Old Apr 28, 2011, 08:26 AM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
United States, FL, Ponce De Leon
Joined Nov 2005
Dogfighter segment starts around 1:23
Flite Test - 02 SEFF 2011 - EVENT (12 min 1 sec)
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old Apr 28, 2011, 04:55 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Am I reading correctly, you got her over 100mph with the motor/esc you will get with the stock setup, not some upgrade package right?
Originally Posted by Brian Chitty View Post
Here is some DogFighter Footage shot at the SEFF event a few weeks ago. I personally flew it and a blast. This is going to be a fun pylon racer! We even got her up to 113 mph on a level pass with the standard power pack setup!
http://www.youtube.com/watch?v=YErlA...el_video_title
msev is offline Find More Posts by msev
Old Apr 28, 2011, 06:02 PM
Joined Nov 2005
That's what the rep said.
Old Apr 28, 2011, 06:59 PM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
Great to see that speed on a plane that will make much less noise than an EDF or pusher going over 100 mph.
7rider is offline Find More Posts by 7rider
Old Apr 29, 2011, 07:05 AM
Brian Chitty is offline
Find More Posts by Brian Chitty
sponsored by labor
Brian Chitty's Avatar
United States, OK, Broken Arrow
Joined Jan 2006
Yes, Over a 100 for sure. This is not a "hot" setup. I'm sure people will have these airframes blazing much faster with more Kv rated motors and higher cell count batteries.
Brian Chitty is offline Find More Posts by Brian Chitty
Old Apr 29, 2011, 10:24 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Again, I don't believe it is possible w/ the stock 9x6 prop, you just don't get the necessary pitch speed (stock 3s, 1350kV motor), but 8x8 might just do the trick
cheers
Clemens
mopetista is offline Find More Posts by mopetista
Old May 04, 2011, 11:57 AM
Xelerator is offline
Find More Posts by Xelerator
WCRC Skyhawks
Greenville, SC
Joined Jul 2008
According to the data sheet:
The stock setup is called "DogFighter TUNING", 3S, 1130kv motor, 10x7prop, good for 90mph
The upgrade is called "DogFighter ULTRA", 3S, 1350kv motor, 9x6 prop, good for 103mph
Cheers,
Chris
cheers
Clemens
Xelerator is offline Find More Posts by Xelerator
Old May 04, 2011, 12:19 PM
msev is offline
Joined Sep 2010
90mph is still good, at 89 euro in Schweighofer, Austria...
Old May 04, 2011, 12:33 PM
tdriedger is offline
Find More Posts by tdriedger
USA, CA, San Carlos
Joined Apr 2003
3S Lipo @ 10.5V I get the following pitch speeds:
Tuning - 78mph
Ultra - 80mph
100+ mph would need 4S with either of the suggested power setups.
tdriedger is offline Find More Posts by tdriedger
Old May 04, 2011, 03:37 PM
Vienna, Austria
Joined Apr 2007
Calculating pitch speed, and how to account for unloading
Tuning - 78mph
Ultra - 80mph
Your pitch speed calculation assumes a drop of voltage under load (whether 10,5V for 3s is a good estimate depends on the internal resistance of the battery and the amps, for 50+ amps and a regular 25C 2200mA battery that seems ok) but at the same time you take the idle rpm of the motor at that voltage. Even with a fair amount of unloading that is not realistic.
For those who want to know how to calculate pitch speed at certain rpm with a certain prop:
rpm = revolutions per minute. Each revolution propels the prop (theoretically) forward by the amount specified in the pitch (unsually inches)
So by multiplying rpm with the prop pitch you get the pitch speed in inches per minute. To get miles per hour you have to convert that first into miles (I don't know the exact conversion factor as I am "metric", it must be something like 40x1600 inches in a mile) and then multiply by 60 (in an hour you get 60 times as far as in one minute).
So that is the easy part.
tdriedger obviously put in 10,5 Volts times 1350 rev per Volt per minute times 6 inches per revolution and converted that (inches per minute) to miles per hour. Beware that the kV gives you the idle rpm per Volt...
A software such as drivecalc will also tell you how fast a certain motor will spin a certain prop using a certain battery. You see that a motor under load will spin the prop less fast than at idle w/out prop, typical is some 60-75%.
That gives you static pitch speed. What you have to guesstimate is the unloading in flight, i.e., the motor is revving more freely because the air is coming along nicely for the prop to shove behind. That depends on a host of factors, in well-designed setups which aim for high prop efficiency you get something like 20% unloading. If you use very high pitch props they will only unload in a steep dive but won't give you the maximum level speed. Conversely, if you choose a big prop with less pitch you will have plenty of static thrust which results in good acceleration, good vertical but limits your speed, and the prop acts as a brake even in a shallow dive.
Although in theory a plane will be slower than the pitch speed of the prop (since there should be no thrust to propel the plane if the prop's movement is just matching the speed of the incoming air) speeds can sometimes be as high as pitch speed due to prop airfoil lift effects - and the true pitch of a prop isn't always what's printed on it.
A dogfighter with those big props will see a lot of unloading in level flight since 9x6 or 10x7 would be chosen for maximum vertical acceleration. For speed you would want to use 8x8 or similar.
I hope we will soon see how fast this dogfighter really is. I wouldn't buy any of the MPX drive sets anyway, the good thing about the motor mount is that you can put in any 35mm motor from HK or other without the need to reverse the motor shaft or such.
cheers
Clemens
Old May 04, 2011, 04:58 PM
USA, CA, San Carlos
Joined Apr 2003
I never said that the plane would go 80mph on 3S.
I completely agree with all your points. I simply ran some simple numbers to give the maximum pitch speed with no other losses. Someone with a better understanding of motocalc or similar program could better model performance and speed with 3S and 4S power.
What I believe my numbers do say is that there is no way in the recommended power systems will do over 100mph on any day of the week. Even in a perfect world.
I think 65-75mph is more realistic but I'll leave the scientific numbers to someone else.
Old May 04, 2011, 05:02 PM
USA, CA, San Carlos
Joined Apr 2003
Coincidentally...
113 km/h = 70.2149447 mph
Old May 04, 2011, 06:18 PM
GassPasser is offline
Find More Posts by GassPasser
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
thank you Jesus !
GassPasser is offline Find More Posts by GassPasser
Old May 04, 2011, 06:52 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
No god was involved with the making of this plane.........
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old May 05, 2011, 03:24 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
cheers
Clemens
Hi Clemens,
actually, some sleek models do reach the theroretical (geometrical) pitch speeds, because all those drive calculators never consider that the prop blades are profiled.
You are assuming that the top speed was reached with an 9x6", when the recommended folder is actually 8x7".
I would assume, that the voltage under load at top speed is closer to 11.5V than 10.5V.
11.5V x 1350U/V x 1/60 x 0.1778m (=7") = 46m/s = 165.6kph = 103mph
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Question Kyosho Phantom Reno Racer Motor Selection Cincy E-Flyer High Performance 6 Aug 12, 2011 03:35 PM
Discussion Multiplex news 2011: Reno-style DOGFIGHTER etc mopetista Foamies (Kits) 0 Feb 01, 2011 06:09 AM
Sold Cox Corsair II Reno Racer CL RTF skylane42 Aircraft - Fuel - Airplanes (FS/W) 0 Dec 11, 2010 10:45 AM
For Sale Hacker Reno Racer-Cosmic Wind Doug Hinkel Aircraft - Electric - Airplanes (FS/W) 1 Sep 02, 2010 01:02 PM
