Old Feb 15, 2013, 06:47 PM
conceptmachining is offline
Find More Posts by conceptmachining
Death and Taxes
conceptmachining's Avatar
Des Moines I'm in Heaven...I mean Iowa
Joined Feb 2006
Gave mine a test run today. What a fun plane. Went with the 1300KV turnigy with a 9x6 prop and 2100MAH 3 cell. Gots some good speed, isn't real heavy. A fun flying plane for sure. Gonna be one of my faves. Doesn't take long to get up to soar around. Rolls like a dart. Nice job on this one.
conceptmachining is offline Find More Posts by conceptmachining
Old Feb 16, 2013, 10:16 AM
mr.sand is offline
Find More Posts by mr.sand
Joined Oct 2007
Himax Motor
Originally Posted by MclF1 View Post
i run the dogfigther RR and it is bloody good for a stock setup 3 or 4 cell 2200mah
http://www.ebay.com.au/itm/290652341...84.m1423.l2649
The Himax motor is designed to run on a 3s lipo...not sure how long you can expect it to run on 4s.......
mr.sand is offline Find More Posts by mr.sand
Old Feb 16, 2013, 02:53 PM
mr.sand is offline
Joined Oct 2007
Motor Shafts---Turnigy 3025-1500
Well I made some new 70 mm shafts for this motor and installed them.
There is a groove on the old shaft for a clip at the front bearing location and a 5-6mm flat on the end a few mm from the tip. Now the shaft does have a screw on it applying pressure at the opposite end and I was wondering if I can get away with a 5mm collar at the front bearing instead of cutting the groove and flat...any useful advice would sure be appreciated
Old Feb 18, 2013, 12:37 PM
mr.sand is offline
Joined Oct 2007
Dog Motors --Turnigy 3025-1500
I have been informed on how to repair this shaft properly. A Forum Thank you to
murdnunoc,
Old Feb 18, 2013, 01:17 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Glad to hear you got sorted.
I was going to post that I thought it would be ok to use a collar but got sidetracked and forgot....
feefo is offline Find More Posts by feefo
Old Feb 27, 2013, 09:59 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
My dog is finally ready to maiden. I have an E-flight power 25 1250 motor installed and several different props to try. I plan on starting with a 9X9 on 3s.
asosestrom is offline Find More Posts by asosestrom
Old Feb 27, 2013, 11:03 PM
flypig is offline
Find More Posts by flypig
It's a gremlin, so what.
flypig's Avatar
peterborough
Joined Dec 2007
Well it took two months, but the Dr. MadThrust motor came in today. http://www.hobbyking.com/hobbyking/s...dproduct=29355
It bolts right in, prop adapter seems to bite fine, and a prop clears the nose of the plane. Minimal amount of foam was removed to fit it in.
Must admit, when the post lady handed me the package, there was some instant pucker factor from the sheer mass of it
flypig is offline Find More Posts by flypig
Old Feb 28, 2013, 12:17 AM
flypig is offline
flypig's Avatar
peterborough
Joined Dec 2007
Alright then, just taped her shut with servos, esc, battery and junk roughly where they ought to be. Balanced right at the recommended CoG, wow some luck there eh.
Anybody with a heavy, faster Dog have a good recommendation for a CoG. Often recommend ones are so conservative, a plane will climb like mad under power from being so nose heavy.
Old Feb 28, 2013, 04:41 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
flypig,
Google "Dive test for CG".
Get your CG as close as you can for maiden flight, then do the Dive test in-flight to optimize it.
Good luck,
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Feb 28, 2013, 05:49 PM
flypig is offline
flypig's Avatar
peterborough
Joined Dec 2007
That's my preferred method as well. Just want to avoid an overly pitchy plane, since at first throw it will be untrimmed, on top of being a torque to the left lawn dart
More than likely going to bungee launch it off a hill for the first go at it. At least then I'll have a half way behaving plane for the first hand launch. I've done that before, worked out well.
Old Feb 28, 2013, 08:25 PM
mr.sand is offline
Joined Oct 2007
Mad motor
That motor looks huge. You probably know all this but....
I don't see a problem balancing the plane at factory spec location.
Just before the launch make sure to ground check all controls and have your throws adjusted moderately per factory or slightly less.
The plane should be powered up until you feel it wants to fly out of your hand..then heve it level to 30 degrees up and give it positive forward motion...good luck
Old Mar 01, 2013, 09:25 AM
flypig is offline
flypig's Avatar
peterborough
Joined Dec 2007
Without a doubt, thanks for the advice guys.
Lots of tricks out there, but just as many different airframes with unique considerations. I asked for with this plane, and the advice doesn't fall on deaf ears.
So I noticed on my Rarebear that when I went up in propeller pitch, the plane would " wallow ", unresponsive for a extra 10 - 20 feet , on top of the regular dead air,then pull away. Taking 40 feel to get to full throttle helped. I assume this is normal, and I'll have to learn the best throttle position for the Dogs wing loading, and prop. Does a air prop " cavitate " like a boat prop does if too much power is applied out of the hole?
Old Mar 01, 2013, 09:37 AM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
You are experiencing prop stall. With higher pitch props, they don't really "bite" until they get enough air passing through them. Lower pitch will have more static thrust and give you the low end grunt at the expense of top end speed.
nofreee is offline Find More Posts by nofreee
Old Mar 01, 2013, 11:33 AM
mr.sand is offline
Joined Oct 2007
Cavitate
I don't know about this...I have a funfighter RB and the Dog..never flown a prop smaller than 8x6 sport on dog with a 4s batt...no problems launching following my previous advice...same with Rarebear...If the plane wants to pull hard from your hand before heve and release and your launching into wind...it ain't going to stall--normally
Now launching downwind is a different matter all together...even launching in no wind might be a tad trickier than into wind....I have doofed them before
Old Mar 02, 2013, 02:15 PM
gibb83 is offline
Find More Posts by gibb83
Joined Sep 2008
Just got my first Dog! Gonna glass it a little and make it look good first. Any experiencewith prop saver on this? Running on stock setup.
gibb83 is offline Find More Posts by gibb83
Question Kyosho Phantom Reno Racer Motor Selection Cincy E-Flyer High Performance 6 Aug 12, 2011 03:35 PM
Discussion Multiplex news 2011: Reno-style DOGFIGHTER etc mopetista Foamies (Kits) 0 Feb 01, 2011 06:09 AM
Sold Cox Corsair II Reno Racer CL RTF skylane42 Aircraft - Fuel - Airplanes (FS/W) 0 Dec 11, 2010 10:45 AM
For Sale Hacker Reno Racer-Cosmic Wind Doug Hinkel Aircraft - Electric - Airplanes (FS/W) 1 Sep 02, 2010 01:02 PM
