| Thread Tools |
| This thread is privately moderated by Mick Molloy, who may elect to delete unwanted replies. |
Planes begin at 2 mins; look for Robota at 5:17
A slightly different format to Kingaroy you might say... . |
All I wanted to ask is the REVISION of existing rules, either positive or negative, not just iterative adding of extra points. The rules are so complex that IMHO they rule out maybe a half of commercial micro autopilots and most popular open source ones. If you say you can modify open source - fantastic, but I expect then that the number scrunteering flights will reflect the ambition of having really complex failsafe rules.
I would prefer guidelines, probabilities and more open specification etc instead of dictating the fail-safe logic. I can adhere easily, but knowing the amount of work I spent on it, I feel this is unfair to force the others to implement all those algorithms with their sequencing because I see they are far from the most intuitive to implement and test, among dozens of existing possibilities. |
Mick has asked me to moderate the thread until he is able to return. As he has a brand new baby and work committments are keeping him from being active here at the moment.
I sit on the technical committee along with Mick and the other members. I'll endevour to answer some of the questions asked by people hoping to compete in this years 2011 aerial drop challenge, and the 2011/2012 S&R/Aerial drop - OBC challenge @ Kingaroy. I'll also review some of the posts and remove the off-topic/inflamatory etc ones, in the next couple of days. I am also aware the S&R rules link is incorrect on the website, that is being addressed asap. In response to some of the questions asked: Quote:
Yes, both are needed. Graphical display with waypoint and aircraft current location is mandatory. In 2012 we will also require a NMEA feed provided by teams so we can utilise this information for external purposes at the competition. I'm not sure what format we will require the hardware connection as yet, I'll advise once this is known. As always, there is more than 1 way to provide the solution we are requiring, so thinking outside the box is encouraged. Quote:
Hope that answers some questions. Cheers Mark |
Joined Jan 2011
Thanks for that information, I have another question. I can't accurately determine the drag coefficients of my aircraft until I build a full scale model and test it at varying wind speeds in the wild (or a wind tunnel), a scale model won't produce accurate results due to the material used (it can bend in the wind, and making it smaller will make it bend less giving inaccurate drag coefficients). Can I sub in drag coefficients for similar aircraft and provide the real drag coefficients once I have built and tested them?
I refer specifically to this part (more specifically the distances that the vehicle could exceed the mission boundary): "In the case of lighter than air aircraft, strategies should be included that note how the aircraft can be brought to ground in the case of failure, noting maximum crosswinds and the estimated maximum distances that the vehicle could exceed the Mission Boundary." |
USA, ND, Grand Forks
Joined Jun 2010
Joined Jan 2011
The thing is, although it will have many failsafes they will all differ with how long it takes for the aircraft to reach the ground. The hard one to calculate will be the safety valve, as it pops off it loses buoyancy and thus lift, so descends to the ground at an exponential rate, however the drag on the bottom of the aircraft should be great enough to slow its descent, so it would be good if i could sub in values for deliverable 1 and provide the real values in the formulas in deliverable 2. |
| Thread Tools | |
| Discussion Uav challenge outback 2011 | leogarabello | Australian Electric Flight Association | 1 | Feb 08, 2011 08:33 PM |
| Contest OFFICIAL - 2010 UAV Outback Challenge Forum | Mick Molloy | UAV - Unmanned Aerial Vehicles | 589 | Feb 02, 2011 05:18 PM |
| Discussion UAV Outback Challenge | ommadawn | Video Piloting (FPV/RPV) | 0 | Sep 25, 2010 01:37 AM |
| Contest UAV Challenge Outback Rescue 2009 - Official Thread | Mick Molloy | UAV - Unmanned Aerial Vehicles | 720 | Nov 19, 2009 11:42 AM |
