
chulian1819 is offline Find More Posts by chulian1819
Old Mar 24, 2011, 04:23 PM
F18 is offline
F18
Find More Posts by F18
F18
United States, MA, Onset
Joined Apr 2008
Originally Posted by jdwolters View Post
Maybe the servos just won't stay still at neutral but when you move to a different spot, it settles down. I was thinking of cleaning mine. (I have one like this on the elevator - no cross-talk from other wires here and this happens with no throttle.)
I was thinking about what you said and I just took a break and was tinkering with the plane again. The stock 25OmAh battery that came with the Mossie needed charging so I just so happened to plug in a 160 mAh to do some static testing. The plane works PERFECT with the 160 MAh battery with NO Aileron servo movement at low rpm.
When I plug the 250 mAh back in I get the erratic aileron servo movement again at low rpm.
How is that possible? Could a "funky" battery have caused this problem?
I need to buy a new 250 mAh battery and test it again.
F18 is offline Find More Posts by F18
Old Mar 24, 2011, 04:45 PM
aracer is offline
Find More Posts by aracer
UK, Hereford and Worcester, Worcester
Joined Feb 2009
Originally Posted by RealGambler View Post
Ideally, it would be better to untwist both set of wires, and then twist them together
Actually doing that is likely to make things worse by coupling the signals in the wires together. Far better to twist each set of wires separately - noting that on mine at least the servo wires are twisted, but the motor wires aren't significantly.
aracer is offline Find More Posts by aracer
Old Mar 24, 2011, 07:23 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Originally Posted by Gary Hoorn View Post
fryfrog,
Running a brushed motor in a glass of water powered by a D cell or 2 is a technique we used back in the dark ages. No prop, just the motor on low voltage. This allowed the brushes to bed in without overheating and made the motors performance more consistent. When finished blow out the water, dry the motor and lube the bearings.
Gary
I like to find out how you lube the bearings on this tiny motor or does it have bushings?
PittSpecial is offline Find More Posts by PittSpecial
Old Mar 24, 2011, 07:38 PM
Gary Hoorn is online now
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Not sure if you can do this on these micro motors, maybe but I have never tried. The technique I posted about was for larger brushed motors like we had to use before brushless motors came along...
Gary
Gary Hoorn is online now Find More Posts by Gary Hoorn
Old Mar 24, 2011, 07:43 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Gary
Gary,
I did realize which size Brushed motors you were referring and again my question is pretty to the point of even bothering with these tiny motors to dump them in water to "Break em in" as someone posted earlier.
I don't think you can re-lube this tiny motor after you submerge it under water and if so, I would love to see some more details.
I think that this Tiny Brushed motor has such a small area on it's brush -to- commutator that it is just not worth doing any "Break in" procedure.
PS
Old Mar 24, 2011, 09:07 PM
Ultra_Spitfire is offline
Find More Posts by Ultra_Spitfire
Super Man's cousin! No cape!
Ultra_Spitfire's Avatar
Australia, New South Wales, Wangi Wangi
Joined Sep 2010
Test flew mine. Bloody twitchy!
Ultra_Spitfire is offline Find More Posts by Ultra_Spitfire
Old Mar 24, 2011, 09:36 PM
Rowdy_b64 is offline
Find More Posts by Rowdy_b64
Our main weapon is surprise...
Rowdy_b64's Avatar
Melbourne, Australia
Joined Aug 2006
What was the wind like ??
Rowdy_b64 is offline Find More Posts by Rowdy_b64
Old Mar 24, 2011, 10:29 PM
skyjet is offline
Find More Posts by skyjet
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
If there was any wind, try it again with zero wind. It flies great with no wind!
skyjet is offline Find More Posts by skyjet
Old Mar 24, 2011, 10:33 PM
Joined Sep 2010
No wind what so ever, I think it was just thermals, as I fly on a hot day usually.
Old Mar 24, 2011, 11:25 PM
Rowdy_b64's Avatar
Joined Aug 2006
Thermals ... man .. how high did you have it?
Old Mar 25, 2011, 12:29 AM
N212LA is offline
Find More Posts by N212LA
keep on spinning!
N212LA's Avatar
Fort Lauderdale,Florida USA
Joined May 2010
Thursday afters fun..
[Youtube]
My short preflight of mosquito,champ, T-28 UM united against a common front! (1 min 15 sec)
[Youtube]
N212LA is offline Find More Posts by N212LA
Old Mar 25, 2011, 02:44 AM
Joined Sep 2010
Gave the mossie a second flight. This time I added nose weight. That did it, and she flies like a dream now! Going to fly it with a banner tomorrow, as it is election day for the state.
Old Mar 25, 2011, 07:21 AM
huntingfield is offline
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
I have had no problems with my Mosquito! Followed the manual as far as control throws and added expo. I also have some Hyperion 240s and find these batteries very good. I have also flown my Mossie indoors and was very pleased to find that it slows down nicely, in fact I can get it to fly slower than my Parkzone J3 Cub !
huntingfield is offline Find More Posts by huntingfield
New Product New Hobby-Lobby micro P-51 and Spirfire! - direct competitor to Parkzone Ultra Micro? Smokescreen38 Micro Ready-to-Fly 316 Aug 22, 2012 11:51 PM
Discussion Parkzone New Ultra Micro Mosquito Mk VI ChuckTseeker Scratchbuilt Indoor and Micro Models 4 Feb 03, 2011 01:22 AM
For Sale parkzone ultra micro J-3 cub BNF trade for micro trojan ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 06, 2010 02:19 AM
Sold Moved to micro section -Parkzone Sukhoi SU-26m Ultra Micro BNF - w/ Lots of new parts major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2010 12:00 AM
Found Parkzone Ultra Micro P-51D BNF (New or like new condition) CGReload Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2009 01:28 PM
